12-03-2012, 08:19 PM | #776 |
Re: Project: 1967 C10 Small Window
Glossy all the way!!!!!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
12-03-2012, 08:23 PM | #777 |
Decided on glossy just before you posted!
12-13-2012, 06:08 PM | #778 |
came home to this.....thanks Josh! It's just about there. Would y'all recommend spraying a few coats of automotive clear, followed by wetsanding, buffing, polishing, to get it looking like glass? I want to make sure it's compatible. He was also really busy with the bed and it's pretty close to being ready for red!
12-13-2012, 06:11 PM | #779 |
67cheby
Beautiful !
Posted via Mobile Device |
12-13-2012, 07:10 PM | #781 |
Sofa King Crazy!!
Is that Outdoor Spar Uerathane? Don't use auto clear on it. Looks great!!!!! If so wet sand it with 1200 to get slick then with 2000 grit, clean it then buff it. I used McGuires polish #1 cut and got great results after the buffing, wax it with some really good wax and buff it again then apply it by hand and just wipe it off. If you need help let me know!!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
12-13-2012, 07:19 PM | #782 |
Looking great! Can't wait to see it mounted in the bed.
12-13-2012, 07:34 PM | #783 | |
Thanks! |
12-13-2012, 08:41 PM | #784 |
I'm just glad to be here!
Bed wood looks great. Are you home on break now till January?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-13-2012, 08:42 PM | #785 |
Super nice...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-13-2012, 09:58 PM | #786 |
Nice, very nice, car show material.
12-13-2012, 10:51 PM | #787 |
Chevy Enthusiast
Looks awesome! Yeah I wouldn't spray automotive clear on top of that other stuff, it will do some neat stuff you're not gonna like.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
12-13-2012, 11:24 PM | #788 |
Looks awesome
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
12-14-2012, 01:34 AM | #789 |
David,
Love your truck and being that your a Aggie I thought you might like to check this out if you have not already seen it. |
12-14-2012, 03:41 AM | #790 | |||
Thanks! Thanks a lot! Quote:
Thank you! Quote:
12-14-2012, 09:29 AM | #792 |
Bed wood looks great David
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
12-14-2012, 10:08 AM | #793 |
Looks great! What is compatible is Epoxy! you can thin it down, spray it to get the build. Epoxy is also much denser and creates a harder surface. The only down side is you must spray Spar Varnish over it again as Epoxy is not UV resistant. You can then sand and buff without excessive yellowing from the Spar Var...
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
12-14-2012, 01:10 PM | #794 |
Looks awesome David! I wouldn't mess around with other finishes on there. What you've got now looks sick! Just my $0.02
How bout some bed pics!?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
12-14-2012, 03:13 PM | #795 | |
Thanks Keith
Thanks a lot, just want to flatten it out a little bit! Not much to see on the bed, but I'll try to get some pictures up later. Right now I'm bodyworking everything so there isn't much progress that you'd be able to see in pics. |
12-17-2012, 04:55 PM | #796 |
bodyworking a stepside bed is FUN............
We bolted up the fenders today in order to get the tops of the fenders and bedsides straight. Everything's looking really straight right now and they'll probably come off today and get hit with some more high build. When it comes apart, it's probably not going back together til it's red! |
12-17-2012, 05:39 PM | #797 |
It's looking like a truck! Nice work boys!
12-17-2012, 05:45 PM | #798 |
Looks great, shouldn't be long now....Jim
12-17-2012, 09:05 PM | #799 |
Looks good. Hope the weather holds out for you while your off from school.
12-17-2012, 11:41 PM | #800 | |
Thanks!
Thanks not too much longer.. Quote:
Should be done with bodywork tomorrow.....hoping to get a final coat of high build on and maybe even the black sealer coat... Also going to try and buff and polish the wood. It'll show a little bit of grain which I like, but it'll be super slick. |
Tags |
1967, small block, small window, stepside |
