Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-08-2016, 09:55 AM   #51
Coursey
Coursey's Avatar
Re: Just picked up this 1966 Suburban
I have been working on getting the burbs rear end down. Installed c-notch, adjustable track bar, shock relocators, KYB shocks, and working on getting the Accuair Elevel installed.
Working on installing the ride height sensors now.
Coursey is offline   Reply With Quote
Old 02-08-2016, 10:11 AM   #52
smbrouss70
smbrouss70's Avatar
Man, that's a good looking Burb!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-08-2016, 10:54 AM   #53
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks good!
Keith
Convert to disc brakes.
Old 02-08-2016, 03:23 PM   #54
lowbuck
Nice shop,the ride height look great the way it was.Very nice suburban.
lowbuck is offline   Reply With Quote
Old 02-08-2016, 04:02 PM   #55
Coursey
Coursey's Avatar
Thanks low buck. That is actually full drop. Wish it would ride that low, but would have to full inner fenders and big notch.
Old 02-08-2016, 04:27 PM   #56
chase@ridetech
chase@ridetech's Avatar
I have Ridetech's controller on my blazer and it's never worked correctly.
The preset air pressures were never reached.
I run it in manual.
Give me a call if you are having any issues on your Ridetech parts, I would be happy to get it worked out.
My Direct line is 812 481 4736
Chase
chase@ridetech is offline   Reply With Quote
Old 02-08-2016, 09:35 PM   #57
Nobby
Nobby's Avatar
Looks Great Man !!!!
Nobby is offline   Reply With Quote
Old 02-10-2016, 10:28 AM   #58
Coursey
Coursey's Avatar
This is how I was mounting the front sensors.
Old 02-10-2016, 09:47 PM   #59
Advanced Design
Advanced Design's Avatar
Burb looks great!
What are the sensors mounted with?
Advanced Design is offline   Reply With Quote
Old 02-11-2016, 08:03 AM   #60
Coursey
Coursey's Avatar
Small 2.5" bolt with a 3/4" long coupling used as a stand off with a lock not on back. Seams very solid.
Old 03-05-2016, 12:54 PM   #61
Coursey
Coursey's Avatar
Pulled it out of the shop to let the elevel calibrate!
Old 03-05-2016, 12:59 PM   #62
Coursey
Coursey's Avatar
Had an issue pop up when i backed it out the steering box started leaking around the end.
I am unsure if this is a 1966 or 1985 box?
The front rack is off of a 1985 c10, so i am unsure about the steering box.
It has 85 stamped into the end. Not sure if this means 1985 or something else.
Old 03-05-2016, 02:06 PM   #63
smbrouss70
smbrouss70's Avatar
I don't think they had a power steering "Box" in '66, it was a steering assist ram. See if the fittings are metric, and if they are, go ahead and use an '85 box.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-05-2016, 07:14 PM   #64
Advanced Design
Your Burb is a beauty!
Old 03-11-2016, 03:54 PM   #65
Coursey
Coursey's Avatar
Road side gas stop!
Old 03-11-2016, 03:56 PM   #66
lolife99
lolife99's Avatar
Looks great!
Keith
Old 10-24-2017, 10:31 AM   #67
Bennett68C10
Bennett68C10's Avatar
Just stumbled across your thread, beautiful truck. Love the stance of it, mine will have a similar stance when i get done with it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-24-2017, 10:33 AM   #68
Coursey
Coursey's Avatar
Thanks. I actually sold this one the first of the summer. It went to a guy down around Atlanta, GA.
