Old 01-26-2014, 11:34 PM   #201
swamp rat
swamp rat's Avatar
Re: Project: Shiro
Originally Posted by Bucks68 View Post
Questions for the day:
1. Anyone know if there are different tachometers for 6 and 8 cylinder trucks?
2. What is the capacity of the in-cab fuel tank?
Been fiddling a bit just to try and stay interested until the PB stuff gets here. Worked on the dash lights and fuel gauge today. Got some of the lights working and now others that worked before no longer work AHH!!! Swapped the gas gauge for one I had stashed and it goes to empty when powered up, but I'm not sure I have enough gas in it to register, only 4 gallons or so, hence the question above. Hope you are all having a wonder day.
My guess;
Yes
21 gal.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-26-2014, 11:41 PM   #202
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
Originally Posted by mahanian View Post
No, it won't be reading accurately, basically 75% of actual motor RPM.
I'm guessing someone bled the brakes without the little tool that holds the proportioning valve piston in the center. You will need to re-center it to get the brake light to shut off.
So basically the tach is usless... that's great, the hits just keep on coming!
I've heard about centering the piston, but I'm going to have to look into how to do it. Thanks for the heads up!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-26-2014, 11:51 PM   #203
GAc10boy
GAc10boy's Avatar
Re: Project: Shiro
Apparently my parking brake light stays on all the time as well. Let us know what you find out in fixing yours. Keep ya head up!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 01-26-2014, 11:53 PM   #204
mahanian
C10 addict
mahanian's Avatar
Re: Project: Shiro
I've had three 6 cylinder tach clusters, they are pretty rare but out there. It's not going to hurt anything to keep the 8 cylinder tach until you can swap it out.
The attached pic shows you how the tool works. You have to open up the end of the valve and push the piston back to the center position. Pull the brake switch so you can watch and see when it is centered
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 01-31-2014, 06:35 PM   #205
C10_ustacould
Re: Project: Shiro
Got a shipping notification from UPS... looks like some parts are beginning to make their way from Apache Junction to my little garage. Probably just front and rear coil-overs, which actually come from Indiana, but I am stoked to start receiving parts from our friends at Porterbuilt.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-31-2014, 06:37 PM   #206
Rusbuilt
Rusbuilt's Avatar
Re: Project: Shiro
Sweet!!!
Rusbuilt is offline   Reply With Quote
Old 01-31-2014, 08:20 PM   #207
Bennett68C10
Bennett68C10's Avatar
Re: Project: Shiro
Awesome news, always love getting new parts
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-01-2014, 06:47 PM   #208
C10_ustacould
Re: Project: Shiro
Pro Performance has a Boyd Welding fuel tank group buy going on for us, but I think I'm going to have to miss out. I thought I had my plan figured out, side fill through the marker light, but I really like the caps n2billet uses from crafty b (http://www.crafty-b.net/products/gas...e=pages&page=3). One of these caps would have to be mounted in the center to look right which negates participating in the group buy. Here is a pic of the one I like. Pic is courtesy of his web site... What say you??
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-01-2014, 07:21 PM   #209
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project: Shiro
Won't Boyd's Welding make you a "center fill" tank?
Keith
Convert to disc brakes.
Old 02-01-2014, 07:40 PM   #210
C10_ustacould
Re: Project: Shiro
Yep, just not in a group buy. I'm waffling back and forth on this. The side fill is slick, but Crafty b's caps are so freakin' cool!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-01-2014, 08:39 PM   #211
knomadd
knomadd's Avatar
Re: Project: Shiro
what's your ultimate plan for the truck? are you ever going to use the bed that would make the center fill a problem? Or would it never see it's bed used for anything and the center fill wouldn't be a problem, or even a cool conversation piece at a show?
If you plan on using the bed much, the center fill might not be the best option. I've got one, but it's nearly flush with the ribs in the bed floor, so a load wouldn't be an issue, unless I forget to fill it before loading the bed.
Good luck making a decision, both ideas are pretty slick!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-01-2014, 09:27 PM   #212
C10_ustacould
Re: Project: Shiro
C'mon Duane! Don't bring common sense into this!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-02-2014, 02:11 AM   #213
jmedero
jmedero's Avatar
Re: Project: Shiro
I'd say go for it. It looks trick.... And if common sense was going to be used this thread would not exist. Lol.
Oh I know where a 6.0 is at..... Call me if your interested.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 02-03-2014, 03:21 AM   #214
C10_ustacould
Re: Project: Shiro
Well said Juan! I'm not ready to buy an engine yet. You'll know when I am, I'll put the word out to see what is out there.
It's no secret that I am less than enthused about this truck at this point than I was when I purchased it. I have been struggling with what I want to do with this truck and what many others believe should be done with it. I know… I know, it’s mine so I should do what I want with it, right? Well, not so much. First, I value the opinions of some members due to their knowledge and/or successful builds which weighs on me. Second, if a truck has a significant configuration, or low miles for instance, then you’d like to honor that by not doing something irreversible to it. There are quite a few people that feel that way about this truck, and commented here and on Instagram about being true to the originality of the truck. I am coming to a crossroads where it will become a point of no return, a decision will have to be made, and I am becoming more comfortable with the direction I have chosen. This is not a Yenko Camaro or a pristine ’63 split window Corvette, so it will not be a shame to alter it, it will most certainly increase its value. (Especially the Porterbuilt parts!) This truck will likely need to be painted after the sheet metal is fixed and I’m thinking some GM 503 light green just may be in order… just maybe.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-03-2014, 03:03 PM   #215
GAc10boy
GAc10boy's Avatar
Re: Project: Shiro
Buck - Hate to see you struggle with the decisions on the truck but I'm confident you'll do the right thing for you and your son. Enjoy following this thread and look forward to seeing how Shiro progresses over the next few months.
And I love 503 light green! Wasn't that the color of your stepper?
- Robbie
Old 02-03-2014, 05:12 PM   #216
sduckworth13
sduckworth13's Avatar
Re: Project: Shiro
Buck, here is a frame that has some Porterbuilt stuff already done and another ad for some Porterbuilt tubular control arms.
http://reading.craigslist.org/cto/4280533689.html
http://huntsville.craigslist.org/pts/4300289888.html
Scott
sduckworth13 is offline   Reply With Quote
Old 02-03-2014, 05:37 PM   #217
knomadd
knomadd's Avatar
Re: Project: Shiro
If you put that filler in the bed, you can't cover it up! Just sayin'
-Duane
Old 02-03-2014, 06:09 PM   #218
Justin36
Justin36's Avatar
Re: Project: Shiro
Hey Buck. I have been kind of growing threw the same thing you have.. And my dad enlightened me in a way I haven't looked at it. Your truck has the original motor and that's awesome, but when your finished original motor or not, your going to have billet wheels and porterbuilt of which neither even existed when your truck was new ,, no one will be complaining that you ditched stock suspension or stock wheels.. As you said it isn't a yenko or a split window, have a matching numbers 6 cylinder means nothing in my book either anymore... So with that being said, do what you and your son like, because at the end on the day that's all that matters
Justin
Justin36 is offline   Reply With Quote
Old 02-03-2014, 10:50 PM   #219
preacher anthony
Thumbs up Re: Project: Shiro
X2
preacher anthony is offline   Reply With Quote
Old 02-04-2014, 01:53 AM   #220
C10_ustacould
Re: Project: Shiro
Me too, and yes the 68 was that color. I must admit that for me to say it will be green is presumptuous, I will talk to the boy and we’ll weave it into the plan. Honestly, repainting the exterior white would be the easiest thing, but we’ll see what he says.
Thanks for the links but I have a full Porterbuilt coil-over suspension on order, and hopefully just weeks out, so no need for any more suspension parts at this time.
About the only thing the my son will be carrying is drums (I love my band geek!) so not much to worry about there.
Originally Posted by preacher anthony View Post
X2
Thanks guys, I should highlight that my feelings of let's call it discouragement were fueled by more than just the configuration and low mileage of the truck. The condition of the truck took me by surprise. I expected to have just two rusty cab corners to deal with and unfortunately found more than that. It's nothing that can't be handled but I was not prepared for it which weighed on me a good bit and I honestly didn't know if I wanted to keep the truck. I feel fortunate to have the guys here on the forum for support and guys like Hart_Rod, n2billet, and lowlife99 in my corner to lend a hand or give advice. (I know… I’m such a name dropper!) Nate at Porterbuilt has also been awesome to work with, answering questions and offering opinions and advice to help make my project go as planned the first time. So, we are going to press forward, not looking back, to try and create a truck that will play a big part in my son’s high school experience. I am now looking forward to building the truck with my boy and also repaying all the great support we have here on the forum.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-04-2014, 07:54 AM   #221
Justin36
Justin36's Avatar
Re: Project: Shiro
I hope this helps too, your dealing with a great color to match back, we bought this solid truck, besides cab and rockers were rotten and the new owner replaced all the rust the cab and rockers were the same on both sides. You can do it! Whether you decide to paint the truck or not!
Justin
Old 02-04-2014, 11:07 AM   #222
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: Project: Shiro
Hey Buck cool plans for the truck. Have you thought about getting another frame to build with all the Porterbuilt stuff and engine swap...etc? You could keep the truck in its current state and take care of some of the body issues and minor stuff and still be able to enjoy the truck as is. I find alot of projects get put on the back burner and intrest is lost and are sold off. All the cruise nites kick off next month it would be a shame not to enjoy it before tearing it apart. Now if i can only follow my own advice....i tear everything apart as soon as i get my hands on it!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 02-04-2014, 11:57 PM   #223
C10_ustacould
Re: Project: Shiro
Thanks bro! I have thought about using another frame and I happen to have one lying around. I guess it must be the tiny bit of purist in me but I prefer to keep the frame with its original cab and such. That way the numbers on the title, VIN tag, SPID, and frame all match. As far as the cruise nights go, I'm not really interested in taking to any at this point. Honestly, I don't find it enjoyable to drive. The carb needs work the gauge panel lights are possessed, which bugs the crap out of me. I have a couple of small projects to keep me busy while I'm waiting for the rest of the PB kit to arrive. I am also lucky enough to have Hart_Rod just up the road so I can hitch a ride with him. I appreciate the advice and look forward to seeing what you bring to Cruisin’ the Coast this year.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-04-2014, 11:58 PM   #224
C10_ustacould
Re: Project: Shiro
Looks good!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-08-2014, 11:07 PM   #225
C10_ustacould
Re: Project: Shiro
We started replacing the vent windows and seals today. My son did very well and asked a lot of questions along the way, I'm very proud. The passenger side is done, we'll tackle the drivers side in the morning.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
