10-18-2011, 12:44 AM | #326 |
Re: No Limit '72 C-10
Up to speed and watchin...
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
10-21-2011, 06:14 PM | #327 | |
'69 Chevy SWB
you didn't forget about me did you?
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
10-25-2011, 08:55 PM | #328 |
Originally Posted by aggie91 I saw the article in Street Trucks about the suspension mods. Can you elaborate more on what you did for the front crossmember and for the mods to the rear frame? Pictures would be nice... Thanks, check the 'make it handle thread later today. __________________ I may be crazy....but I looked through both threads and still don't see pictures with more detail about the front crossmember alterations. How, or/did you address centering the front wheel when you did the work ? Thanks for all the great information ! |
10-29-2011, 10:17 AM | #329 |
You can find more detail about the rear frame here [url=http://67-72chevytrucks.com/vboard/showthread.php?t=419251&page=31[/url]. I would like to know more about the front crossmember myself.
10-29-2011, 02:59 PM | #330 |
I'm just glad to be here!
http://67-72chevytrucks.com/vboard/s...96#post4951896
Look at this thread starting at post 108. This is how I believe Rob did the front on JT. We need to add pictures of the crossmember back in. Posted via Mobile Device
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-16-2011, 11:06 AM | #331 |
Hart Rod Rob or Nolimit Rob with a rear mount tank, no limit panhard bar and rear shock relocation kit, is there still room to run the exhaust to the rear. Hart Rod's truck pics are the only one's I've seen so far with the panhard setup and rear tank with his exhaust run to the back.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
11-22-2011, 08:02 PM | #332 |
Hi Rob, back in post 207, you said you made adapter mounts for the LS engine. In the Street Trucks article, they said you used Energy Suspension adapters. Which one? Do the ES mounts move the engine sufficiently back and down?
Thanks,
Jack Byrd '70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4 '76 Airstream Argosy MH(want a longer one), 454CID, TH400 |
11-23-2011, 11:49 PM | #333 |
Hmm, both, I guess. I made my own plates, but they are basically the same as Holley, Trans Adapt, E.S., and others. I did use the normal Energy Suspension mounts for a SBC. I used a pattern that would normally move the motor back some, the square mount plate. - but, since I knew I would have to build custom stands off of the crossmember (raised in the chassis) it just seamed easier. If you are using factory mount stands, choose the plates that keep the motor in the stock location.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
12-04-2011, 03:40 PM | #334 |
Been missing updates on progress on JT. Is it on a side burner now? Will there be any more articles in Street Trucks on its' progress?
Thanks,
12-04-2011, 06:45 PM | #335 |
We just did a bit. Maybe the most noticable changes lately. I hate doing this stuff, (door mechanics/windows) so I tend to drag my feet a bit. It was time for some interior comfort. We put in a simple stereo - really simple. 80w amp, two 6x9's (the doors were already cut, so it seamed like the thing to do), and an input cable for an I-pod, or I-phone. It sounds good, and it only cost about $125. Next we got a door/glass install kit from Brothers Truck parts. I had a spare set of wind wings, so I rebuilt them ahead of time. As we got serious, we pulled the seat, and put a good layer of insulation down, along with a carpet kit (Brothers) Here's a note: get a carpet kit for the correct floor pan in your cab. We had to make two trips to get it right. Then new felts and rubbers in the doors, and rebuilt the O.E. cranks. Last, we painted the door panels to match the interior, and put a layer of dynomat on the inside of the doors and panels. Next will be some kick panels, and a panel for the back of the cab behind the seat. This has make a HUGE difference in the 'drive' experience. The doors shut solid, no rattles, and thecab is much quieter. I'll get some picts up next week.
12-05-2011, 08:00 PM | #336 |
Rob, I have been putting off buying my purchase of bags for the rear of my truck until I have heard feedback form you on how they run on JT. Could you let us know if you did add the 9000 bags and how they ride and handle vs other bags please?
12-15-2011, 06:26 PM | #337 |
ttt
12-15-2011, 09:53 PM | #338 |
subscribed
12-23-2011, 11:18 AM | #339 |
Any pictures of the installed rear sway bar? Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-25-2011, 07:16 PM | #340 |
Sweet, love the lower a arms!
12-26-2011, 01:07 PM | #341 |
After reading the tread you started on make it handle I thought there would be more info on this build.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-29-2011, 09:09 PM | #342 |
Update
12-29-2011, 09:11 PM | #343 |
Updates
12-29-2011, 09:47 PM | #344 |
Where did you guys mount the battery?
Posted via Mobile Device |
12-30-2011, 12:08 AM | #345 |
I'll post up a short video friday that shows. It's behind the pass rr tire.
12-30-2011, 09:12 AM | #346 |
The rear saw bar bolts to your shock relocater ? Do you have this in production yet ?
12-30-2011, 02:21 PM | #347 |
The sway bar mount has it's own plate, the pass side doubles as the panhard rod mount, if you are using ours. Or, it has just a sway bar mount.
12-30-2011, 08:13 PM | #348 |
12-30-2011, 08:34 PM | #349 |
Fun Stuff
Great video! Thanks.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
12-31-2011, 09:04 AM | #350 |
Great video I really like the frame mods.Can you take a pic of the bed floor so we can see what 4" looks like.
Tags |
1972 chevy, c-10, no limit engineering |
