07-21-2012, 01:17 AM | #1 |
chevy only
Re: My brides new ride
what a cool truck !!
CHEVY ONLY... Nothin Else ! |
08-26-2012, 03:31 PM | #2 |
more update
both door windows felts are gone as in nothing left of them plus both window reg are shot window won't go up & won't go down I got luck as in all the screws came out easy nothing was stuck or hard in pulling everything apart now I took both reg apart to see if i could save them but the RH- passenger all the parts were rusted so bad it was nothing budt dust on the LH-driver one the tooth was worn and even with cleaning & oiling it still would stick in the same spot
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
08-26-2012, 04:11 PM | #3 |
Tot Roddin'
Lookin' good!
But where's a pic of the truck and the owner.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-26-2012, 04:40 PM | #4 |
pic 42 you can see her shadow through the back window ( she's camera shy )
10-19-2012, 05:55 PM | #5 |
Few updates / replace the leaking 13 gal gas tank with a 20 gal & pickup-sending unit , replace the worn out manual steering box with a good used one ( capt fab hooked me up ) figured no pics were needed for these , replace the glove box and looked through everything and found the protecto plate and owners manual
went to a swap meet and picked up a air cleaner and valve covers
10-19-2012, 07:25 PM | #6 |
Who Me?
YOur off to a great start!!
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
11-13-2012, 11:03 AM | #7 |
Looks like you have a nice project going on. Thanks for the window weld info. I will keep that tad bit of info tucked away when I have to do mine.
11-13-2012, 11:30 AM | #8 |
duallyjams would you like to share where the vent window rubber, window channel and window felts came from? I replaced mine about 4 years ago and all the rubber is dry rot and vent windows are very hard to open....the bad thing about it is I havent fully enjoyed driving my project yet...
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
11-13-2012, 09:01 PM | #9 | ||
The wife has been using it for her yard work.
11-13-2012, 11:24 PM | #10 |
I'm just glad to be here!
Very nice. Where in Texas did you find this one?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-14-2012, 08:46 AM | #11 |
Amerillo on C/L
For some reason it was on cl for over a month with no interest , I got it for a lot less then what the asking price was.
12-22-2012, 05:50 PM | #12 |
Got all the gauges working except for the odometer and the speedometer would bounce so the only option left was to pull the gauge pod out.
think all this fine red clay dust had anything to do with it not working the nylon worm gears are worn out and one has a tooth missing fast forward got it back together and installed into the truck I added a vacuum gauge and did it exactly like chevyrestoguy write up in his thread http://67-72chevytrucks.com/vboard/s...=446527&page=3 starts at post 65
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 12-22-2012 at 05:56 PM. |
12-22-2012, 06:51 PM | #13 | |
"Oh well, it's a driver."
Added a tach as well, nice work!
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E Quote:
12-23-2012, 01:05 AM | #14 |
Looks fantastic.
Posted via Mobile Device |
12-23-2012, 02:28 AM | #15 |
60-66 Nut
Looks great
Did you paint the bezel or is it just bead blasted?
12-23-2012, 12:57 PM | #16 |
the tach is a repro
thanks I wish I had you welding skils It's painted , I went through three different colors of silver , still not sure if I like the color.
12-23-2012, 11:30 PM | #17 |
Who Me?
The new cluster looks great!
12-24-2012, 03:22 AM | #18 |
Hey.. where did you get that tool for the vent window rivets??
12-24-2012, 10:12 AM | #19 |
thanks
bought it from another board member it was kinda pricey not sure if I had to do it over again if I would buy one , look in the fact section Alan has a good write up on vent windows.
12-24-2012, 11:53 AM | #20 |
Everything looks great James!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-24-2012, 02:43 PM | #21 | |
Thanks , I start by reading through one of your threads to see how you did it.
01-19-2013, 06:10 PM | #22 |
Time to address the truck leaning to one side. The PO lowered the truck by heating the spring with a torch.
grinder , air chisel , little heat , rivets flying cut the spring to get it out but you can still what happens when you heat it up
01-19-2013, 06:18 PM | #23 |
I bought everything from NoLimit ( board vender )3" drop spring , 2" lowering blocks , shock relocator and shocks , panhard bar
old verses new This is some really nice stuff . The only problems that I had was me not paying attention. Thanks to Rob from taking time out of his busy day to answer my question and help me along. Went for a quick ride and it's a big difference in ride quality. Here is a thread about NoLimit parts http://67-72chevytrucks.com/vboard/s...d.php?t=477839
01-19-2013, 06:45 PM | #24 |
Lookin good Man!
09-29-2013, 04:45 PM | #25 | |
Live and let live |
