Old 05-08-2016, 07:40 PM   #1151
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Originally Posted by lower50's View Post
I totally agree Doug. Connecting with other old truck lovers, helping, sharing. Everyone on this forum is so positive, love it.
Keep up the good work.
Lower, you are so right. We can connect around the world and help or encourage each other. Kees in the Netherlands, you in Canada, Marc in Michigan. All good.
Speaking of connecting, we need to keep those folks impacted by the fires around Fort McHenry in our thoughts and prayers. Members here have lost all possessions. Check out the general discussion area if you haven't.
Lots of yard work with the wife between rain storms so only had a little shop time Sunday afternoon. Finished the trans crossmember mount and moved to notching the crossmember the drive shaft would hit when aired out.
Rummaged through neighbors collection and swapped for some large diameter pipe.
Advanced Design is offline   Reply With Quote
Old 05-08-2016, 07:44 PM   #1152
Advanced Design
Marked out the cut for the pipe notch. And yes, my plasma cutter is in a little red wagon.
Cut out the notch, threw the drive shaft back in then raised raised the rear to the bump stops to check clearance.
Old 05-08-2016, 07:50 PM   #1153
Advanced Design
The notch worked, the plasma sliced like going through butter, the pipe section fit and the welder burned in wire very smooth. This was all a rarely achieved zen like state....hmm...
Next week end should be back on the exhaust.
Old 05-08-2016, 08:32 PM   #1154
Valarius_Starchaser
Valarius_Starchaser's Avatar
Nice work Doug I too find a rare occasion where all of my efforts go well and smooth but when they do they sure do work
I agree with your words on the fires my Fiancé has family from there who is directly impacted and are currently displaced and have no idea if their home is gone. It makes you think of how fragile and fleating a lot of our "prized possessions" for now all we can do is pray for wisdom of the men and woman fighting the fires and for rain and lots of it to stem the flames
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 05-08-2016, 10:29 PM   #1155
youngrodder
youngrodder's Avatar
The notch looks good Doug. Nice work....
Late Sunday was good for me to get in a little garage time as well..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-09-2016, 09:46 AM   #1156
Coach529
Coach529's Avatar
Great looking notch. It sure is fun when it all goes good.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-10-2016, 10:00 PM   #1157
rkn463
rkn463's Avatar
Hi AD,
I've been reading this thread for a week now since you posted on my c50 build. I wish I had your body working skills, you do great work! I've always loved this series of chevy truck and the burb is just that much more cool. Thanks for sharing your journey, your life and your faith with us.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 05-10-2016, 10:30 PM   #1158
Advanced Design
Thanks Val...sometimes it goes right. The fires in Canada are terrible with so many lives uprooted and changed for ever. Wish the rain we have been getting was there instead.
Marc
Hey thanks Marc. You did real good work for late on a Sunday. I start running out of gas. Way back, a buddy and I would work on the race car all Friday night and head for the track in Frederick, MD to drag race on Saturday. That was 25 years ago though.
Thank you Coach. When it was going smoothly I was thinking of your build and how the welding was going smoothly...then how the front suspension and one of the rear knuckles really fought you.
Originally Posted by rkn463 View Post
Hi AD,
-Richard
Richard, thank you for your kind words. And for hanging in there through this long journey of a build thread. You have some very creative ideas going with your build and I love that. And the Lord has worked in our lives in amazing ways. I give Him the glory.
Wife and I went to the shop for a bit this evening. I had to make sure the drive shaft really would clear the notch. Whew...
Then I stared at the frame and exhaust pieces for like a half hour thinking...some parts are slip fit, some butt weld, and it all needs fabricating together. How do I position the pieces to lay them out, measure for needed cuts and support for welding? Came up with an idea I will try next week end. If it works I will share it and if it doesn't we will pretend it didn't happen.
Yeah, I am overthinking this one...
Old 05-10-2016, 11:51 PM   #1159
lower50's
lower50's's Avatar
The notch looks good and strong enough for what it is. For the exhaust I would start at the front attach and tack weld as you move back. That is how I did mine, just make sure you can remove it before you weld to much in case you need to add a flange.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-11-2016, 09:13 AM   #1160
Number98
Prestige Worldwide
Number98's Avatar
I have been slacking on this thread, I had to go back and read several pages and get caught up. Looking good AD!
Number98 is offline   Reply With Quote
Old 05-11-2016, 08:24 PM   #1161
Advanced Design
Thanks Lower, I think it will be strong enough for the loads it will have. Yep, planning to start at the front and work my way back with tack welds. I need to position the X pipe where it needs to be and work back to it. Then a very short run to mufflers and a 90 out to the flex pipe and running board outlets.
Hey 98 good to see you back. I've been enjoying Betty's updates and I ...for a second...thought I was on the wrong build when Nsane was posting pics. Imagine they will do a great job with the metal while you redo the engine.
My AADD was kicking in and I stopped to look at this one. No powertrain installed and has new paint and decent chrome for $3k. Retired new car dealer had a guy do paint and body. He wasn't happy with result so stopped the restoration. Thinking it is perfect for my next LS swap project.
Old 05-11-2016, 08:26 PM   #1162
Advanced Design
Great starting point for LS install...possibilities here. CFO green lighting the idea too.
Old 05-11-2016, 08:30 PM   #1163
Advanced Design
Until I crawled underneath...stupid Midwest road salt rusty truck...yeah it can be fixed and there is probably a bunch of ugly under the new paint. Pass.
Old 05-11-2016, 10:27 PM   #1164
youngrodder
I don't like the idea of you toying with the idea of picking up another project. if I'm going to finish 3rd on the Suburban build off it could really put my strong hold on 3rd place in jeopardy...
The notch looks like it worked out well...
Marc
Old 05-12-2016, 12:33 AM   #1165
joedoh
joedoh's Avatar
yeowch, I love the 67-8 front ends the best too.
Old 05-12-2016, 07:56 AM   #1166
Valarius_Starchaser
Definitely pass on the truck there's better opportunities out there Doug
"Orange Crush"
Old 05-12-2016, 05:03 PM   #1167
Iceburgh
Iceburgh's Avatar
One thing is for sure my next project will not be a vehicle from the east or Midwest.
Southern and west cars are just head and shoulders better. The Burb was bad enough but the 56 is just getting old cutting and replacing metal. Not to mention $$$ on trim
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 05-12-2016, 08:24 PM   #1168
Advanced Design
Marc
That gave me a smile and chuckle! Truck could have been a good possible to have on deck after the Burb. I think the notch will work too. Kinda copied Old n slow.
They do look good. Yeowch is right.
For sure Val. Eventually the right something for the next build will fall in my lap. Knowing this retired dealer and his cars, I figured this one had to be rock solid before he spent money on paint...nope. Always pays to look.
You and me both Iceburgh. My 48 truck was rock solid and was a pleasure to build. This Burb was decent though not perfect. Next one has gotta be nice. Something like this one...http://ls1tech.com/forums/conversion...onversion.html
I think I asked before, do you have a build thread going anywhere on your 56?
Old 05-13-2016, 09:07 AM   #1169
RockinKees
RockinKees's Avatar
Notch came out good!
Shame you had to pass the C10, from the pictures it looked like a real nice truck.
Something you would find overhere, then you look underneath....
I think you guys have a lot of space to think about another project, while the other isn't finished yet
Wish I was in that position.....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-14-2016, 08:24 PM   #1170
Advanced Design
Thanks Kees! We are fortunate to have a lot of space. That is one benefit of living in a rural area.
My exhaust platform idea worked...it's a start. Now to find fairly short mufflers to be able to make the 90 to the exhaust outlets in the running boards.
The pipe clamp shown in the picture came from Stronghands and it worked extremely well for holding the pipe sections being butt welded. Very well made quality clamp for like $38 from Amazon.
Old 05-14-2016, 08:30 PM   #1171
Advanced Design
My TIG welding skills are not there yet to be able to tack weld the butt connections. Without going into details, it was pretty much a Three Stooges episode. I was laughing at myself.
So I resorted to the MIG for the tacking needed. That worked!
Now, to put in about 100 hours practice with the TIG...it is always rewarding to learn a new skill.
Old 05-14-2016, 10:43 PM   #1172
99 to Life
99 to Life's Avatar
looks killer, great jig you made. I bet you could make a set of those clamps rather easily.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-14-2016, 10:52 PM   #1173
Valarius_Starchaser
I was just thinking that any chance we could get a closeup of them? they appear to have some sort of roller maybe?
For $38 though I don't think its worth converting a $32 pair that one would already have to make them unless you could make it more of an attachment
"Orange Crush"
Old 05-14-2016, 11:09 PM   #1174
youngrodder
Looks great Doug.....I could have sworn I saw these photos before??? Must just be me.
Nice pipe hanger/support set up.
Marc
Old 05-15-2016, 11:09 AM   #1175
Advanced Design
Thanks guys. Yeah 99, you could probably make a set though these are very smooth and stable. By far better than any clamp I have ever used.
Val has a good point and per his request here is a better pic.
Marc, you must have seen the preview!
