09-30-2011, 10:42 AM | #1 |
home made shop tools etc?
Is there a thread on here on home made shop tools,benchs etc on here,if not should start one
09-30-2011, 12:47 PM | #2 |
fat old dude
Re: home made shop tools etc?
id like to see this
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
09-30-2011, 09:55 PM | #3 |
Hand Crafted C-10
The only tool I can think of right off hand is too simple. Hopefully it will qualify.
I have a big chunk of Styrofoam I lodge over the hood release on my truck so I can climb in safely without tearing my jeans (and bum )…I’m kind of short and often have to sit right in the engine compartment to get anything done. I'm sure there's a zillion other things so I guess I'll be back here often to post... ...and learn new inventions... . Last edited by ETsC10; 09-30-2011 at 09:57 PM. Reason: ... guess I wasn't finished..:) |
09-30-2011, 10:19 PM | #4 |
I've been known to make jigs and stuff out of 2x4s. They're cheap and once I'm done, I'll break it down and reuse the wood. Lowes has some wood screws with torx heads that get reused.
Last summer I made a rotisserie for a gas tank that needed cleaned out and coated. |
09-30-2011, 10:43 PM | #5 |
Hollister Road Co.
I made a proportioning valve lock tool out of an set screw because I couldn't find them anymore. I have an old 9" South Bend that comes in hand for things like this.
10-01-2011, 02:11 AM | #6 |
fat old dude
needa have pics of lockdocs smooth cowl jig,
or Rokcrln cab dolly
10-01-2011, 08:15 AM | #7 |
My make shift door spring tool
10-01-2011, 10:32 AM | #8 |
here are a couple I found that looked interesting
10-01-2011, 04:06 PM | #9 |
I've got quite a few that my dad made, from before they were commercially available. I'll post 'em up as I can get pictures.
In the meantime, here's my homemade fixture for supporting my pickup bed for transport and paint - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-01-2011, 04:11 PM | #10 |
As an aside, the "trailer" should count as a homemade shop tool, too -
Dad and I built the trailer on the floor of the garage in 1967. K
10-03-2011, 08:02 PM | #11 |
I am a Referee of life.
I don't have a pic or time to clear the way to get one but my workbench was built from Kitchen cabinets.I used 4 3 w/doors and 1 with drawers.The doors are 2 ft wide and the drawers are 18".The top is made from 4 2X8's on a 1X4 frame(8ft long).I wanted closed storage beneath because my shop tends to be cluttered enough without open storage and the closed doors help keep stuff cleaner.I also used a couple of wall cabinets above it to store other stuff.The back wall is pegboard and the top is spanned by a 1X12(top cabnets are 12") with a 4ft flourescent light.I added 2 8ft flourescents where the original incadescent lights were.I have some open shelving and a folding table for additional space.Plugged a retractable shop light in at the plug for the door opener and mounted it to the support for the GDO.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-15-2011, 08:16 AM | #12 |
As promised, some pictures of homemade tools from my Dad's collection;
I mentioned he was a diemaker at Chevrolet for 26 of his 35 years with GM, so he had access to any kind of machinery or help imaginable. As a result he/they made a lot of tools that were either not available in the marketplace, or just because they could make them for free rather than having to purchase them. I hit the "mother lode" yesterday - Here are a few I found while I was unpacking: Homemade tubing bender, for bending 1/2" fuel lines - This is a good one. It doesn't look like much, but it is made from a turned down cap screw. The small end fits into a connecting rod (piston end) and you swing the rod past the weight on the crank. This is either to (a) ensure you have adequate clearance or (b) use as a fixture to grind the crank weight until clearance is acheived. I've done this at least a couple times. Homemade tool for pushing the rear axle pinion yoke off the pinion gear shaft (for those stubborn applications) - Fixture that emulates the bolt pattern of the exhaust side of a Chevy Big Block cylinder head, for use in fabricating header tubes - Pretty simplistic but still counts: a Drift pin for aligning bolts; I use this one for lining up suspension bolt holes for rear upper and lower control arm attachments - Homemade tool that keeps the flywheel from turning while torquing attaching bolts/torque convertor bolts/harmonic balancer bolts or installation. The beveled edge is placed in the ring gear teeth and it rotates until stopped by the bellhousing alignment pin or some other feature on the block/trans: Valve spring compressor for use when the cylinder head is installed on the engine. The cylinder is filled with compressed air and the locks can be removed to repair a seal, or replace/shim the valve spring - To be honest, I'm not sure what these are for. They were in the tool kit with all the rear end set-up tools. One of them looks like it might be for holding the pinion yoke to keep it from turning: Homemade bearing/seal installer (fits front wheel "dust cups" too, I believe) - Homemade slide hammer, for removing the rear axle ring gear/carrier after the caps are removed (for Pontiacs, which are a press fit) - This is the tool for checking pinion depth when setting up a rear axle. The round portions are held in the carrier saddle and then a depth gage is placed on the flat. The flat is machined to match the rear axle shaft centerline and the depth is measured from there to the rear face of the pinion gear (for Pontiac) - These are used to keep the pinion yoke from rotating, while torquing or removing the pinion nut and/or crushing the crush sleeve. The fork portion is bolted into the yoke, and then a piece of pipe is inserted over the end - Not sure what this is, either, but it was in with the rear axle tools and too cool to pass up - Homemade drift pin/punch, for whatever - I know there's more up at Mom's house, like a homemade camshaft degree wheel that's about 2 feet in diameter (made before they were commercially available). I'll shoot some pics the next time I'm up there. K
11-16-2011, 12:11 AM | #13 |
Hand Crafted C-10
Keep them coming!!
When I worked for Boeing, I had a whole drawer devoted to my own fixtures for things I needed to do ... if there was not the right tool made or it was too much trouble to ask for the right tool to use just one time (in their opinion). ...so I made my own. Your Dad did the same. and now more people can benefit. The wealth of information your dad gave you so you could even identify these tools is astounding! Please continue...I'm lovin' this thread! Last edited by ETsC10; 11-16-2011 at 12:11 AM. Reason: . |
11-16-2011, 12:59 PM | #14 |
I needed a tubing roller a few years ago when buildig a Targa top for a 1978 Camaro. I didn't want to pay what Eastwood or similar companies were wanting for a roller so I built this one. It's adjustable for different size tubing and has a bottle jack for tension on one of the outside rollers. I wanted the outside to push up instead of the inside wheel pushing down like most rollers are; this way the tubing curls up instead of down towards the ground. If you're making long, broad curves, the tubing will hit the ground if the roller curves the metal downward, mine doesn't have that problem.
Here's my homemade air drier. Used a dorm fridge, a 5 gallon bucket, and 20 feet of copper tubing coiled inside the bucket. It has a water trap on the outlet side and quick release fittings so it can be unhooked and moved easily.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-17-2011, 08:08 PM | #15 | |
11-18-2011, 04:35 PM | #16 | |
Here's a few more: The aforementioned homemade cam degree wheel: This is a homemade stand, used to hold a burette (like you might see in science class) while cc'ing cylinder heads: And, these are PVC pipe construction but are slipped over axle shafts during storage, to keep them from getting coated with dirt and fuzz:
12-19-2011, 03:11 PM | #17 |
Found a couple more.
This is a spacer, used as a fixture for widening a steel wheel. The length of the spacer corresponds to the final wheel width. We used to widen wheels by preserving the front half (thereby keeping the dimensional integrity between the wheel spider and the front face of the rim) and by cutting the back portion off the wheel. A new back portion, from a different wheel and with an additional 2", would then be fixtured to the front face/spider, using this spacer as a checking fixture. A small plate was affixed in four locations, allowing for minute adjustments of the donor portion. Once the radial and lateral runout are within spec then the two halves can be welded together. Here is a finished sample, a 10" Corvette rally with the front spacing preserved and the 2" added to the rear.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-19-2011 at 03:22 PM. |
12-22-2011, 08:55 PM | #18 |
This Bandsaw isn't mine but I used it when cutting my bed wood. I started with 2" thick pieces and cut them in half. With this monster you strap the wood to the guides and push the spinning blade through the wood rather than pushing the wood through the blade. Tons of fun, super loud.
Trevor "You already said spite" |
04-11-2012, 12:34 PM | #19 |
mines a cheap and easy.. but it really helped with my carpet and sound mat install...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? |
06-06-2012, 09:35 AM | #20 | |
Posted via Mobile Device |
06-12-2012, 12:06 PM | #21 | |
Just a nother gear head
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
08-02-2012, 12:50 PM | #22 |
here, just not logged in
I've been needing a third hand working on some stuff. So i made a stand for my vice.
I made some stakes to go through the lug holes so if i need it a little more solid i can stake it to the ground. Still not 100% if i'm going to use them or fill the base with ready-mix concrete. |
08-18-2012, 11:20 PM | #23 |
I made a frame for helping remove/re-install the box of a pickup truck:
It's pretty simple, although a bit large, but it works like a charm. I ran remove or re-install a box in 5 minutes by myself. I had to do something after I damaged my box a bit when I tried removing it myself with the skidsteer and some chains. This is another simple tool for helping cut holes in steel with a torch. Just a few large flat washers welded together. 3 different sizes welded together works out nicely. You always have it clamped to the steel so that the hole you want to use is raised up off the steel surface a bit. Then you put the torch in and simply use it as a circle cutting guide. It works, although finding the exact hole size you need may take a bit of trial and error, depending on your torch and how well you operate. Naturally, you won't cut a 2" diameter hole if the washer's ID is only 2". You would need slightly larger washers than the hole size you intend to cut. Of course I can't take credit for the washer jig, I found out about it because of a welder at work. He told me he learned about it years ago from another welder. |
08-19-2012, 10:22 AM | #24 |
Hand Crafted C-10
Great work tools ssapach. The bed jig looks like it would be handy for more than a few chores.
Oh...and Welcome to the Tool Forum! .
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
08-23-2012, 10:59 PM | #25 |
well mine is allmost like dragginmetal's only its a lil' more portable just a old broken vise that was welded and put back too use on a old engine stand. portable and very handy(kudo's too the kid for puttin this together)pay no mind too the p.w it was only in the pic.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
