07-23-2008, 01:49 AM | #76 | |
Re: LS1 swap. What oil pan did you use?
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-23-2008, 01:56 AM | #77 |
C10 addict
Any idea what mounts the camaro pan will work with? I'm going to pull the drivetrain out of the GTO this weekend.
Good luck with the move! |
07-23-2008, 02:29 AM | #78 |
All the mount that move the motor back, ie the ones that use the plates....Street and peformanc, CPP, and I'm sure others. Thanks.
06-27-2009, 10:10 PM | #79 |
Amateur Rust Fighter
I know this is an old thread, but I think my question is relevant to the discussion.
What's this piece indicated by the arrows in the attached pic, and does it need to be swapped if changing from an F-body pan to a CTS-V pan, or does it stay with the pan it came with? The CTS-V pan is on the left, indicated by the red arrow. Obviously the F-body pan has the green arrow. Thanks, Brent
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
06-27-2009, 10:50 PM | #80 |
C10 addict
That is the oil cooler bypass, You want the camaro one with the boss on it so you can drill and tap it for your oil pressure gauge. See attachment
06-28-2009, 12:03 AM | #81 |
Thanks for the info! What did these and later cars do for the oil pressure sender, since obviously they didn't use this method?
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) Last edited by brossow; 06-28-2009 at 12:05 AM. |
06-28-2009, 03:21 AM | #82 |
C10 addict
They have an oil pressure switch at the back of the manifold. It won't work with mechanical oil pressure gauges
06-29-2009, 01:01 AM | #83 |
Dumb question: is it tapped to 1/8" NPT or 1/4" NPT? The attachment above says both. I'm assuming it's supposed to be 1/4" NPT but I hate to make assumptions.
06-29-2009, 01:24 AM | #84 |
C10 addict
Most aftermarket oil pressure gauges use a 1/8" NPT fitting but come with an adapter for 1/4". I would recommend 1/8" NPT so you maintain good wall thickness.
06-29-2009, 07:57 AM | #85 |
Ah, I get it. Thanks!
01-17-2010, 03:17 PM | #86 |
Hart_Rod, I just went through this thread and this is what makes 6772 site priceless. Thank you for all the research. Would you happen to have the part numbers for CTSV pan and pickup? Stupid question but that is classic CTSV application right? For the LS6 application? Not the LSA new supercharged correct?
01-17-2010, 07:03 PM | #87 | |
R/ EDIT: I found these numbers in this thread, http://www.ls1tech.com/forums/conver...s-needed.html: Oil pan 12577901 windage tray 12558268 pickup tube 12577906
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-17-2010 at 07:05 PM. |
01-17-2010, 07:30 PM | #88 |
69fatmotor
i haven't used one yet but here's a pan kit from gm performance http://www.summitracing.com/parts/NAL-19212593/ . i did how ever use the h3 pan in a '71 truck with the factory stands , fit like a glove
01-17-2010, 08:04 PM | #89 |
Here's another good thread with all the pans and part numbers:
http://www.ls1tech.com/forums/conver...x-oil-pans.htm Cadillac CTSv : Capacity: 5.5 qts Oil pan: 12577901 Oil pump pickup: 12577906 Windage tray: 12558268 (same as Truck "C/K) Dipstick tube: ? Dipstick: ? O-ring for Oil pump pickup:? Oil pan baffle: 12577904 l
02-03-2010, 07:18 PM | #90 | |
he recomend CPP mounts as well ECE's and others It all depends were you mount the tube perches. you can get same issues with any mounts ! Last edited by gus; 02-03-2010 at 07:32 PM. Reason: none |
02-03-2010, 07:28 PM | #91 | |
02-03-2010, 07:31 PM | #92 |
01-05-2017, 03:09 PM | #93 |
I have the stock 5.3 vortec truck oil pan on my 65 C10, but not thinking ahead I found out I have no clearance to remove & replace the oil pan to replace the oil pan gasket with pulling the engine out; does anyone know of a solution?
01-05-2017, 05:13 PM | #94 | |
How often do you plan to need to replace the oil pan gasket? Often enough that pulling (or at least lifting) the engine is a big deal? I could be wrong, but I'd be very surprised if any oil pan would have enough clearance around the crossmember that you could get the pan loose, let alone completely removed for gasket replacement.
01-06-2017, 01:34 AM | #95 |
~ I like these old threads they are sometimes helpful when working on old trucks.
Oil pan leaks are common on LS engines,(especcially for those with heavy feet on the gas); there has to be a solution other than pulling the engine, there is not enough clearance on the low hump cab to raise the engine. Just wondered if someone solved this with different engine mounts or oil pan. |
01-06-2017, 02:36 AM | #96 |
Hey gtmywings, Welcome, and if you want to remove the pan with the engine in place it's possible to jack up the truck and support the frame, use a cherry picker to hold the engine up, disconnect the motor mounts, remove all the cross member bolts to frame, brake lines, disconnect pitman arm, and drop and roll the cross member out of the way.
I would rather pull the motor myself as these ls motors are very easy to work on. |
01-06-2017, 07:46 AM | #97 | |
If you aren't going (or are able) to lift the engine in place that pan is not coming out of there. It won't clear the rotating assembly or oil pickup tube when you drop it.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-06-2017, 01:07 PM | #98 |
I thought of that 68C10airstream, it looks like a previous owner welded the cross member to the frame, something I had to planned to address when I do a frame off, but in the mean time I would like to stop the leak, and I currently don't have a place to pull the engine, I just fixed 3 other small leaks that were accessible. This is my only vehicle & daily driver.
01-06-2017, 01:21 PM | #99 |
NC_John , do a google search on "common oil pan leaks on 5.3 vortec", it is one of the common areas that leak after 120K miles, I currently have 128000 on this engine. I am using the stock LM7 oil pan, if there is another oil pan that will give me the clearance such as f-body or vette, that may help in the future.
I may have to cut the low hump in the cab and make more room above the transmission in the future just so I can have access to removing oil pan. Though it looks like I will have to pull the engine to fix this leak unless I can figure something out. I had hoped someone in this forum had found one. |
01-06-2017, 03:21 PM | #100 |
The truck I'm building has an aftermarket frame (from Scott's). It requires an "F" body pan, or the camaro pan. It's got the shallowest (is that a word?) front, and yes, it's a 5.5 quart pan. As long as you're changing the oil, I don't think that's a big deal. I'm running it on the low HP 6.2/LS3; and the corvette pan that came on the crate motor didn't work either. I say corvette, it could be a cadillac pan, I'm not sure. Please realize I don't race the truck, so just remember that figures into my opinion here.
I had a truck pan on a previous build, which fit a factory frame (lowered) OK. The pan did hang below the cross member though. I wasn't in the weeds, so I was OK. Guess it depends on your build. Summit has an "F" body pan kit, with the pan, tray, and pick up tube including gasket. Think it was slightly over $230? Don't really want to remember... Worked though. I agree that best idea is to stay with a GM pan. With the frame I have, I also didn't have room for the factory exhaust headers. I went with a set of "shorty" headers on e-bay. They work fine but I had to go to 135 degree spark plug wires. I'm also running fire socks over the wires just for safety. Good Luck with your build!! |
