Old 10-07-2022, 02:13 AM   #451
Advanced Design
Advanced Design's Avatar
Re: slammed 57
Holy cow I’ve been missing out….wow! Looks great!
Advanced Design is offline   Reply With Quote
Old 10-08-2022, 08:46 AM   #452
Jason 56
Re: slammed 57
Question… when you’re sanding are you cutting to 1500 or 2000 grit before buffing and are you doing your final polish with foam or wool?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 10-08-2022, 07:36 PM   #453
slammed57
slammed57's Avatar
Re: slammed 57
Thanks fellas I appreciate it
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 10-08-2022, 07:41 PM   #454
slammed57
slammed57's Avatar
Re: slammed 57
800,1000,1500,2000,2500,3000 grits all by hand with ridged and soft blocks. I use a lambs wool pad from 3D ( highly recommend) little pricey for that pad $40 but sooo worth it and then a lake county white foam pad for polish.... I been using 3d compound and 3d polish ( i really their compounds) 2500 grit is not a must but does help a little more
My 57 current build
Old 10-08-2022, 10:26 PM   #455
Jason 56
Re: slammed 57
Thanks for the info.
Can’t wait to see the whole body complete. I agree… lots of work, but SOOO worth it!
Old 10-09-2022, 06:22 PM   #456
slammed57
slammed57's Avatar
Re: slammed 57
using a ton of guide coat between each grit except when doing the final step of 3000 grit. Also Iam really happy where the patched in of the cowl vent, came out pretty slick. all that left with the cab is the cut and polish of the door jambs....
My 57 current build
Old 10-10-2022, 11:01 AM   #457
oldman3
oldman3's Avatar
Re: slammed 57
Looks beautiful...Jim
oldman3 is offline   Reply With Quote
Old 10-10-2022, 08:43 PM   #458
duramax55
Re: slammed 57
slamed 57 you said you guide coat when colour sanding. Never thought of that , dose that give good indication of when you have removed all the marks from previous grit. Doesn't the water from sanding just wash the guide coat off?? Very nice looking truck and paint is awesome.
duramax55 is offline   Reply With Quote
Old 10-10-2022, 10:20 PM   #459
slammed57
slammed57's Avatar
Re: slammed 57
Yes, it tells you exactly when all scratches are gone and move on to the next grit. you can not use the guide coat on the first cut ( there are no scratches for the powder to fill) only after 600-800 or what ever grit you prefer start with.The key is to use a lot of light. a flood lamp on a stand works great, a led that straps to your head (like what the mechanics) use works decent to. when first applied and sprayed with water only a slight amount comes off but plenty stays on for the sanding process. As your are sanding you will see the scratches slowly disappearing, when they are gone I will sand 2-3 more swipes after just to be sure. it produces a consistent and even result. 3000 grit does not need guide coat applied. I also only buff and polish at 1000 rpm with a high quality pad,almost impossible to burn the clear or burn through.
My 57 current build
Old 10-11-2022, 09:35 AM   #460
my56chevytruck
my56chevytruck's Avatar
Re: slammed 57
great job Mike, as always. She's "IS" a show stopper.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-11-2022, 09:41 PM   #461
duramax55
Re: slammed 57
slammed 57 thanks for the reply. Will have to try that, alsohow do you prevent getting deeper scratches when sanding. For some reason i get scratches fromdirt or whatever in the paint when sanding. I try to use a lot of soapy water when sanding but still get them don't know what I'm doing wrong. Also soak paper in bucket often
Old 10-11-2022, 09:47 PM   #462
dsraven
Re: slammed 57
Use clean water
Wash the part to be sanded first before sanding
Change water between grits
Dont stir up the water when dipping sander into bucket
Use a large bucket
Use a bucket to rinse of the sander before dipping into the "good" bucket
Use a soaking wet rag to wipe the surface often and especially between grits
Use a pump sprayer
Old 10-11-2022, 09:49 PM   #463
dsraven
Re: slammed 57
I have used a garden hose with a slow stream to flood the surface when wet sanding.
Old 10-11-2022, 10:11 PM   #464
62 Barnfind
62 Barnfind's Avatar
Re: slammed 57
What guide coat are you using?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 10-12-2022, 11:33 AM   #465
slammed57
slammed57's Avatar
Re: slammed 57
dsraven has some excellent advise. I would also add what i do is i get a clean towel and lay it on the work bench or cart on rollers so when you put your sand paper down or sanding block, you put it on the towel. so it wont pick up dirt. I change paper pretty frequently especially when you go up in grits , the finer it is the faster you'll burn through the paper. I personally dont use soapy water. It is acceptable, but with straight water you can feel the paper cutting the clear better and lets me know when to switch at add new paper. the soap just glides over instead of cutting ( at least to me it does). I use a normal squirt bottle from home depot and constantly spray the area as iam sanding. the hose is nice but in my garage it would become a swimming pool.
My 57 current build
Old 10-12-2022, 11:36 AM   #466
slammed57
slammed57's Avatar
Re: slammed 57
I use mirka dry coat with the 3m guide coat pad only, the mirka pad works , but the 3m has a little more spongy and softer feel to it. I wouldnt run out and buy 3m just for the pad, I just had it laying around from prior use
My 57 current build
Old 12-21-2022, 10:27 AM   #467
slammed57
slammed57's Avatar
Re: slammed 57
still chugging along, got a few more parts painted and assembled
My 57 current build
Old 12-21-2022, 10:28 AM   #468
slammed57
slammed57's Avatar
Re: slammed 57
Hope y'all have a Merry Christmas
My 57 current build
Old 12-21-2022, 10:50 AM   #469
Rickysnickers
Re: slammed 57
That looks great!!!
Old 12-21-2022, 02:16 PM   #470
57FleetsideC4
Re: slammed 57
Fantastic looking build!! Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 12-21-2022, 07:30 PM   #471
Advanced Design
Re: slammed 57
Wow! Beautiful! MerryChristmas!
Old 12-23-2022, 12:24 AM   #472
nvrsatisfied
nvrsatisfied's Avatar
Re: slammed 57
nice build! that meat on the back gonna look �� ��
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations)
Perry, Ok.
We're just two guys, trying our best.
72 cheyenne super
https://67-72chevytrucks.com/vboard/...d.php?t=811512
55 chevy truck
http://67-72chevytrucks.com/vboard/s...d.php?t=840174
nvrsatisfied is offline   Reply With Quote
Old 12-23-2022, 11:23 AM   #473
my56chevytruck
Re: slammed 57
you do great work Mike. What size gas tank are you using?? Merry Christmas my friend.
1940 Ford Dlx Coupe
1969 Mach1
Old 12-31-2022, 11:44 AM   #474
Jason 56
Re: slammed 57
I like it!
Old 01-09-2023, 07:23 PM   #475
slammed57
slammed57's Avatar
Re: slammed 57
Little progress here!
My 57 current build
