03-28-2014, 09:22 AM | #251 | ||
Re: 1966 F100 Short/Fleet Full Stock Resto Build Thread
No problem! Try it out on some small/spare parts first to get the hang of it so it'll go smoothly when you get to the good parts.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-28-2014, 09:23 AM | #252 |
Hood has been wetsanded and buffed top and bottom, it's ready to install.
Couldn't resist... Guide coated with sharpie marker, ready to block with 1000 grit. After sanding with 1000 and 2000. More sharpie marker before sanding with 2500. Inside after sanding/buffing. Top finished up.
03-28-2014, 10:52 AM | #253 |
I'm just glad to be here!
WOW just WOW
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-09-2014, 02:33 PM | #254 |
Thanks Karl!!
We've been busy on a 1/4 scale Model T go-kart project lately but we're still working on the truck too. I'll start a build thread on the kart in a few days. On to the last frontier... finishing the bed. Hood and radiator are installed.
04-11-2014, 08:44 AM | #255 |
Like all your other work following along is fantastic, always something to learn.
Why do you think the parkerizing rusted on your first attempt? I've been wanting to try my hand at it and would like to use it for the rust inhibiting properties. Maybe a home kit isn't quite the same as the original? |
04-11-2014, 09:46 AM | #256 | |
04-11-2014, 10:49 AM | #257 |
04-24-2014, 05:14 PM | #258 |
Here's the latest. Inside and left side of the bed has been blocked and shot with tinted K93. It's ready to wetsand and paint. Still have to finish blocking the right side of the bed and get it in K93.
Tailgate is ready too.
04-24-2014, 05:16 PM | #259 |
Found the missing/broken firewall clips we needed locally today so we cleaned them up and put them on. Also hooked up the washer nozzles.
Got new cables for the battery but the ends were dull and flaky looking. Glass beaded them, then burnished them with a stainless brush. The battery post got the same treatment. Can't be losing points at shows for shabby battery posts.
05-09-2014, 10:57 AM | #260 |
Outside of the bed is painted. Still need to wetsand and reclear it to level out the mask lines, then wetsand/buff it. We'll paint the tailgate once we get a set of decals to mask the FORD letters.
05-09-2014, 10:57 AM | #261 |
Here are videos of the first start. The owner had his mechanic come over and set the timing and adjust the carb.
05-11-2014, 02:38 PM | #262 |
Ah, the first light-off of an engine. I never look forward to it, because you're always second-guessing everything you did up to that point. "Did I torque the flexplate, did I put enough break-in lube on the cam, and on and on and on. Once it lights off, it's the greatest feeling, like a huge weight was lifted off of your shoulders.
That 352 runs really smooth. Nice job!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
05-20-2014, 02:08 PM | #263 | |
05-27-2014, 03:11 PM | #264 |
The door locks were hazy so I buffed them with green, then white compound before installing them.
Installing the floor mat from ACC. The mat looks good and fits the shape of the floor very well. We still need to finish trimming around the door jambs and gas tank but it's fairly close for now. Dad wants to finish it up so I stopped trimming at this point. If you're going to be installing the floor mat and the firewall pad, you'll be way better off to install the floor mat first as it's tough to tuck the floor mat under the firewall pad around the pedals. The padding they sent was too small so we added more padding around the edges and missing spots. We also cut reliefs in a few places since the padding is flat and not shaped to the pans already. Roughly fitted. I'll post more pics once it's in and settled. The instrutions say it takes 48 hours for wrinkles to come out from being boxed up. Extra length at the rear in case you moved the gas tank. Needs trimming in our case. This is how much we removed from the front edge.
05-28-2014, 12:30 AM | #265 |
Proprietor of Dale's Corner
Looks great. ..
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-28-2014, 05:37 AM | #266 |
Very Nice!
05-28-2014, 08:58 AM | #267 |
Thanks dudes!!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 05-28-2014 at 09:08 AM. |
05-28-2014, 09:08 AM | #268 |
So the same day we install the floor mat, we find a NOS 65-66 tan/black, low hump floor mat... right here in town. What are the odds of that! He's going to dig it out of storage and check it's condition, and he's willing to part with it if it's in good shape still. He says it's never been exposed to heat so our fingers are crossed!
Shot the inside of the bed this morning.
06-03-2014, 09:11 AM | #269 |
06-03-2014, 09:16 AM | #270 |
The trim came back from King of Trim late Friday so we installed what we could Monday. They strip, straighten, buff, bright dip, and anodize the aluminum trim so that it looks better than new.
Correct black detailing around the headlights and upper/lower vertical bars in the grill. Rechromed original door handles. ACC floor mat after trimming and getting a few wrinkles out with a heat gun.
06-03-2014, 05:13 PM | #271 |
Very Nice!
06-03-2014, 07:20 PM | #272 |
Looks awesome, you're definitely paying a lot of attention to the details
06-03-2014, 07:28 PM | #273 |
I thought I would never say this about a F*rd , but that is one nice looking truck!
-Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
06-04-2014, 10:43 AM | #274 | |
06-04-2014, 10:44 AM | #275 |
A few more pics. Had a couple leaks to fix, whoever built the engine didn't get the thermostat housing sealed up so we had to pull it off and resurface the housing to get it fixed. They also used a fiber washer on the drain plug that had split, so it was leaking too. Got those taken care of yesterday, changed the oil and filter, and pulled it out so it could run for awhile to check for leaks again. No wet spots underneath this morning.
Some daylight pictures. Scott Drake headlight with Ford embossed from Mustangs Unlimited. They're halogen so they're brighter than the old style sealed beams. Checking the park lights and headlights.
