Old 11-20-2009, 12:41 AM   #251
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 2" Drop Trailing arms
So,...
If you made a 1.5" longer trailing arm for this application,... I assume the pinion angle would be adjusted per the trailing arm rear axle mount, and where would the air bag be mounted?
Track bar mount?
Sleeve bag behind the axle?
Or are you even considering this as a new product?
Keith
Convert to disc brakes.
Old 11-20-2009, 12:55 AM   #252
PBFAB.COM
PBFAB.COM's Avatar
So,...
If you made a 1.5" trailing arm for this application,... I assume the pinion angle would be adjusted per the trailing arm rear axle mount, and where would the air bag be mounted?
Track bar mount?
Oh yes... it's definitely being considered. You're spot on with your observations.
Pretty sure I will make the 1.5" adjustment at the trailing arm x-member, and not the arm. This will allow me to keep one standard length trailing arm all the way across the board (makes production easier) and it will keep the converging angle the same. I will just add some more holes to the trailing arm x-member to frame mounts allowing it to be used in it's factory position, or moved back to accomodate more drop.
As for pinion angle... there's so many variables (one or two piece driveshaft; ride height; tire diameter; etc) that I will most likely supply some extra axle saddle in the kit, and allow the end-user to adjust per application. If they don't want to put new perches on, they can always shim it.
Bag mounts and shock mounts will be relocated (have a couple ideas). Trac bar mounts will be incorporated into the notch and trailing arm... most likely.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-20-2009, 01:18 AM   #253
lolife99
lolife99's Avatar
I'm interested in this set up.
Keith
Old 11-20-2009, 01:38 AM   #254
PBFAB.COM
PBFAB.COM's Avatar
I am sure a lot of people will be! I will get it all dialed in over the next "two weeks".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-18-2009, 05:40 PM   #255
64shortc10
64shortc10's Avatar
Any updates????????
Also wondering if I need the Dropmember Bolt in c-notch to lay frame on your trailing arms or if the Kp components weld in notch I already have will work?
Very intrested in this set up, curious to see how the bag setup installs? I need a price when u get a min. on trailing arms/carrier bearing crossmember shipped to 95694? Thanks Nate
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 12-18-2009, 08:01 PM   #256
joe231
joe231's Avatar
Originally Posted by joe231 View Post
so....any plans to adapt this set up to the 73-up frame?
I have been kicking around the idea of swapping a '72-earlier trailing arm suspension into my '80....
Hmmm....
Guess I don't rate.
I asked this question over 3 months ago........
CHEVY ONLY
Old 12-18-2009, 09:18 PM   #257
n2billet
Village Idiot....
n2billet's Avatar
Hmmm....
Guess I don't rate.
E-mail Nate
nathan@porterbuiltstreetrods.com
I'm sure he would be happy to answer your question......
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 12-18-2009, 09:36 PM   #258
joe231
joe231's Avatar
nah, that's ok
CHEVY ONLY
Old 12-18-2009, 10:02 PM   #259
Inverter
Inverter's Avatar
Right on Nathan!
I'll be putting in my order in January.
Just have the pieces ready in the jigs and I'll fly in and weld em up....You know?So you dont have to go in @ 4 in the morning.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 12-18-2009, 11:42 PM   #260
Hart_Rod
Hart_Rod's Avatar
I finally got mine installed.....
Hart_Rod is offline   Reply With Quote
Old 12-19-2009, 01:54 PM   #261
PBFAB.COM
PBFAB.COM's Avatar
Hmmm....
Guess I don't rate.
Joe.... you rate! Don't worry. If you go back and do a little diggin' I am pretty sure I answered this question already. If I didn't, my apologies, and YES... there will be a trailing arm conversion coming out for the square bodies as well.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-19-2009, 01:56 PM   #262
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by 64shortc10 View Post
Any updates????????
Tony from Norcal
Tony-
Been a little hectic this past week, and I apologize for not getting back to you as of yet! I will shoot you a PM this weekend. Pretty sure the KP notch will still allow them to lay with the trailing arms. I will try and get some better pics up, but it won't be til after the holidays.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-29-2009, 05:50 PM   #263
64shortc10
64shortc10's Avatar
Thanks Nate!
Tony from Norcal
Old 01-04-2010, 08:19 PM   #264
64shortc10
64shortc10's Avatar
Any updates on this set up? When you have time call me about this setup!
Tony from Norcal
Old 01-06-2010, 09:25 PM   #265
vegaschevy
Im using the 2" drop trailing arms with 5" drop springs, What hole would I mount the arms in on the crossmember?
Also The crossmember goes on top of the upper and lower frame rails correct?
ANd if I have a carrier bearing where can it be mounted to? Drill a couple of holes in the thinner piece?
vegaschevy is offline   Reply With Quote
Old 01-07-2010, 10:15 AM   #266
vegaschevy
I have answered a few of my own questions. The carrier bearing I have is a different style then 10 different trucks I looked at yesterday. here is a pic of the style of bearing I have. It is in need of replacement anyways so Ill be picking up the other style and I think it will be fine
I see I need the one that has the two bolts that appear to mount perfectly in the provided holes in the crossmember.
I am now unsure If I mounted the crossmember up right as mine fits perfectly between the frame rails with no sandwiching at all which I thought was incorrect and that it sat on top of the upper and lower frame rails. anyone know which way it goes?
Also last question, I know the arms need a preset length of 42.5 but which holes from the original crossmember are used or do we drill all new holes? It seems to line up great with the second and fourth holes I believe it was. Anyone know?
Old 01-07-2010, 04:33 PM   #267
PBFAB.COM
PBFAB.COM's Avatar
Here's a Carquest part number for the carrier bearing we are using #HB88107A
As for the mounting holes in the frame-rails... the member will sit inside the rails, like you have mentioned, and will line up with the original crossmember mounting holes.
With your rear drop you are using, start by placing the front trailing arms pivots in the second hole up from the bottom.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-13-2010, 06:03 PM   #268
layingC10nK5
i placed my order with Nate . will lay frame with his trailing arms, weld in notch, and trailing arm crossmember. this guy has top notch customer service, he is very very patient and answers all your questions. i will definatly be ordering my dropmember from him ASAP(when funds allow) rear set up should be here soon.
layingC10nK5 is offline   Reply With Quote
Old 02-13-2010, 07:48 PM   #269
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I just read through the whole thread...and was that it? Are we hangin' waiting for the final complete kit or it it all done?
I have a bare frame...and am looking to put a lower, more modern suspension on it, front and rear....w/o spending a fortune. I am not interested in laying frame, but wan't performance handling and a decent ride. Something like a 3/5 drop maybe, just want a slight rake.
Volume discount on the rear TA/crossmember setup plus a front DM, arms, ?stock spindle? and r&p steering?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-14-2010, 12:43 AM   #270
PBFAB.COM
PBFAB.COM's Avatar
All the parts have been done for a bit... didn't mean to leave anybody hangin'!
As for a package deal like you mentioned... of course I can make a deal, just shoot me your number when you're ready to talk!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-22-2010, 07:04 PM   #271
layingC10nK5
Talking Re: 2" Drop Trailing arms
got my set up today. everything is great. thanks nathan
(sorry about the crappy pics)
Old 02-22-2010, 09:18 PM   #272
GVizzle
GVizzle's Avatar
Wow!
Did you get the new kit that lays frame with the trailer arms?
If so can you post me some bigger pics!!!!!!!
GVizzle is offline   Reply With Quote
Old 02-22-2010, 10:26 PM   #273
SCOTTMO
powdercoater
Nice,congrats on the new parts....one of these days i will get nathan to make me some...
scott
SCOTT
SCOTTMO is offline   Reply With Quote
Old 07-07-2011, 04:53 PM   #274
watahyahknow
watahyahknow's Avatar
ok oooooold tread but still , i been looking at youre website Nathan and couldnt find a version made for the squarebody , is it made yet and if so is the complete price simulair to the older style kit ?
things over here starting to look up , i'm about to start a new job and got a firm grip on paying my debts , from the looks of it i could get back to work on the truck(s) within a year ..... as soon as i find a new space to work on them (working on that too)
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-07-2011, 09:40 PM   #275
Shane
Shane's Avatar
square bodies didn't have trailing arms ... they only came with leaf springs.
Shane is offline   Reply With Quote
