06-06-2008, 12:59 PM | #801 |
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Thanks guys This is my first "real" exhaust system install. I cobbled together the previous system before and after shortening, but it was no where near this quality; just good enough to get it on the road with no leaks.
lyriks, this is why I chose not to flip the TA tabs on the xmember like the ECE and CCP versions come (ECE is reversible; bolt-on, CCP is not). I do have a step notch and I will be attempting to run pipes all the way back |
06-06-2008, 01:02 PM | #802 | |
PITbut
You didnt bend your own pipes, did you just buy sections of prebent and then made yours??? |
06-06-2008, 04:59 PM | #803 |
go cyclones
I was able to adjust it so the indicator is dead on in all gears. Plus as an added bonus, there's a whole lot less play now. Gotta rebuild the column to get it perfect...[/QUOTE] Well Frizzle you sold me. After about two hours of trying to modify the old bracket after I swapped out my th350 with a 700R4 I went and bought the linkage. I hope to have it in on Monday. yeah. |
06-06-2008, 05:07 PM | #804 |
Mike,
Do you plan on running an X-Pipe?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-06-2008, 08:54 PM | #805 |
Mike I used the same Lokar linkage on my 71'...it works great!
Alex 1971 Lil' Red 350 SBC 700R4 |
06-06-2008, 11:51 PM | #806 |
06-06-2008, 11:52 PM | #807 |
I like it; simple. Makes you wonder why the factory felt in necessary to run that big ol' conglomeration...
06-07-2008, 12:06 AM | #808 |
I see what you mean. A bolt in crossover in front of the transmission mount should work well.
06-07-2008, 12:51 PM | #809 | ||
Although I'm going to have to get two more of the S-bends made at a local shop (they don't sell them individually). Last edited by Frizzle Fry; 06-07-2008 at 01:07 PM. |
06-07-2008, 01:33 PM | #810 |
www.73-87chevytrucks.com
Not sure if this helps, but DR Gas sells them individually from what I have found..
http://drgas.com/development/category.php?cid=4
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-08-2008, 02:46 PM | #811 | |
06-09-2008, 11:10 PM | #812 |
A guy with a truck
Did you try contacting Flowmaster directly? Each piece of that kit has an individual part number. I mention this only because I had a similar situation with Summit/Flowmaster before.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-09-2008 at 11:10 PM. |
06-12-2008, 08:02 PM | #813 |
Insane! One of the best step by steps I have ever thumbed.. errr Clicked through. I'll have to keep my eye open and see it on the road sometime.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
06-12-2008, 10:21 PM | #814 |
06-27-2008, 06:17 PM | #815 |
Well, I took a chance on a local shop hoping the bends wouldn't be too bad They're not usable IMO (mandrel is the only way to go). So there's $60 gone and a lesson learned.
I contacted Flowmaster directly today. They said they would have to make them for me at the end of a 3" run, but got back to me with a quote of $24.44 each. I said I'll take em This, and some other distractions including the 64, has derailed my progress on Tubby for a couple weeks. So with this new wind in my sails I'm headed out to work on the passenger side now I should have both sides hung to the mufflers by the time I get these. Last edited by Frizzle Fry; 06-28-2008 at 12:01 AM. |
07-06-2008, 12:24 AM | #816 |
VA72C10
Absolutely awesome work and an inspiration for me to get moving on mine
07-12-2008, 12:44 AM | #817 |
Chevy's Rock!
Incredible build FF... You are certainly a master of fabrication. I just wish that I could make a decent looking weld! Keep up the great work and I look forward to following along.
John '59 NAPCO Pickup '70 K10 Pickup 350 '72 C20 Suburban 350 (MIA) '57 Chieftain 455 '68 Firebird Convertible - 400 '68 Catalina Convertible - 400 '85 Vette |
07-15-2008, 12:50 AM | #818 |
chevy only
mike , nice work, dig your new shop also
CHEVY ONLY... Nothin Else ! |
07-15-2008, 04:58 AM | #819 | ||
07-15-2008, 07:31 PM | #820 |
Gettinlow & Goinfast
i wish i had that much clearance under my k5... i had to go with 2.25 pipe to fit. it was a sad day....
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas |
07-15-2008, 08:29 PM | #821 | |
Keep up the great work! Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
07-18-2008, 06:10 AM | #822 |
Time for some more pics.
The exhaust is all mocked up. I just need to pull it out and finish some of the welds, then hit it with some anti-corrosion coating and reinstall. The rear-most hangers also need to be installed, but it's 95% done. I got ambitious during the install and decided to run it all the way to the back. Good thing I have an over-sized notch (I knew I kept it full size for a reason ) I achieved my goal which was to keep it all above the main frame rails. The exception is in the very rear where it's still tucked up nicely and is above the lower portion of the fuel tank and higher than the lower body line. The only thing visible from the side is the tips of the turndowns I did open a big 'ol can of worms with this. Quite a few changes were/are required to make this work, but it'll be worth it. Fuel and brake line relocation, airlines need to be relocated (was going to switch to hard line anyway), Stock panhard bar mount on the pumpkin had to be removed/ground, and the biggest one being the rear shocks require a reconfig yet again. That's OK because I have another reason to do that as well that I'll show later. ...on to the pics! First the money shots, then the details: |
07-18-2008, 06:18 AM | #823 |
Cleaned up the pumpkin a little: Shocks will mount under the bridge instead of behind it: |
07-18-2008, 06:19 AM | #824 |
07-18-2008, 06:28 AM | #825 |
...and the other reason I want to relocate the rear shocks; I'll be running two rows of Buddy Buckets.
The second row will be just the two buckets and no center seat. That's the arrangement that fits perfectly between the rear tubs. Like this: ...and the reason to move the shocks (left one is up on seat tracks): |
