Old 08-05-2018, 06:27 PM   #701
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Pic 1. Started on my wheel tubs, I used trailer fenders to start.
Pic 2. Figured out the arch (using the new fender as template)
And cut the bedside.
Pic 3. Cut the fender to 3" wide and removed the stock flange and will reuse for mounting.
Pic 4. Bottom side showing the flange.
Mark
reaper71 is offline   Reply With Quote
Old 08-12-2018, 05:29 PM   #702
reaper71
reaper71's Avatar
Pic 1 all tacked together.
Pic 2 all metal finished and installed.
Pic 3 I used dyechem on the next fender and used the old cut piece as a guide.
Pic 4 Tubs all done
Next up the gas tank.
Mark
Old 08-12-2018, 10:04 PM   #703
Advanced Design
Advanced Design's Avatar
Nice work Mark. Looks good!
Advanced Design is offline   Reply With Quote
Old 08-13-2018, 07:36 AM   #704
reaper71
reaper71's Avatar
Thanks Doug
Old 08-13-2018, 05:20 PM   #705
lower50's
lower50's's Avatar
That turned out real nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-14-2018, 07:47 AM   #706
reaper71
reaper71's Avatar
Thanks Lower, Turns out I didnt need the tubs to be as wide as they are. (3") but I had one of the flanges already done before the wheels showed up so I just kept them at 3.
Mark
Old 08-14-2018, 02:50 PM   #707
joedoh
joedoh's Avatar
nice use of trailer fenders!
Old 08-14-2018, 09:44 PM   #708
reaper71
reaper71's Avatar
Thanks joedoh
Old 08-14-2018, 09:50 PM   #709
reaper71
reaper71's Avatar
Just some quick shots I took of the truck to see what it looked like outside
The side shot does not represent the true ride height (dip in the gravel)
Old 08-15-2018, 12:12 AM   #710
mongocanfly
mongocanfly's Avatar
Love the stance...but around here that lower grill would be like a dozed blade....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-15-2018, 06:18 AM   #711
Advanced Design
Looks good outside. Makes a guy want to hurry and get it done.
Old 08-15-2018, 07:49 AM   #712
reaper71
reaper71's Avatar
Thanks Greg and Doug.
Greg as I stated it is not the true ride height, the lumps and bumps in the gravel makes it way lower in the front than it is.
The bumper ends are 4 1/2 off the ground and the center bar is 5 1/2
but yes we have it pretty good around here with the smooth roads
Doug...Yes sir it does make me amped up to get it finished!
Mark
Old 08-16-2018, 10:43 PM   #713
joedoh
joedoh's Avatar
that should be plenty of room, I had a 47 gmc that the bumper was only about 3 inches off the ground and it would rub the crown of the road!
Old 08-17-2018, 07:58 AM   #714
reaper71
reaper71's Avatar
A friend of mine has a truck that sits super low,and after riding in the pickle wagon for a while it kinda beats you up!!
Thats why I chose to "Z" the front end to get the ride height with full travel.
Mark
Old 08-17-2018, 06:25 PM   #715
mongocanfly
The plan for mine is 5 1/2" at the lowest body point....and around here im worried that may be to low....but thats about the same as a new vette ,but their approach and departure angle is minimum since the tires are at extreme front and back...they sit extremely low...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-19-2018, 09:34 AM   #716
99 to Life
99 to Life's Avatar
nice work
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-20-2018, 05:59 AM   #717
RockinKees
RockinKees's Avatar
Just read a few pages back.
Awesome work as usual!
I really like the look of the front, the headlights and I love what you did with the front bumper, really cool!
As Doug said, it looks great outside
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 08-20-2018, 08:00 AM   #718
reaper71
reaper71's Avatar
Thanks everybody!
Its been fun finally getting back at this thing!
Mark
Old 09-03-2018, 07:54 AM   #719
reaper71
reaper71's Avatar
Update:
Pic 1,2 here is the bottom side of the tank and the angle iron I used for the mounting system. all welded to the flange top and bottom.
Pic 3 This is the frame for the tank, its welded to the rear frame section and I used rivnuts to bolt the flanges down.
Pic 4 Tank mounted.
And for those who are wondering yes the tank comes out from the top,and the bed wood will be hinged so it will lift up to gain access if ever needed.
Mark
Old 09-03-2018, 10:04 PM   #720
Advanced Design
Well that is a good mounting solution...one I’ve never considered. Outside my box.
Good idea!
Old 09-04-2018, 07:37 AM   #721
reaper71
reaper71's Avatar
Thanks Doug, I try to make things easy to remove if needed. Always think to yourself....if needed how can I get to this or remove it to gain access with the least amount of work.
And another note: This is a 20gal. tank from a s-10 blazer and the stock pump (vortec 4.3) puts out the same psi the LS motors need, so I will be installing a in tank pump as well.
Mark
Old 09-04-2018, 10:17 AM   #722
99 to Life
99 to Life's Avatar
Nice work on the tank. I've used a blazer tank on last two builds, but made my own straps. I always cut it just close enough to have the filler exit behind DS rear fender, tricky to fill it as a gas station sometimes.
Nice to know on the pump. Last build went with carbed LS and blazer tank. Nice to have the option to switch over to EFI if we ever wanted, has electronic trans also for that reason.
I'm a big advocated of "how can I simplify" getting to something in case it needs fixed. having bed lift up is hands down one of the biggest advantages in these trucks.
Old 09-04-2018, 09:13 PM   #723
lower50's
lower50's's Avatar
Looks great!! I love using common parts.
1951 MG TD
Old 09-05-2018, 07:52 AM   #724
reaper71
reaper71's Avatar
Thanks Guys
As for the filler I plan on doing something creative
Mark
Old 09-13-2018, 08:03 PM   #725
rusty76
rusty76's Avatar
Pic of the truck outside looks really good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
