07-01-2013, 10:37 AM | #26 | |
67-72 parts collector,…
Re: 5-lug Hubcap/Steelie Style Wheel Options
Not sure what your concern would be? The 5-lug steelies would be no different than a truck rally wheel. (since they were made for 71-87 trucks and 88-91 2wd burbs, that all came with disc brakes) The issue is when you have a 15" wheel with more than 4" of backspace. Ususally between 3.5"-4.25" BS you will need to trim the lower a-arm (in the balljoint area) to make them work with 2.5" and 3" drop spindles. The real concern is when people do a 6-lug disc brake conversion,... and try to use pre-'71 steel wheels that aren't designed to clear the disc brake caliper.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-01-2013 at 10:46 AM. |
07-01-2013, 10:48 AM | #27 |
C10 Club Tennessee
That's probably what he was talking about.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
08-19-2013, 12:03 PM | #28 |
I have a question that can probably be answered here. I am doing the disc brake conversion on my 64 and planned on running the 88-98 steel wheels and changing the rear to 5 lug but then I came accross some 5 lug steelies with the nubs that match the factory 6 lugs in the rear. I was wondering if I could run the five lug steelies with the nubs in the front and the original six lugs in the rear with a cap that would cover both centers. I know the originals have three nubs and the 5 lugs have four but I was thinking of running these.
http://www.ebay.com/itm/Chevy-Rally-...ht_1627wt_1161 or something like those. Not even sure if those would work. Sorry I know this isnt the 60-66 section but I found this thread in a search and didnt want to start another one. If anyone read all of that Thanks.
BaBaBooey BaBaBooey GO SPURS GO!!! |
08-19-2013, 12:07 PM | #29 | |
You would just need two spare tires,... if you plan on carrying a spare.
08-19-2013, 12:57 PM | #30 |
sounds like a plan. Not too worried about a spare. I only drive it very local and I'll keep the spares at home. Thanks!!
05-06-2014, 12:43 PM | #31 |
Can anyone tell me if these caps will mount to the 15x6 steel wheels and fit over the front hub on 71 C10. I have the stock wheels on my 71 5 lug and wanted to run spider caps but they do not fit over the front hub (at least the ones I can find). I cannot tell how tall these caps are from the picture. If anyone has any other suggestion that would be great. I have dog dish caps from cars and the original 71 caps but none give the look I want. The spider caps look great on the back but do not fit the front.
Well I am not tech savvy enough to make the image attach correctly. Basically I am talking about the 88-98 center caps referenced at he beginning of this thread. Thanks H[IMG] http://t3.gstatic.com/images?q=tbn:ANd9GcTa5sRPuENNjydtw8hzdzGgLGFZt2GkFimlfKv7kmCXNInSDyO8LEnfYzqv[/IMG]ELP Last edited by BC13; 05-06-2014 at 12:49 PM. |
05-06-2014, 12:49 PM | #32 | |
05-07-2014, 12:00 PM | #33 |
Neither of those is really a feasible option, thanks though.
07-27-2014, 10:50 PM | #34 |
I see American Racing has a "smoothie steel" wheel now. They weigh 25 lbs I wonder if that is less than a stock wheel.?
Size: 15x8 Offset: -6mm Backspacing: 4.251" Bolt Pattern: 5-127 Rec. Tire Size: 225/75-15 Weight: 25.4lbs. Finish: Chrome Plated Construction: 2pc. Welded Finish Warranty: 1 Year Manufactured in China http://www.tirerack.com/wheels/Wheel...All&sort=Brand Last edited by kitsbeach; 07-27-2014 at 10:51 PM. Reason: oops |
07-29-2014, 08:40 PM | #35 |
Not sure who makes these or where to find them but they are a must for my truck one of these days. Anyone know where I can find them?
07-31-2014, 10:37 PM | #36 |
What hub cap options do you have with the wheel master oem wheels? I think they have the 4 nubs like the gm wheel.
10-20-2014, 09:59 AM | #37 |
I want to pic up a set of stock 71-72 wheels for my truck and I noticed that this thread lists them as being 15" x 6.5" but I noticed on the 72 truck brochure it lists the size as being 15" x 6" with a 15" x 5" being "available". My truck is a 1970 but I am planning to add OEM size disc brakes up front and I'm looking to maintain a stock look. So before I start looking too hard I was wondering if the wheel is stamped 15" x 6" or 15" x 6.5".
10-22-2014, 04:12 PM | #38 | |
It'd be alot cooler if you did
I used to run these on my 78 in a 17x8 with NOS derby caps. They're on the Daily driver suburban now with 265s. |
12-18-2015, 01:25 PM | #39 |
PO3, "Chrome Hubcap", I believe. Nice retro look.
08-21-2016, 04:59 PM | #40 | |
Does anyone know if a standard 1/2t dog dish cap (10 1/8") will fit over the formed center of the series 12/13 Wheel Vintiques wheel? If the cap is large enough to fit over the formed area, I could add clips and install dog dish caps on a set of these wheels. I'm looking for the oe look of steelies and caps, but want a larger diameter wheel... 16" or 17". So far this is the only wheel I've found that appears to be an option, as the series 62 wheel only comes in 4.5/4.75 bolt pattern in the larger diameter.
Thanks, Miles Quote:
01-01-2017, 10:48 PM | #41 | |
01-07-2017, 09:36 PM | #42 |
70+ ( Old Skool Club )
I have a 1971 C20 Burb with the original 16.5 8 hole rims and the chrome hubcaps. I've seen threads that show folks replacing the 16.5 rims with 16 x 8 inch rims because tire choices are better. I though I read somewhere that you could use rims from newer vehicles to get the 16's. Does anyone know which vehicle I should look for to get a set of the 16 x 8 8 hole rims that my chrome hubcaps will fit.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-07-2017, 10:21 PM | #43 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=552307
01-16-2017, 05:17 PM | #44 |
Hey guys, Jegs has Wheels Vintiques 15"x6" bare 62 series on sale for $63 each. That's over 23 bucks less than Summit. They say smoothie on the site but the part number and pic show OE nubs for dog dish caps. I just ordered a set. http://www.jegs.com/i/Wheel+Vintique...FQ9Efgod2o8Brg
Romans 10:9 - The Truth Last edited by RDrancher; 01-16-2017 at 05:29 PM. |
01-27-2017, 03:42 AM | #45 |
Collector of Projects
Does anyone know the right offset for 18x8 on a 1978 2WD Blazer with a small drop... I was looking at either Mob Steel or Wheel Vintiques...
05-29-2017, 02:09 PM | #46 |
have to stay in touch with this thread, great info.
Just help to some, I just ordered my trail gear 1" toyota spacers/adapters from summit this after noon to mount my 22" transports onto the factory drum/drum setup on my 67 C10. Buddy says they work mint and no clearance issues either and fills the fenderwells a bit better. He has done 2 or three now. Will try and remember to post my results. No spacers will rub the frame on the front and believe the axle center is to small on the rear axles to fit the hub centric hole.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
09-27-2018, 08:51 AM | #47 |
Subscribed to this for some GOOD wheel info.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
04-02-2022, 11:03 PM | #48 |
The Older Generation
Bumping this back to the top. LockDoc
04-03-2022, 08:31 AM | #49 |
Great info!
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
