01-24-2020, 07:05 PM | #1301 |
Re: off it goes
I have plans...the wife has other plans. lol, no this will be the only one I build to this level. I have lots of nice cars over the years but nothing to this degree. This is a one and done for me....
02-16-2020, 01:29 PM | #1302 |
Re: off it goes
*Ahem*
02-20-2020, 02:44 PM | #1303 |
Re: off it goes
I'll never get tired of the details. So keep this thread going with how you use it and post previously unposted pics of the work process. I'll Look!
02-25-2020, 08:01 PM | #1304 |
Re: off it goes
front end is completed...got a few more pieces put on under the hood
02-25-2020, 08:05 PM | #1305 |
Re: off it goes
buttoning up some things on the interior now that we got all the gauges working. Has any issue with no fuel gauge but turned out to be a faulty sending unit, all fixed... Also took the NOS door handles and polished the inserts to a mirror finish, being as there is nothing else on the truck brushed. Polishing the shifter, tilt lever and signal as well
02-25-2020, 09:38 PM | #1306 |
Re: off it goes
Jeez. Us. Man.... the details on this.
Just outstanding.
02-25-2020, 10:49 PM | #1307 |
Re: off it goes
As the engine rocks in its mounts, will it over-stress the intake tube? I'm not seeing any flex joint in the intake.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-25-2020, 11:45 PM | #1308 |
Re: off it goes
02-26-2020, 02:15 AM | #1309 |
Re: off it goes
Crazy good.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
02-26-2020, 09:10 AM | #1310 |
Re: off it goes
Dayummm this truck is beautiful!!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-26-2020, 10:45 AM | #1311 |
chevy truck fan
Re: off it goes
uuhhm... yea I think this sums it up!!! exquisite!!
question: could/would you go into a little detail of how/what you did for the body "vent openings"- wiper arms openings above the firewall (post 1256) I would like to try to do something similar... thank you in advance |
02-26-2020, 07:31 PM | #1312 |
Re: off it goes
02-26-2020, 07:38 PM | #1313 | |
Re: off it goes
02-26-2020, 07:39 PM | #1314 |
Re: off it goes
thank you everyone for the nice comments...truly appreciate it
02-27-2020, 12:16 AM | #1315 | |
chevy truck fan
Re: off it goes
thank you again |
02-27-2020, 12:09 PM | #1316 |
Re: off it goes
Yes laser cut piece is an exact copy of the factory plastic one, so yes mounting holes all lined up. As for the mesh, we used a panel bond adhesive to keep them in place. We used the panel bond because at that time I was leaving the finish mirrored so we couldn’t tack weld it, but now that we painted it we could of done a small tack to keep them in place.
02-28-2020, 06:34 AM | #1317 |
Re: off it goes
I like the filler pieces you made for the bumpers. Did you attach them to the body or to the fenders?
Rick |
02-28-2020, 06:57 PM | #1318 |
Re: off it goes
03-17-2020, 07:01 PM | #1319 |
Re: off it goes
a little interior action going on in the shop
03-17-2020, 07:07 PM | #1320 |
Re: off it goes
NICE!
03-19-2020, 06:58 PM | #1321 |
Re: off it goes
thanks man
03-20-2020, 06:37 PM | #1322 |
Re: off it goes
This has to be the nicest Squarebody ever built (EDIT: hell, it might be the nicest truck ever built...). It is on my bucket list to see it once it's done.
03-22-2020, 05:32 PM | #1323 |
Re: off it goes
Hart-Rod's comment is definitely not hyperbole!!
03-25-2020, 06:23 PM | #1324 |
Re: off it goes
thanks guys...I appreciate the compliments
03-25-2020, 06:26 PM | #1325 |
Re: off it goes
started to put outside mouldings on....
