06-12-2014, 02:10 PM | #326 |
Re: '72 Drop member... "Betty"
Clean.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-12-2014, 02:20 PM | #327 |
Would you happen to know the outside diameter of these spacers?
///Relaxed Atmosphere |
06-12-2014, 04:13 PM | #328 |
I believe 1 1/2"
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
06-15-2014, 12:02 AM | #329 |
Exhaust system. Going to take it apart and paint black
06-15-2014, 12:43 PM | #330 |
Bed wood almost in. We cleared and sanded this stuff like 10 times. Next time my process will be different. Man these kicked my butt
06-15-2014, 04:03 PM | #331 |
Looks good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
06-15-2014, 07:52 PM | #332 |
Really nice stuff going on. The diff vent is very cool. Consider that idea stole! The bed wood looks real nice too. You mentioned doing something different if you were to do it again. What would that be?
06-15-2014, 10:01 PM | #333 |
Man this is taking shape quick, looks great!
06-15-2014, 10:40 PM | #334 |
Man your exhaust and bed wood look great. Nice job.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-16-2014, 12:21 AM | #335 |
After I stained them I just started clearing them, sanding in between each heavy coat or 2 but the clear is to hard to get built up thick enough to hide the wood grain. Next time I will coat with a product like "bar top" that flows into all the grain, then clear it for uv protection. I haven't done the 4 corner pieces so I will try it in them and let you know. The first way took me 2 weeks of sanding and clearing. F that!
06-17-2014, 04:47 PM | #336 | |
06-17-2014, 05:40 PM | #337 |
Amen brother!
06-17-2014, 11:54 PM | #338 |
Here is some more progress. Got the sloshtubz installed, the bed on and the accuair mounted and mostly wired. Getting closer. I need it finished for our annual car show at the dealership on the 28th
06-18-2014, 10:37 AM | #339 |
Ttt
06-18-2014, 11:41 AM | #340 |
very nice
06-18-2014, 12:40 PM | #341 |
Thanks fellas, glad you like it.
06-18-2014, 12:42 PM | #342 |
seth when the truck is laid out how close are top of the rear tire to the bottome lip of the bed side. Just wondering how much I have to cut.
06-18-2014, 12:55 PM | #343 |
I left about inch of metal below the bed rails so I could bolt my wheel tubz in and it still gave me good clearance. I don't remember exact numbers and I'm at work so I'm away from truck. Hope that helps you
06-18-2014, 02:14 PM | #344 |
67-72 parts collector,…
Does this picture help?
06-18-2014, 02:56 PM | #345 |
What was the wheel sizes again?
06-18-2014, 03:39 PM | #346 |
Truck looks awesome
06-18-2014, 04:02 PM | #347 |
5.5 front 5.75 rear. I have the wider factory rear end still.[/QUOTE]
22's
06-19-2014, 01:43 PM | #348 |
Couple more shots. Painted exhaust ceramic black and we were able to get the stock brake booster to fit with sloshtubz. I was happy about that because I want to keep the stock ish appearance.
06-19-2014, 01:45 PM | #349 |
It looks great Seth. I am about to run exhaust also.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
06-19-2014, 01:56 PM | #350 | |
The exhaust came out great. What ceramic black paint did you use? |
