Old 03-20-2014, 04:52 AM   #476
K10mashup350
Re: How about some pics of Static Dropped C-10's
Well what I did to get that was went to my machine shop an Drew up a basic spring/axle perch but the only difference was that I had him cut it I had him make it up where the perch was also the 2" block as well, so it was a 2in1 piece
K10mashup350 is offline   Reply With Quote
Old 03-20-2014, 02:35 PM   #477
ivorton74
ivorton74's Avatar
U got any pics of it?...i got just flip brackets with gabriel air shocks in the back and 2 cut coils in front. Would like to go with 3 inch springs and spindles and 2 inch shackles
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 03-21-2014, 10:33 AM   #478
K10mashup350
This is the best I got of my "custom" perches with 2" block "built-in"
Old 03-21-2014, 02:20 PM   #479
tinydb84
tinydb84's Avatar
That looks a bit scary to me. Is it fully welded? It doesn't look like the rearend was cleaned prior to welding.
David
Instagram: myfabguy
Old 03-21-2014, 03:37 PM   #480
beckmand78
beckmand78's Avatar
You may want to take that axle out and reweld the perches without the rust. I've had bad experience with Welds+rust, they dont mix
69 c10, mild 350, TH400, LWB......Starting build 3/14
beckmand78 is offline   Reply With Quote
Old 03-24-2014, 02:27 AM   #481
freezmcnally
freezmcnally's Avatar
Originally Posted by 1978steven View Post
Love the stance, if you don't mind what are the drop specs?
what rims are those?
Every new beginning comes from some other beginnings end
freezmcnally is offline   Reply With Quote
Old 03-24-2014, 08:20 PM   #482
K10mashup350
No they are not fully welded there... But the rust in the area of weld was cleaned up with die grinder prior to the weld being put there.
The drop specs are approximately 5" front and 8"+ in the rear.
And unfortunately I don't know what rims they are they were on the truck when I bought it they are 15" though
Old 04-12-2014, 02:18 PM   #483
JonFrankMc
Originally Posted by JonFrankMc View Post
my '71 stepper. 2.5" drop spindles and 3" springs in the back. 275/60/r15 on all 4 corners. Perfect for what I was looking for.
Took a HUGE hiatus while playing with my TBSS. Drug the truck out of the garage and put staggered steelies on for better clearance upfront. Like the look, jury is still out on the hubcaps
JonFrankMc is offline   Reply With Quote
Old 04-14-2014, 11:53 AM   #484
Patina'd_402
Patina'd_402's Avatar
'70/C10/402/TH400.
Patina'd_402 is offline   Reply With Quote
Old 04-22-2014, 09:34 PM   #485
Robznob11
Robznob11's Avatar
here is mine and its gonna have to have new front tires. its to low for comfort!!! these are 225/50/15 im fixing to put 255/60/15 so we will see what it looks like. its kinda a balancing act caus Im pretty sure after the tire swap im going to have to trim fenders and maybe relocate hood hinges
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-23-2014, 10:17 AM   #486
Dobster
Thumbs up Re: How about some pics of Static Dropped C-10's
I would get a tire that is as tall as the back for a level look that fills out the front wheel well.
Dobster is offline   Reply With Quote
Old 04-23-2014, 12:07 PM   #487
knomadd
knomadd's Avatar
I'm not sure what your wheel specs are, but I've got 265's (although on a 22" wheel) on all four corners of mine, without rubbing problems. 255's should be fine, if your tires aren't too close to the fender now. If you're concerned about rubbing the fenders, you could always just go taller, not wider. Say a 225/75/15? Just a thought.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-24-2014, 06:16 PM   #488
Robznob11
Robznob11's Avatar
Lol my problem is not width its hight. I have a 235/70/15 rollers on there now and I have 1 inch from the top of the tire to the inner fender lip where the hinge bolts on. It may not appear so in the pics but it rides about where a truck would sit if it was bagged out with stock spindles. If I put bags on it I could lay my fenders on the ground.
LED TAILS
Old 05-06-2014, 01:55 PM   #489
Robznob11
Robznob11's Avatar
Wink Re: How about some pics of Static Dropped C-10's
ok here is an update! the fronts are now 255/60/15
LED TAILS
Old 05-06-2014, 03:54 PM   #490
knomadd
knomadd's Avatar
That looks much better!
-Duane
Old 05-06-2014, 11:06 PM   #491
Robznob11
Robznob11's Avatar
My measurements are 24" top of front wheel opening to ground, 27" on the rear, top of wheel opening to ground.
LED TAILS
Old 05-07-2014, 08:43 PM   #492
zibs71
zibs71's Avatar
Not sure if this is right forum
I have P295/50R15 on rear of my 71 C10 and P255/60R15 on the front I've looked everywhere and can't seem to find the idealistic drop? Does anyone have this setup or know of the best or most common drop. Thanks in advance for your input.
zibs71
zibs71 is offline   Reply With Quote
Old 05-07-2014, 10:57 PM   #493
Robznob11
Robznob11's Avatar
4/6 is good for ride , thats what I have with an additional 3" of body drop, my tires are close in size to yours. So what you see in my pics is 7/9 drop. If you don't have deep bs win the rear Rims your tires will rub you need 6.5 bs atleast for a 12 wide rear and that is on an early(narrow rear) you need 7.5 bs for a 70+ rear. With a 10 rim just subtract 2" bs =)
LED TAILS
Old 05-08-2014, 09:47 PM   #494
zibs71
zibs71's Avatar
Thanks Robznob11,
As I said I'm really a noob with all this suspension stuff so in saying that is 4/6 mean 4 inch drop in front 6 in rear¿ sorry for my ignorance on this. Would it be best to use lowering coils ? What is the best recommended coils or drop spindles¿ Can someone please explain this to me.thank you for all feedback .
zibs71
Old 05-09-2014, 02:05 PM   #495
68Stepbed
68Stepbed's Avatar
Originally Posted by zibs71 View Post
Thanks Robznob11,
zibs71
Early Classic enterprises is the only people I recommend to buy a 4/6 kit from. www.earlyclassic.com
If you want sports car handling then go with the Hotchkis TVS kit, but for a driver/cruiser, ECE all the way.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-18-2014, 12:38 AM   #496
King Cary
Drop and wheels make all the difference.
This is the work of member way2lo2 for a customer.
Badass as usual Boris!
I think this is the truck that sold on EBay Thursday for $36,000.
King Cary is offline   Reply With Quote
Old 05-18-2014, 08:39 AM   #497
Hart_Rod
Hart_Rod's Avatar
link?
Hart_Rod is offline   Reply With Quote
Old 05-19-2014, 01:10 AM   #498
King Cary
No link but I will see if I can find one. There is another black and white C10 on there in Vegas for $72,000...
Old 05-19-2014, 01:22 AM   #499
63chevyll
gets board easy.......
63chevyll's Avatar
Yo rob, nice stance and wheel combo.
63chevyll is offline   Reply With Quote
Old 06-01-2014, 09:48 PM   #500
NEWBIEC10
NEWBIEC10's Avatar
1.5 coils cut in the front and 2 " blocks plus jeep springs in the rear
NEWBIEC10 is offline   Reply With Quote
