06-08-2018, 05:18 PM | #1 |
Help! need steering box for '67 C10
I need a power steering gear box for my '67 C10, but was informed by my very knowledgeable mechanic that most of the gear boxes are of poor quality.
The former owner had installed power steering (for front-end drum brakes), and due to his death, I don't know if the box was new or not at the time of the upgrade from manual steering. The Pitman and Idler arms have been replaced, but the steering gear box (and I would replace the rag joint at the same time) appears to be "toast." Tried a place called "Flaming River" online (reported to be a quality source), but they don't supply steering gear boxes for the '67. I have numerous catalogs, but don't want to waste my time contacting any of them unless I can be assured that I will receive a unit that won't wear out right away. I have been told that too many boxes are "junk," and I am a relative newbie in the area of which companies can be trusted for higher-quality products. Or....should I check the local Chevrolet dealership? So........any suggestions as to where to go to purchase the item (a power steering box for a 1967 C10) would make my day. Thanks, Smitty |
06-08-2018, 05:35 PM | #2 | |
The Older Generation
Re: Help! need steering box for '67 C10
Basically any of the power steering gear boxes will fit the '67. The problem is that the '67 frame does not have the factory frame indentation to allow it to bolt in directly. You will have to indent the frame or add spacers between the steering box and the frame to make it work. There are quite a few threads on the subject if you do a search. Here is one thread you can check out.... http://67-72chevytrucks.com/vboard/s...d.php?t=365817 LockDoc
06-08-2018, 08:43 PM | #3 |
As far as quality is concerned.. I just put in a gear box from LMC Truck on my 71.. Quality seems great.. it's exactly like the factory unit.. I only have about 100 miles on it.. Don't foresee any issues..
06-08-2018, 09:04 PM | #4 | |
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
06-09-2018, 11:26 AM | #5 |
Thanks Rob. The "play" in the steering wheel is apparent when driving or when the engine is stopped. Doesn't make a difference. Play is around 4 inches. The idler arm and Pitman arm were purchased from LMC. I'll check out Red Head (not familiar with them). I checked with Flaming River, but they don't carry steering gear boxes.
Which leads to the possibility of having the existing box rebuilt. Since it fits well to the frame, why not have the box rebuilt? Any ideas? Last edited by Smitty550; 06-09-2018 at 11:40 AM. |
06-09-2018, 12:39 PM | #6 |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
06-09-2018, 12:45 PM | #7 | |
06-09-2018, 05:03 PM | #8 |
Lee steering is top notch. Bought my GTO's box from them in the early 90's. Got just what I wanted after talking to Lee on the phone for at least a half an hour. We decided what would be best and it has been flawless since.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-09-2018, 05:07 PM | #9 |
Any auto parts store sells them for right at 200.00 plus your core......
I BELIEVE IN JOHN 3:16 |
06-09-2018, 05:21 PM | #10 |
Would you consider used?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
06-09-2018, 05:21 PM | #11 |
Lee steering will be more than that. If I remember correctly it was $800 to have them rebuild my box and pump. I was building an autocross car and the second gen Trans Am box I had in it wasn't cutting the mustard.
06-09-2018, 05:56 PM | #12 |
Sure. My wife and I have a "getaway" place near Graeagle, but we won't be up there for a few months. Chester is not far away, and even if I find a new part elsewhere, I would enjoy meeting you to compare notes, etc. If you can shoot me a Private Message, I'll contact you either way. I'm a newbies on this site and haven't posted or received PMs, so I may require being led by the hand.
Smitty |
06-09-2018, 06:01 PM | #13 | |
Thanks for the tip. I hadn't even considered shopping locally because the truck is now 51 years old, and I didn't think parts would be offered by the discounters. I'll also check with the local Chevy dealer. Smitty |
06-09-2018, 06:59 PM | #14 |
I'd recommend a Lares brand rebuilt, $103 plus $75 core at rockauto. You can even choose your ratio, 4 turns or 3, depending on your preference. I switched to Lares for steering stuff after having nothing but terrible luck with Cardone. I have had great luck with their pumps too.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
06-09-2018, 09:29 PM | #15 |
Oreillys has life guarantee
06-09-2018, 09:38 PM | #16 | |
06-09-2018, 10:04 PM | #17 |
The dealer will bo of no use.
The nearest parts store will have the parts, but you can't ask for a 67 box since they didn't have PS (regardless of the questions about Cardone). If you want try 68, 69, etc. til you find a part. Use theire website. Look for metal flakes in the fluid. If it's ther you need a rebuilt pump and new lines as well as a box to make sure the metal is out. |
06-10-2018, 10:27 AM | #18 |
Thanks, Franken. I didn't think that PS was available for '67 C10s, but being a newbie, I didn't know if I should stop wasting my time trying to find a '67 gear box, or go for a '68 or newer. Come to think of it, the existing box must not be a '67, since if PS wasn't available for that year, the box must have come from a '68 or newer truck, and if this was the case, the modification to attach the box to the frame won't be apparent until the existing box is removed.
While we are on the subject, does anyone have an opinion on whether or not a quick-ration box should be considered? Seems that the original steering wheel diameter was large because power steering was not an option, and it was easier to turn the truck with a larger steering wheel than with a smaller one. Frankly, I feel that a quick-ratio box would work well, especially if a smaller steering wheel were used. Does this make sense? |
06-10-2018, 10:32 AM | #19 | |
06-10-2018, 12:12 PM | #20 |
I prefer the quicker ratio box. I went to one when I went to a smaller wheel and wouldn't go back. It steers much faster than the original style box.
06-10-2018, 03:34 PM | #21 |
q/r boxes are real darty
06-10-2018, 04:10 PM | #22 |
All the 67-72 trucks had large diameter wheels. I never found a QR box darty. Chances are the toe was off.
Parts area: http://67-72chevytrucks.com/vboard/s...d.php?t=765332 Last edited by franken; 06-10-2018 at 04:40 PM. |
07-11-2018, 09:27 AM | #23 |
I put a RedHead 3.5 box on my suburban and absolutely love it!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-11-2018, 09:50 AM | #24 |
Cordova Truck Dismantlers Inc. in Sacramento (916-366-6866) is showing a complete P/S changeover for $200.00. It may be what you are looking for.
Used power steering box are selling for $75. to $150. at junk yards in CA. Also check Rock Auto for new and rebuilt units. Good Luck! Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-11-2018, 10:57 AM | #25 |
I live 20 minutes from here and never even knew they existed. Thanks!
1968 GMC C2500 Long Bed Fleetside |
