02-26-2013, 08:50 AM | #351 |
Re: Project "Jezebel"
Looks great Steve, Giving me motivation to get back to my build....
02-26-2013, 06:30 PM | #352 |
Project collector
Thanks guys, now to cutting and buffing...
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
03-04-2013, 04:23 PM | #353 |
Project collector
Couldn't resist putting the bed next to the cab to take a pic.
Ill post some pics later of the firewall. I think it looks killer.
03-04-2013, 04:29 PM | #354 |
Nice job Steve!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-04-2013, 08:58 PM | #355 |
Project collector
As promised. Still have to cut and buff but here it is in gun finish.
It's getting fun now! Working in a clean area bolting on new parts! Anyone need 5 lug Moser Axles for a pre-71 12 bolt? I didnt measure my rear and "assumed" it was a 67 like the frame. Imagine my surprise when the axles were not quite long enough to attach the "C" clips....
03-04-2013, 09:45 PM | #356 |
WOW! I mean WOW! Beautiful!
03-04-2013, 10:25 PM | #357 |
That is one slick paint job.
03-04-2013, 10:34 PM | #358 |
That is a thing of beauty. Awesome job man.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
03-04-2013, 11:04 PM | #359 |
Wow nice work color looks bad a$$
Posted via Mobile Device |
03-05-2013, 08:26 AM | #360 |
Nice job on the truck, looks like a show winner.
Scott |
03-05-2013, 08:30 AM | #361 | |
67-72 parts collector,…
Some of them were the same length as the 71-72 rearends.
03-05-2013, 09:28 AM | #362 |
Still Learning
Awesome work on the paint Steve!
03-05-2013, 01:59 PM | #363 |
Looks great
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
03-05-2013, 02:05 PM | #364 |
Just Beautiful. Props to you, man. Very Very nice. Now put it together and beat it like a rented mule!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
03-12-2013, 03:23 PM | #365 | |||||||||
Project collector
Here is bit of an update: Got my new axles in (the right ones this time ) and installed. Installed the front suspension, engine and tranny. When I installed the Vintage Air Front Runner Serpentine belt kit and rotating the engine over by hand I noticed I have a bent flexplate. It's hitting the starter... Now I have to pull the tranny and replace it. Here are some pics of where I am currently.
03-12-2013, 04:08 PM | #366 |
Still Learning
Wow! the power plant looks great! too bad about the flywheel man. Look forward to more updates.
03-12-2013, 08:35 PM | #367 |
Wow, looking great. Maybe one day when I grow up
03-15-2013, 07:22 PM | #368 |
Shaping up real nice, everything looks excellent!
Scott |
03-15-2013, 11:34 PM | #369 | |||
Project collector
Update: Installed front suspension and steering components. Replaced the flexplate Installed fuel and brake lines Installed fuel tank Installed core support and radiator Installed transmission lines Placed cab and bed on the frame - PROBLEM..... There must be a problem with the cab mounts or the replacement bed I purchased because the body lines in the bed do not align with the lines of the cab... There has to be something easy as I cant believe the replacement bed is to blame. It's about an inch off! Here is what I am talking about. Any suggestions?
03-15-2013, 11:52 PM | #370 |
Enjoying left field
Make sure you've got the right cab mounts. On some trucks the rear cab mounts are lower. I think its the 4wd frames though.
03-16-2013, 05:06 AM | #371 |
Try switching the front mounts with rear ones , I did that when I put my cab back on and saw a huge gap at the top of my fender and pinching at the bottom
03-18-2013, 04:39 PM | #372 |
Those look like the correct rear cab mounts to me. How about a pic of the front mounts?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
03-18-2013, 05:55 PM | #373 |
I think you having it on jack stands is causing part of the problem. Bolt the front wheels on and put it on the ground and recheck. You may still have to add a few shims, but I bet it is closer.
03-20-2013, 03:55 PM | #374 |
Project collector
Thanks guys, I measured the mounts and they are all the same. I haven't tried Rob's suggestion yet but I went ahead and ordered a new set of cab bushings from Classic Parts to make sure. On the site it looked like the fronts and rears were a different size. Until then, I will put the wheels on and see what that does.
03-20-2013, 05:49 PM | #375 |
This might not be of any help, but I just purchased new bushings from Brother's. The front mounts are 1-7/16" tall and the rears are 1-1/4". I will be installing them this weekend. There also looks to be at least one additional steel washer (approximately 1/8" thick) in between my old bushings and the cab.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
