Old 08-17-2007, 06:10 PM   #276
68 short step
Re: Killers 5.3L install
i believe they are just 194's but ill double check here later on.
68 short step is offline   Reply With Quote
Old 08-17-2007, 06:28 PM   #277
1LoC10
Insert Title Here
1LoC10's Avatar
yeah most of the gauges they have say they light up with incandesent bulbs and they are the regular halogen color when you scroll over em... but those when you scroll over they are pure white, but it doesnt say anything.. just wondering if its an LED or what
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 08-17-2007, 07:59 PM   #278
gringoloco
A guy with a truck
gringoloco's Avatar
They're not LEDs, just standard twist-in socket 194s. Here's what they look like lit up:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-17-2007, 08:06 PM   #279
1LoC10
Insert Title Here
1LoC10's Avatar
ok cool... maybe its just the white face that makes them look more white rather than yellowish
BOBBY
_69 SWB_
Old 08-17-2007, 08:26 PM   #280
68 short step
with loco
Old 08-17-2007, 10:49 PM   #281
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by 68 short step View Post
with loco
You're welcome
-Chris
Old 08-17-2007, 11:01 PM   #282
1LoC10
Insert Title Here
1LoC10's Avatar
I think im going to go with the Old Tyme II series, thanks for the lit up pic though
BOBBY
_69 SWB_
Old 08-18-2007, 10:07 PM   #283
68 short step
got the cab back on the frame.... the front springs, drop spindles, drilled and slotted rotors are installed... and started to gut the interior.. removed the seats, gas tank, juit padding, and carpet..... laid down the dynomat extream sound deadener/ insolater.... and yes that is a couch and entertainment center in my front yard
Old 08-18-2007, 10:08 PM   #284
68 short step
Old 08-18-2007, 11:50 PM   #285
killer71
killer71's Avatar
Sweeetttt! Looks like you've been busy!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 08-19-2007, 09:00 AM   #286
meathead95
computer illiterate
meathead95's Avatar
wow! great work so far.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 08-19-2007, 02:58 PM   #287
gringoloco
A guy with a truck
gringoloco's Avatar
Almost a truck again.
Killer- Do you ever make it out to any of the local cruise-ins? I have got to see this thing in person when it's done.
68SS- What are you doing about the A/C compressor?
-Chris
Old 08-19-2007, 03:19 PM   #288
msgross
msgross's Avatar
how many sq ft. of dynamat did it take? Did you do the backwall?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-19-2007, 03:50 PM   #289
killer71
killer71's Avatar
220$ roll from summit! No don says it wasn't enough so i gotta get some more.
R.I.P.
Killer 71
10/26/07
Old 08-19-2007, 03:51 PM   #290
killer71
killer71's Avatar
No not yet chris...but that's the plan....don't worry you & I will hook up...i'm dyin to see that blazer/coys in person.
R.I.P.
Killer 71
10/26/07
Old 08-19-2007, 08:25 PM   #291
gringoloco
A guy with a truck
gringoloco's Avatar
And what are the dimensions on that fuel cell?
Thanks -Chris
-Chris
Old 08-19-2007, 10:19 PM   #292
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
1st time I have seen this thread and damn is all I have to say some great work going on here..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-20-2007, 12:00 AM   #293
68 short step
progress for today, got the a/c condenser, drier, hard lines installed... the hard lines goes through like the factory ones...... modded the headers for a
v-band style connection, i dont like the slip-on desighn that they originally had..... then installed them.... also working on the wiring, this will take some time to hide all the wires, as you can see just a few.... and finally installed the pass fender so it'll hold the rad. support firm to start installing the 5000
CFM electric fan we're going with... that should be enough even for a 120* arizona day, or hauling any boat ....
Old 08-20-2007, 12:09 AM   #294
killer71
killer71's Avatar
Thanks for the updates...you know how i like picts!
R.I.P.
Killer 71
10/26/07
Old 08-20-2007, 08:48 PM   #295
Hart_Rod
Hart_Rod's Avatar
Are you using the factory radiator? How are you hooking up the steam tube/vent?
Hart_Rod is offline   Reply With Quote
Old 08-20-2007, 09:19 PM   #296
1LoC10
Insert Title Here
1LoC10's Avatar
awesome progress man... your doing in weeks, what most of us do in years
BOBBY
_69 SWB_
Old 08-20-2007, 09:26 PM   #297
killer71
killer71's Avatar
factory radiator it is...steam tube will be connected to overflow tank via braided hose...
R.I.P.
Killer 71
10/26/07
Old 08-20-2007, 10:58 PM   #298
68 short step
fabbed up some brackets to mount the fan, then mounted it..... and located the air intake tube to see if it i could get it to clear the battery, i worried about this, but it turned out not to be any problem.... and still doing the wiring....
Old 08-20-2007, 11:31 PM   #299
68 short step
it'll be connected to the fwd. fitting on the water pump, that goes to the heater core.....
the overflow, like killer said, will be connected to the rad with braided line...
Old 08-21-2007, 02:07 AM   #300
gringoloco
A guy with a truck
gringoloco's Avatar
Hello? Test... test... is this thing on?
-Chris
