01-21-2015, 01:15 AM | #1 |
Brand new LSX376 crate motor with extras
SOLD
http://www.chevrolet.com/performance...sx-376-b8.html 19171049 Replaces the 19171049 LSX376 450HP The LSX376-B8 is designed for lower-boost applications, up to about 8 pounds. That’s suitable for most supercharger and turbo kits that are designed to be used with production-based applications. GM Performance Parts takes the economical LSX Bowtie block and combines it with the LS3’s high-flow L92-style heads and mostly internal components (we swap the pistons for forged parts), to create the affordable, high-revving LSX376 crate engine. It represents the essence of LS performance—exceptional airflow capability in straightforward packaging that delivers huge performance without a power-adder. We deliver the LS376 without an intake manifold (and other accessories). So, whether you top the engine with a carburetor or production-style injection system, it’s suitable for your street rod, ’57 Chevy or ’71 Camaro —be it on the street or strip. Our horsepower and torque ratings are based on using the productionstyle injection system. More power can be realized by swapping that for one of our carburetor intakes and a well-tuned Holley four-barrel. NOTE: Due to the number of application variations, the LSX376 crate engine is supplied with a dust shield instead of an oil pan. See the LS Engine Components section for production-style oil pan choices. Also, the LSX376 valve covers do not include provisions for mounting the ignition coil brackets. Aftermarket or custom relocation brackets must be used. LSX376 TECH SPECS Part Number: 19171049 Engine Type: LSX Series Gen IV Small-Block V-8 Displacement (cu in): 376 cu in (6.2L) Bore X Stroke (in): 4.06 x 3.62 (103.25 x 92 mm) Block (P/N 19243171): LSX cast-iron with 6-bolt. cross-bolted main caps. Crankshaft (P/N 12597569): Nodular iron Connecting Rods (P/N 12607475): Powdered metal Pistons (P/N 12166957): Forged aluminum Camshaft Type (P/N 12603844): Hydraulic roller Valve Lift (in): 0.551" intake / 0.522" exhaust Camshaft Duration (@0.050 in ): 204deg intake / 211deg exhaust Cylinder Heads (P/N 12615879): Aluminum L92 style port, with "as cast" 68cc chambers Valve Size (in): 2.16 Intake / 1.59 exhaust Compression ratio: 9.0:1 Rocker Arms (P/N 12569167 int): Investment-cast, roll trunnion Rocker Arms (P/N 10214664 exh): Investment-cast, roll trunnion Rocker Arm Ratio: 1.7:1 Recommended Fuel: 92 octane Maximum Recommended RPM: 6600 Retuctor Wheel: 58X Balanced: Internal OTHER PARTS INCLUDED IN PACKAGE: LSX-LS3 dual plane intake manifold. #19244037 Muscle car pan kit. #19212593 Coil kit. #19257878 Wire for coil kit. #12601824 LSX Ignition Module. #19171130 Front accessory drive W/O A/C. Holley Ultra Double Pumper Carb. # 0-76650BK Holley HP125 Fuel pump. #HY-12-125 Holley Fuel Filter. #HLY-162-553 Earl's Pro Lite 350 fuel hose. #EAR-352008ERL Earl's Fuel line carb kit with pressure guage. #EAR-AT101295ERL CPP LS Motor stands and mounts porwder coated black. Price WITH shipping. $6700.00 to business or hold at terminal. Will be extra charge for residential and lift gate service if needed. Price PICKED UP. $6400.00 Last edited by 1968Mann; 01-31-2015 at 04:17 PM. |
01-21-2015, 01:29 AM | #2 |
Re: Brand new LSX376 crate motor with extras
pic
01-22-2015, 11:13 AM | #3 |
great price!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-24-2015, 01:53 PM | #4 |
What brand of accessory drive kit does it have? You have pictures of it?
Kirk 72 Blazer CST 4wd highlander 66 Nova |
01-24-2015, 01:59 PM | #5 |
01-24-2015, 06:58 PM | #6 |
Pics for blazerowner.
01-24-2015, 09:03 PM | #7 |
I'll have to stew on it but it is Close to what I want.
01-24-2015, 10:33 PM | #8 |
01-29-2015, 12:57 AM | #9 |
Hmm- I might just have to break open the piggy bank for this.....
01-29-2015, 01:11 AM | #10 |
01-29-2015, 01:18 AM | #11 |
Do you have the engine mounts as well?
01-29-2015, 01:33 AM | #12 |
