Closed Thread
Old 09-24-2009, 06:52 PM   #251
r1lorenzini
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Originally Posted by Hickup pickup View Post
I will be puting a nitrogen infused intercooler to disipate the generated heat transduced through a ridgid Kenuter valve perpetuated into a Flux capacitor.thus cooling the center cap.
I think the PLASTIC cap would melt long before the silicone.
Freeeeeeking hilarious
r1lorenzini is offline
Old 09-24-2009, 08:17 PM   #252
jorgensensc
jorgensensc's Avatar
Okay, heres what I know about the 1" rotor setup. They both came on square body trucks, so when my truck was converted to front disc using square body front brakes and crossmember it had the 1" setup. Somewhere along the way I decided to get drop spindles, but found they only came for 1.25" rotor setups at that time. So i converted to 1.25 rotors, which Then I needed to get 1.25 calipers. Not such a big deal. Now they have drop spindles for 1" rotor setups, so it's really not that hard to go with a 1" setup. I'm sure the ECE stuff is nice, but you may be better served going to a junkyard and getting some squarebody parts, it may be easier and cheaper in the long run.
And yes it is alot of trouble going through all this for some wheels, but so is building a truck rather than buying one. We are all a glutton for punishment on this board!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 09-24-2009, 08:42 PM   #253
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
As was once said to me, "oh the joys of truck building!"
78 Build Thread
4Runner Build
smashingchuck is offline
Old 09-24-2009, 08:57 PM   #254
lolife99
67-72 parts collector,…
lolife99's Avatar
Shawn
Hey Shawn,... thanks alot for confirming that the 1" calipers are different. Now I need to buy new calipers for my drop spindles.
I agree with you somewhat.
If you can go to a junkyard and get all good parts to use on your truck you are right.
If you need stock height spindles,... I agree also.
But,... If you are going to use drop spindles,... (like I've said before),... the only part I would re-use from a junkyard front end,... is the rotor dust shields and the bearing dust caps..
Everything else,... I would get new for reliability sake.
New, calipers, rotors, bearings, hoses, ball joints, and,... of course,... drop
spindles.
This is just my take on the junkyard parts.
I guess because all the squarebody junkyard parts around here,... are wore out.
Keith
Convert to disc brakes.
lolife99 is offline
Old 09-24-2009, 09:04 PM   #255
lolife99
lolife99's Avatar
Maybe, I'm more excited than everyone else about this because I was dreading the job of machining the rotors, and possible the wheels. And then having to try to glue on the modified centercaps.
Now everything can be fixed (for my truck anyway) by bolting on the 1" rotors.
Keith
lolife99 is offline
Old 09-24-2009, 09:59 PM   #256
Hickup pickup
Hickup pickup's Avatar
Ya know' By the time you spend the time , effort and , oh yea the additional money ,you could just spend a little more and buy a wheel that actually fits. Or wait until the redesign comes out. But I guess this would be a futile argument if (like Me) you have already purchased the wheels. That being said the mods weren't that tough and if you follow this thread I spelled them out pretty wheel. GL
2-20, 2-21 whatever it takes!
Hickup pickup is offline
Old 09-24-2009, 10:09 PM   #257
lolife99
lolife99's Avatar
I agree^^.
I really liked these wheels when I saw them in Des Moines at the Goodguys show.
But then when I saw them on your 'burb,... I knew I had to make them work.
For me it's no additional expense,... since I hadn't bought spindles, calipers or rotors yet.
Keith
lolife99 is offline
Old 09-27-2009, 06:22 PM   #258
au03z71
au03z71's Avatar
Well, it's nearly October. Any word on the re-design and/or availability?
au03z71 is offline
Old 09-29-2009, 12:37 AM   #259
harnalien
TruckincrazY
harnalien's Avatar
Wow, great thread! I was bummed to hear of the fitment issues until I got to the part about the LD rotors. I have 3" DJM spindles and 1" rotors. These wheels are definitely on my radar if they fit!
harnalien is offline
Old 09-29-2009, 01:25 AM   #260
r1lorenzini
Just heard the staggered idea is pointless the rear rim does not have a bigger lip it's a smaller offset for newer tricks was what I was told. Good news was. 160$ a rim for grey 20's
Old 09-29-2009, 05:31 AM   #261
DrtyJack75
huh??
So the 10" rear wheel wont have a bigger lip?
DrtyJack75 is offline
Old 09-29-2009, 05:47 AM   #262
lolife99
lolife99's Avatar
Look at the pics on "page 1" of this thread.
Keith
lolife99 is offline
Old 09-29-2009, 06:01 AM   #263
DrtyJack75
well the picture of the red truck, look like the same lip...
but the wheels without tires, look like the wheel on the right (or further away) looks to have a bigger lip....
is that just my eyes?
Old 09-29-2009, 06:42 AM   #264
lolife99
lolife99's Avatar
The red truck has 20x8.5's front and rear. That's why they look the same.
Keith
lolife99 is offline
Old 09-29-2009, 10:02 AM   #265
nlped
nlped's Avatar
Okay...just got off the phone with Ray...apparently a part owner of Boss/Eagle wheels and got a depressing update. The new ETA for the revamped 338's are not due out for 8-12 weeks. Apparently they are not going to complete this "project" until after the SEMA show, which is the first week of Nov.
And for the guys with the LD rotors...test fit, because I had the LD rotors first and the wheels didn't fit my truck even then.
Sorry for the bad news!!
Ed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 09-29-2009, 10:19 AM   #266
lolife99
lolife99's Avatar
I'm sure my LD rotors are GM originals. I wonder if the "parts house" rotors from China are different?
Keith
lolife99 is offline
Old 09-29-2009, 10:23 AM   #267
nlped
nlped's Avatar
^^^ I can't answer that, but the rotors I took off my truck could have very possibly been the original ones as the truck only had 87K miles on it when I got it from the son of the original owner. None of the receipts that came with the truck show anything but 1 front brake service and 1 rear.
Carter
nlped is offline
Old 09-29-2009, 11:16 AM   #268
Hart_Rod
Hart_Rod's Avatar
Someone needs to send a rep at Boss/Eagle HQ's a link to this thread. Maybe seeing the large amount of interest in these wheels will cause them to pick up the pace......
Hart_Rod is offline
Old 09-29-2009, 11:56 AM   #269
nlped
nlped's Avatar
^^^Been there, already did that!
Carter
nlped is offline
Old 09-29-2009, 11:59 AM   #270
au03z71
au03z71's Avatar
Ed
Well, I guess I can tell the wife what I want for Christmas now...
au03z71 is offline
Old 09-29-2009, 12:06 PM   #271
nlped
nlped's Avatar
^^^Yep! If something changes, I will let you guys know...post haste!!!
Carter
nlped is offline
Old 09-29-2009, 03:25 PM   #272
au03z71
au03z71's Avatar
Ed
au03z71 is offline
Old 10-02-2009, 04:59 PM   #273
Blitz
Mr. Thread Killer
Juuuust to keep all your interest up and maybe make some drool. Today at GoodGuys DFW
Blitz is offline
Old 10-08-2009, 07:57 PM   #274
Benji_1802
Hey guys, im getting my set of boss 338's this weekend. i will post a pic of my truck and the wheels...
Benji_1802 is offline
Old 10-08-2009, 07:59 PM   #275
DrtyJack75
are they the new design for our trucks? or do you have the smaller rotors?
Closed Thread
