01-18-2013, 12:39 AM | #376 |
Re: Greg65 build thread
ahh ok ya ive always herd stainless tubing is a pain to work with but ive never tried.. and thanx man!!!
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
01-18-2013, 11:35 AM | #377 |
Alan is great to work with. I would like to help more living a hour away limits that pretty well. But then again I stay out of his way and let the master work is magic.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
01-18-2013, 11:40 AM | #378 | |
I've herd the same thing and will let you know how it turns out.
01-18-2013, 07:52 PM | #379 |
looking good greg, what brand pump are you running? i have to get together with you and alan and check these trucks out in person, again great work.
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
01-18-2013, 09:26 PM | #380 | |
I'm not sure on the brand of the pump. A friend of mine bought a couple of these for his Camaro and one for me. I think it is the same company that makes pumps for Holley. Anytime you want to meet just let us know. The next time I come up to Tn. I will give you a heads up. Posted via Mobile Device
01-18-2013, 11:20 PM | #381 | |||
1 thing at a time is progress.
Just let us know. BTW thanks
Alan
Philippians 2:14-16 |
01-19-2013, 09:33 PM | #382 |
Yeah Greg, I would like to see ya'll. My truck hasn't changed since you dropped the springs off. But feel free to drop in anytime.
1990 Chevy Silverado (My DD) 1978 Chevy Bonanza LWB (My LWB to SWB 1 day project) 2015 Hyundai Sonata (Wife's DD) |
01-20-2013, 12:33 AM | #383 |
The process of putting the rib in the floor. This will hold true for most patches.
First I cut out the new piece then taped it where I wanted it. Then I screwed it in place. I use a thin 1/16" cutoff wheel and cut out around it. I cut slits in the end to form the taper. Then used magnets to hold it in place while i tacked it. You could also cut out the bad place then put it on the new patch and do it that way. Which the way I mostly do it, but I had such a small piece to work with I did it this way that is pictured.
Alan
01-20-2013, 12:37 AM | #384 |
I used a small screw driver to even the pieces up as i tacked it. Then welded by skipping around to keep the heat from wrapping the metal. Then ground the welds flat.
Alan
01-28-2013, 11:42 PM | #385 |
Suscribed
01-28-2013, 11:58 PM | #386 |
Cab, doors, inner fenders got dropped off at the sand blaster today.
Alan
01-29-2013, 01:42 PM | #387 |
I'm just glad to be here!
I always thought you should sandblast before doing the metal repairs? Won't you be worried about trapping sand in some areas of the cab and doors?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-29-2013, 01:50 PM | #388 |
My rule of thumb is too cut out all the bad metal then have it blasted. The floors and rockers were done by someone else. I cut out the rest of the bad spots so it will give the blaster access to areas behind the rust. It takes a lot of time to get the sand out, especially the rockers in this case. The roof skin is removed so that should be easy to remove the sand in that area.
Alan
01-29-2013, 09:01 PM | #389 |
A little late on the pics, this was loading day.
He was supposed to be done today, but that didn't happen. No biggie, it was raining and tomorrow will be stormy. I should be able to get it Thursday.
Alan
01-31-2013, 11:52 PM | #390 |
Back from the blaster
Alan
02-01-2013, 12:35 AM | #391 |
Now the work begins. Note pad at the ready.
02-02-2013, 10:15 PM | #392 |
I need your note pad, to copy off of.
Today was a wash literally. I wanted to epoxy prime it today, but Mother Nature said no way. The California doors are in great shape, I really didn't seen this being an issue. The blasting showed some holes (small) in the bottom of the doors. It's far better than what we have to work with around here.
Alan
02-03-2013, 11:39 AM | #393 |
Not near as bad as the first two doors. The cab is looking great Alan.
02-04-2013, 01:22 PM | #394 | |
Very nice build, and I like the color you chose! I'm a little biased though! Going to be a great looking truck with all the work going into it.
Like Alan said, there is no easy way to fix the door edge. Have to make relief cuts through the inner and outer skins to pull it out straight. Just bending it out without cutting reliefs will cause low spots right behind the edge and the edge still won't be level with the rest of the door skin.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-04-2013, 11:06 PM | #395 | |
02-04-2013, 11:17 PM | #396 |
Thanks, I started with blue, then turquoise, and finally decided on fawn. Funny how many times I've changed my mind in ten years.
02-05-2013, 08:21 PM | #397 |
gotta love clean parts
02-06-2013, 07:55 PM | #398 |
It is nice!!
I got to spray some epoxy primer today.
Alan
02-06-2013, 07:58 PM | #399 |
More
Alan
02-06-2013, 08:12 PM | #400 |
I know I'm not the first but let me tell ya, you make that epoxy primer look goooood
