#26 | |
Re: LS SWAP 4l60e problems
I am using Valvoline Dexron III... Should I think about using something else?
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
#27 |
Good to hear you got it straightened out. Good info on the issue too.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#28 | |
Valvoline Dex/Merc is a good conventional ATF. I didn't want to recommend draining a expensive Group IV synthetic ATF if that's what you were running. |
#29 |
Lol Cline I was waiting on his answer too before recommending a drain and fill. You pockets empty fast with a synthetic!
#30 | |
I know a lot of shop have a trans flush machine now a days, and it can clean out the trans, converter and trans cooler all in one shot, plus it likely be a half hour to hour labour at most shops. |
#31 |
meowMEOWmeowMEOW
The only thing I've ever seen a flush do is push out the remaining good seals, find every leak you have, and ensure that you'll get upsold by the tranny shop. They fall into the category of convenience services I don't trust, performed by people who shouldn't be near my truck.
If everything was brand new, and there was a reason to think something physically was clogged, then I might say yes. But on a trans with more than a couple miles on it I stay away.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#32 |
![]() Join Date: Apr 2005
+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#33 | |
