Old 01-04-2016, 01:42 AM   #526
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by Advanced Design View Post
That is very clean! What are the 10 relays controlling?
Thanks AD Well first I'm not using the key to start the truck. I'll take a pick of what I'm using. So top 5 relays are: IGN any thing I want powered with key: Amp, 12v power plug ect. Glow plugs, Left and Right door poppers, spare. Bottom 5: Starter, Lights, Fuel: anything related to motor running: fuel pump, Efan ect, ACC: all the secondary parts of truck running like transmission controller, gauges, ect. Then my heater. I am using a 30A electric heater 6000btu instead of coolant. Hope that makes sense.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-04-2016, 02:55 AM   #527
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by Chance48 View Post
I need to learn a lot about this stuff. Why use relays in place of fuses? If a relay is a switch, what is the difference in powering a box full of fuses with one switch(key switch) or using a bunch of relays with fuse links? I need some quick education. I'm googling what I can but there is nothing specific to auto, or explanations of what and why? I'm kinda dude that needs to know why I'm doing something. Any of your help would be greatly appreciated.
Chance
So a relay powers another circuit from an existing circuit. Why not just have a separate circuit for what ever that relay is running with a fuse for it? Is this to reduce the amount of fused circuits?
Is this why some vehicles have two fuse boxes? Fuses protecting relayed circuits?
I understand the solenoid. So there are different size relays(amperage)? Lowers, I'm sorry to beat your thread like this. I'm trying desperately to wrap my brain around this. I know nothing besides bare basics of auto wiring. Everything besides relays, haha. Which I'm getting the idea that they are an important an necessary part of the system. I've never had a relay go bad, never even had to think about a relay, I'm ashamed to say, I guess.
So say I want to wire in an e-fan. How would I use the relay or wire this setup up using a relay I should say? Thanks for the help.
Ok, lol...I got all nervous when I seen all those relays. I you tubed my butt off and got a general idea of it and how to wire them. As usual, I'm a long ways away from this in my build but the wiring is one of my largest concerns and gets me worried. I learned a lot tonight and my kind is at ease for now.
Chance
Sorry for the delay Chance. No I'm not using relays instead of fuses, I have 20 fused circuits. So most 12v switches are rated for 10A-20A I don't like putting 10A through a 10A switch. More like 2-5A through a 10A switch. So in comes a relay, much easier to change a relay too. A relay uses a small amount of power say 2A to switch a larger amount of power say 30-40A in a typical cube relay like what I'm using. Same as the starter solenoid on a car say 5A to spin your 300A starter. I am using more relays than I need to, partly because of how I am turning the truck on and part because overkill doesn't hurt. Don't worry about the wiring ask me or any other of the guys on here anytime. Hope that helped. Bob
1951 MG TD
Old 01-04-2016, 08:57 AM   #528
Chance48
Re: My 52 GMC Build
Thanks lowers, I've been on a research mission and studied up, a lot! I will need help and will be asking, thanks man.
Chance
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 01-04-2016, 11:57 AM   #529
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Re: My 52 GMC Build
Originally Posted by lower50's View Post
No I'm not on Instagram and I have not seen it. Please post
Here you go... posted by stanceiseverythingcom
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 01-05-2016, 03:34 AM   #530
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks John
This is my starter sw. I built it out of the original cable leaver that actuated the 2 speed rear end that my truck had originally. Now you just push and it actuates the sw under the dash.
These switches will be to turn the truck on. Upper hole will be for headlights.
1951 MG TD
Old 01-05-2016, 04:32 AM   #531
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Thanks Lower, it does make sense. I like the concept and flexibility it gives you as well as diagnostic / repairability if needed. No searching all over for a relay.
The starter button is way cool....reminds me of some of our heavy equipment starting.
Advanced Design is offline   Reply With Quote
Old 01-05-2016, 07:06 AM   #532
Katrina/10
Katrina/10's Avatar
Re: My 52 GMC Build
I'd like to see some more info on your heater when you get to that part.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-05-2016, 08:37 AM   #533
Chance48
Re: My 52 GMC Build
Nice, I like that starter button. And...I'm interested in your heater option also.
Old 01-07-2016, 12:24 AM   #534
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Here is the heater I am using. It is 6"X 4"X 5". Since the truck will be a spring, summer, fall truck I mainly need it for defog the window. I will be making up some ducting for the end of it to attach the defroster tubes. I think it will be mounted by the fire wall on the trans hump. Nice thing is I can put it anywhere.
http://www.my12voltstore.com/12_Volt.../sa12-3000.htm
1951 MG TD
Old 01-07-2016, 12:26 AM   #535
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Tonight I got the electrical panel mounted to the fire wall
1951 MG TD
Old 01-07-2016, 01:24 AM   #536
joedoh
joedoh's Avatar
Re: My 52 GMC Build
clean wiring is a joy to troubleshoot!
Old 01-07-2016, 11:35 AM   #537
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
that heater looks awesome, def something to think about. Let us know how it works and sounds. I spent hours routing my heater hose and getting coolant all over me. 1st heater/ac unit I had was garbage, so I had to replace it. Ever since I hooked up my heater I now can't seem to get an air pocket out of the system, either that or ironically my temp gauge is malfunctioning. anyway, I like the fact that this is a USA brand and they have some confidence in their product.
Nice panels
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-07-2016, 11:54 AM   #538
Henney
Re: My 52 GMC Build
Lookin killer. What's on the far left of your electrical panel? Are you planning to put a cover over it?
Henney is offline   Reply With Quote
Old 01-07-2016, 04:48 PM   #539
Jay92
Jay92's Avatar
Re: My 52 GMC Build
Excited to see this truck out and about this summer! I had a shop in Breslau (beside the airport) up until April when I moved to London.
Jay92 is offline   Reply With Quote
Old 01-07-2016, 05:37 PM   #540
RockinKees
RockinKees's Avatar
Re: My 52 GMC Build
That looks really clean!
Now I know for sure I have to make a new fusepanel....
Nice little heater too!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-07-2016, 07:10 PM   #541
47 Fasttoys
47 Fasttoys's Avatar
Re: My 52 GMC Build
High quality looking job on the wiring Lower. Make that 3X or 4X on the heater deal. The one in my '46 is a POS and I'm looking for an original to rebuild or a quailty alternative.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-07-2016, 10:50 PM   #542
65sub
65sub's Avatar
Re: My 52 GMC Build
Great heater idea. I'll save that site for later
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-08-2016, 01:06 AM   #543
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Nice panels
Ya since my exhaust is in the way of any stock heater, I was looking aftermarket anyways. I hooked it up when I got it. I'd say it works similar to the high low of a 110V house heater for heat. Fan was quiet and moved a good amount of air. I would recommend so far.
Thanks. Far left is my glow plug relay timer, usually on the motor. I'm thinking I will put some smoked lexan over the lower portion.
Oh it will be out and all about.
Thanks Kees
Rob
Thanks 47
Thanks I figure for the small amount of time it will be used, it's a much better option. Also I have a rebuilt 110A altinator.
1951 MG TD
Old 01-08-2016, 08:55 AM   #544
Chance48
Re: My 52 GMC Build
Ah sweet, that heater should heat that cab fine if it's sealed up good. Wiring looks legit. I'm still being a puss just thinking about my wiring, haha.
Old 01-09-2016, 09:41 AM   #545
Katrina/10
Katrina/10's Avatar
Re: My 52 GMC Build
Thanks for the link on the heater, I think it may work for me. A few years ago, I bought one of those heaters that plugs into the cigarette lighter, and it put out very little heat.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-11-2016, 06:30 PM   #546
lower50's
lower50's's Avatar
Re: My 52 GMC Build
N.P. They have different sizes so what ever will work.
1951 MG TD
Old 01-11-2016, 06:46 PM   #547
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Wow wiring takes forever and you don't get much to show for it. On Friday I made a new glow plug wire harness. Took 2.5 hrs for basically a piece of 8ga wire with 8 bullet connectors. Today I made the wire harness for the front of the motor: fuel on, tps, temp, alt.
1951 MG TD
Old 01-11-2016, 07:35 PM   #548
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: My 52 GMC Build
Attachment 1486841
So true, and making it neat takes even more time! Looking good, though.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 01-11-2016, 11:38 PM   #549
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
I can firmly back you up on that wiring takes forever. Looming all the wires, heat shrink and making it neat. 60 hrs into a full custom wire job with bags isn't far off.
Old 01-11-2016, 11:40 PM   #550
Chance48
Re: My 52 GMC Build
Lookin good man!
bagged, build, diesel, gmc, hot rod
