Old 09-20-2016, 10:54 PM   #626
piratexpress1369a
piratexpress1369a's Avatar
Re: My suburban's Twisted Little Sister
Awesome work Dale
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 09-24-2016, 09:14 PM   #627
65sub
65sub's Avatar
Originally Posted by lower50's View Post
Wow Dale you are flying!!! Is the little kiddie pool for when you guys need a brake?
Thanks Lower The kiddie pool is for my dog everybody else can use the big pool.
Originally Posted by 62stepside longbox View Post
Great to see you getting back to work!
Thanks Nik. It's good to be back.
Originally Posted by Advanced Design View Post
You know, that approach is a great idea and will save a ton of time and work. Going to be rolling soon.
Thanks A.D. Swapping just the rail only took about 10 hours start to finish.
Very nice!
Thanks Palf
Originally Posted by piratexpress1369a View Post
Awesome work Dale
Thanks Pirate
After we got the rail changed we decided to modify the drivers side of the frame to make a new style of wheelchair lift in the pick up.Doing the modifications now will slow down the reassembly but it's easier with the body off. To start off we removed the exhaust, trailing arms and the crossmember. Stay tuned next week for more updates
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 09-26-2016, 08:44 PM   #628
65sub
65sub's Avatar
Today we got started on the new trailing arm crossmember. To make more space we are moving the crossmember back 9 inches so we chopped that amount out of the trailing arms then welded them back together. Then we remounted to the rear axle
Dale
Old 09-27-2016, 01:07 AM   #629
Grizz1963
Grizz1963's Avatar
Clever Clever Clever.
Amazing how necessity is the mother of invention.
As always, great to see your updates.
And of course the doggy assistant. They make a difference too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is online now   Reply With Quote
Old 09-28-2016, 11:51 PM   #630
Average Joe
Average Joe's Avatar
Quality work! Anxiously awaiting the next installment.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-29-2016, 07:41 PM   #631
65sub
65sub's Avatar
Thanks Rian. Sometimes it comes down to invent something or just drive a mini van. AND I HATE MINI VANS.
Thanks Joe The next instalment is coming up.
Today we used the plasma cutter to split one side of a 2X2. Then we slid it over the bottom of the drivers side frame rail and tacked it in place.
Dale
Old 09-30-2016, 08:11 AM   #632
lower50's
lower50's's Avatar
Neat idea. I see great things coming.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-06-2016, 08:17 PM   #633
65sub
65sub's Avatar
Thanks Lower
Today we finished the new trailing arm crossmember and welded and bolted it in place. Then we made the inside rail of the box we are making and then set it in place.
Dale
Old 10-06-2016, 10:45 PM   #634
lower50's
lower50's's Avatar
That is some serious steel frame you got going there.
1951 MG TD
Old 10-07-2016, 12:32 PM   #635
62stepside longbox
62stepside longbox's Avatar
Wow that is gonna be one beefy frame!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 10-07-2016, 12:49 PM   #636
Bomp
Bomp's Avatar
Serious frame modification.
Bomp is offline   Reply With Quote
Old 10-12-2016, 02:23 PM   #637
65sub
65sub's Avatar
Better to be over built than under built.
Well I don't want my butt dragging on the ground
I really do like to cut things up.
After a whole bunch of welding we have finally got to the point of cutting the original frame out. Here.s a couple of pictures of where we are now
Dale
Old 10-13-2016, 03:57 PM   #638
Average Joe
Nice work!
Old 10-13-2016, 06:29 PM   #639
lower50's
lower50's's Avatar
I totally agree!! Looks great.
1951 MG TD
Old 10-13-2016, 07:25 PM   #640
62stepside longbox
Looks great Dale, keep the show going
Old 10-19-2016, 09:22 PM   #641
65sub
65sub's Avatar
Nice work!
Thanks guys. I'm glad you're following along on the slight detour on the '67. Hopefully we'll get back to the Twisted Little Sister fairly soon.
We boxed the original frame forward of the cut out section and welded the boxing plates to the new frame. We also had to reroute the exhaust. Here it's just tacked together. We should have the welding done soon before the weather gets too cool
Dale
Old 10-19-2016, 11:25 PM   #642
Hewfil1
Hewfil1's Avatar
I take it you won't be boxing both sides then?
Hewfil1 is offline   Reply With Quote
Old 10-26-2016, 01:32 PM   #643
65sub
65sub's Avatar
No, the boxing only extends about 12" ahead and behind the section we cut out of the drivers side frame rail.
We finished most of the welding so we pushed the frame back inside out of the cold weather. Then we carefully lowered the cab and box down on the frame
Dale
Old 10-26-2016, 07:45 PM   #644
Advanced Design
Advanced Design's Avatar
That was some impressive frame fabrication!
Dale, is that a combination tonneau cover and tailgate? Very cool look.
Advanced Design is offline   Reply With Quote
Old 10-27-2016, 03:38 AM   #645
Grizz1963
Grizz1963's Avatar
That last chassis photo really shows the extent to which you have to modify your life to get from A to Z with a modicum of coolness.
That's some serious editing of the original design just to fit it around you.
Amazed as always Dale.
Old 10-27-2016, 10:05 AM   #646
piratexpress1369a
Looks awesome
63
Old 10-27-2016, 10:50 AM   #647
62stepside longbox
Looking great Dale, she'll be done in no time
Old 10-31-2016, 08:16 AM   #648
deejaaa1
Beautiful craftsmanship.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 10-31-2016, 04:55 PM   #649
lower50's
lower50's's Avatar
That frame looks great, should be nice and strong for your lift.
1951 MG TD
Old 10-31-2016, 08:41 PM   #650
65sub
65sub's Avatar
Thanks Doug. Combining the cover and the tailgate gets the tailgate out of my way and it's different.
Thanks Rain. I find cutting stuff up and changing it to be the fun part of the build.
Looks awesome
Thanks Pirate
Thanks Nik. Hopefully I'll get a test drive before the snow arrives.
Thanks DJ.
Thanks Lower. I think it will all work out.
Today we installed the rad saddle and both front fenders so we could check that we had solved our panel fitment issues. Good news, things are looking good.
Dale
