Old 04-07-2016, 09:59 PM   #501
Advanced Design
Advanced Design's Avatar
Re: My suburban's Twisted Little Sister
Stretch, chop, continuing nice fabrication Dale. You must be in the shop about every day.
Advanced Design is offline   Reply With Quote
Old 04-07-2016, 10:10 PM   #502
62stepside longbox
62stepside longbox's Avatar
Awesome job! Whenever I need inspiration for my build I come over here and watch you build this masterpiece
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-08-2016, 02:18 AM   #503
Bomp
Bomp's Avatar
Making it look like nothing ever happened.
You know you're making me work at being better on my build now.
Bomp is offline   Reply With Quote
Old 04-08-2016, 03:58 AM   #504
Grizz1963
Grizz1963's Avatar
And that is why we come on here to get inspired.
Not just the learning, but also pushing our own boundaries and expectations.
That tailgate looks amazing from sitting here in the comfort of my kitchen at the table having breakfast
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-08-2016, 03:39 PM   #505
AJCK87
I'm partial to the barn door set up, however your are killing it with the look on that clam shell! I'm convinced. Nice work
AJCK87 is offline   Reply With Quote
Old 04-10-2016, 03:34 PM   #506
65sub
65sub's Avatar
Thanks Doug. We work it on pretty steady when life doesn't get in the way.
Thanks Nik. Glad I can help but I expect your determination would get your truck built without any help from me.
Thanks Greg. I'm happy our little adventure can be of some help to you.
You're right Rian this forum is a gold mine of knowledge and inspiration and I mine it like an old time prospector.
Thanks AJ. I prefer the barn doors as well but I used the clamshell gates for two reasons. First, it fits the opening I have left and second I'm mostly using left over parts and the clamshells are leftovers.
After we shortened the sides of the upper gate it left a 5/8" gap at the bottom so we tacked in a filler piece. Then we cut the bottom inch off for later use. Next we mounted the upper gate on the truck The last thing we did was cut off the top section of the lower gate (the piece with the latch in it) and clamped it to the back wall of the truck.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 04-11-2016, 07:51 PM   #507
65sub
65sub's Avatar
We spent most of today removing the skin from the top half of the lower gate. The gate has 4 braces inside that are spot welded to the inner panel and the spot welds are nearly impossible to find. After we got the sheetmetal off we placed it on the truck to see what needs to be trimmed.
Dale
Old 04-12-2016, 07:37 AM   #508
lower50's
lower50's's Avatar
OH YA that is going to look great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-12-2016, 10:39 AM   #509
62stepside longbox
Nice work, it's starting to come together
Old 04-18-2016, 08:21 PM   #510
65sub
65sub's Avatar
Thanks Lower
Thanks Nik
Last week we found that the upper gate hinges were to loose so we spent a couple of days making new pins for them. Today with the rebuilt hinges installed we finished trimming the two halves of the gate. Then we tacked the lower half to the truck so we would have a stable piece to work with. Next we carefully aligned the panels and tacked them together inside and out. Then we cut the tacks holding the bottom half to the truck and tested the new extended gate.
Dale
Old 04-18-2016, 09:41 PM   #511
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Looks great Dale! The chop is really noticeable when looking at the height of the window opening. Cool
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 04-18-2016, 10:18 PM   #512
CRGRS 66
CRGRS 66's Avatar
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-21-2016, 08:37 PM   #513
65sub
65sub's Avatar
Originally Posted by CRGRS 66 View Post
Thanks guys. The rear window is only chopped 2.5" compared to 5" on the sides because it was short to start with.
We got the top of the lower wall tacked on. Then we filled the gaps at each end. And after a bunch of time hammering dents and trimming the edges the licence plate recess is ready to tack in.
Dale
Old 04-21-2016, 09:03 PM   #514
Really enjoying you project. Love your ideas and the magnificent metal work pulling it together.!
Palf70Step is online now   Reply With Quote
Old 04-21-2016, 11:14 PM   #515
lower50's
lower50's's Avatar
Like your tail gate sticker says (Kick ass) Do you have a plan on when the burb will be done?
1951 MG TD
Old 04-22-2016, 12:08 AM   #516
62stepside longbox
The work you are doing is great Dale, this is got be the craziest build to ever exist
Old 04-23-2016, 09:04 PM   #517
65sub
65sub's Avatar
Thanks Bill. We're having a lot of fun building it so I' m glad you and others enjoy reading about it.
Thanks Lower. I'm terrible at estimating timelines but I would guess 2 years.
Thanks Nik. That sets the bar pretty high but we'll do our best.
Yesterday we continued work on the licence plate recess.. We made a 6" diameter tube to connect the inner and outer panels. We also added a 1.5" strip to the bottom. Then we tacked the recess panel in place.
Dale
Old 04-24-2016, 02:11 AM   #518
Grizz1963
Grizz1963's Avatar
...... Tell you what Dale
People out there who come to shows and look at completed or "rat" trucks and cars really have no idea of the amount of time and work that goes into these builds.
A "simple" job like the plate recess and tube you posted up above has to take a few hours to complete.
Then there is all the planning and thinking that goes into it. I often laugh at people who just cannot plan and see the end product toward which they have to work, it has to be tough for them.
For the first time in 25 years working in the medical field, I have a manager who rides a motorbike and has changed engines before, knows how to change a flat wheel, so one who would understand the work you do. Often it is real difficult to try explain what goes on in my world, sharing this sort of thing, and mostly I have given up trying to explain to them. However, your last post will be shared as I am again so impressed. Reminded that these things don't just fall together over a weekend.
Looking good.
Old 04-25-2016, 08:39 PM   #519
lower50's
lower50's's Avatar
You are so right Grizz
1951 MG TD
Old 04-25-2016, 08:53 PM   #520
65sub
65sub's Avatar
Looking good.
Thanks Rian. I'm pleased your job situation is working out so well. It's alwys nice to have coworkers that can understand the effort that you put into your hobby. You're definitely right that these projects don't fall together in a few days. The back of this truck has taken several weeks of work.
After a bunch of trimming and some POR15 we got the bottom sections of the upper gate ready to attach. We got the first one tacked in place to check the fit.
Dale
Old 04-25-2016, 09:06 PM   #521
Advanced Design
Dale, the back end is looking really good. Imaginative design coupled with impressive fabrication skills is really fun to watch and learn from.
Old 04-27-2016, 09:29 PM   #522
65sub
65sub's Avatar
Thanks Doug. I'm quite pleased with the progress so far and we're having fun building it too.
We installed the second half of the upper gate bottom then added some filler strips to fill in the gaps. There was one other adjustment that needed to be made. The striker on the lower wall no longer lined up so we shifted it over 11/16" and tacked it back in.
Dale
Old 04-28-2016, 01:44 AM   #523
Grizz1963
Grizz1963's Avatar
And that striker Dale, is what it's all about.
Making stuff work just right.
Loving it.
Old 05-01-2016, 09:27 PM   #524
65sub
65sub's Avatar
Loving it.
Thanks Rian.
I had an idea recently on how to modify the hood. We're going to try pie cutting it by slicing it on the body line on the side. so to start we drilled the spot welds at the front and removed the front brace and the front piece of the hood.
Dale
Old 05-02-2016, 09:47 AM   #525
lower50's
lower50's's Avatar
Looking forward to seeing what you do with the hood!
1951 MG TD
