Old 12-10-2011, 11:17 AM   #426
BBEEP
Junior Member
BBEEP's Avatar
Re: 52 GMC Envoy Burb meld/build
Originally Posted by mr48chev View Post
Did you have it dipped in the Portland area or? I'm pretty sure that somewhere in the build the cab I am putting together will be better off with a trip to the dip tank.
The hole in the roof from the light that was on the truck in it's early life?
I had it dipped in Eugene at Metalworks 541-341-3372.
The hole in the roof was from a factory looking vent. I suppose for the passengers on the cot!
BBEEP is offline   Reply With Quote
Old 12-12-2011, 08:48 AM   #427
AUSSIE54
AUSSIE54's Avatar
Congratulations on just clocking over 56,001 views BBEEP. It's a great build. So interesting and very adventurous. Certainly not for the faint hearted!
AUSSIE54 is offline   Reply With Quote
Old 12-17-2011, 09:29 PM   #428
BBEEP
Junior Member
BBEEP's Avatar
Thanks!
Thought I'd post an inside pic, have to do finish work on anything that shows:
Old 12-26-2011, 04:40 PM   #429
BBEEP
Junior Member
BBEEP's Avatar
Nixed the idea of painting from below the windows inside up and over the fiberglass headliner. I think it would look good, but create a tin can effect from my stereo . . . I am still going to make a fiberglass headliner while the top is off, but I will upholster it.
(If anyone would like one while I am doing it, let me know. The guy is charging me $250-300) Probably mid January.
Old 12-28-2011, 12:39 AM   #430
fredscarryall
fredscarryall's Avatar
i would like to order a headliner.i could drive to eugene to pick it up.i am about an hour and a half away. let me know when he gets closer to making it. fred
fredscarryall is offline   Reply With Quote
Old 01-16-2012, 07:08 PM   #431
BBEEP
Junior Member
BBEEP's Avatar
Mounted the running boards last week. Shortened them about 1/4 inch on each end so they wouldn't rub on the fenders. They are also raised about and inch & 1/2 so they are flush with the body--no gap. Interesting thing, we didn't use the stock running board brackets: from the bottom of the Envoy frame is almost exactly the same height from the ground has the boards. Just used square tubing.
(and it is sitting up in the air in the front on jackstands, in case you're wondering . . .)
Old 01-17-2012, 03:25 PM   #432
BBEEP
Junior Member
BBEEP's Avatar
Defrosters . . .
Old 01-17-2012, 03:43 PM   #433
xpickup
xpickup's Avatar
Originally Posted by BBEEP View Post
Defrosters . . .
BBEEP, what a great idea.
Shannon
xpickup is offline   Reply With Quote
Old 01-17-2012, 03:50 PM   #434
BBEEP
Junior Member
BBEEP's Avatar
Found the right one at Sears. $9.99 accessory for a shop vac.
Old 01-17-2012, 04:04 PM   #435
xpickup
xpickup's Avatar
BBEEP, Thank you, because I do not think I have mine. And I do not think they came with my heat / air unit either.
Shannon
Old 01-17-2012, 04:36 PM   #436
Hart_Rod
Hart_Rod's Avatar
Shannon
Vintage Air sells some repos made out of plastic for this year of truck...
Hart_Rod is offline   Reply With Quote
Old 01-17-2012, 05:07 PM   #437
youngrodder
youngrodder's Avatar
I might have some metal ones laying around as I used the plastic vintage air ones. I could use a driver side interior window trim (non vent window) if anyone is intrested in doing some trading....I appoligize in advance if I'm bracking any forum rules (:
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-30-2012, 05:13 PM   #438
BBEEP
Junior Member
BBEEP's Avatar
The factory, or even vintage air, would still need to be modified to fit the Envoy venting. I have $26 in the whole 'ducting'.
As much air as the newer system pushes through, I don't think I will have a problem defrosting the windows . . .
Old 01-30-2012, 05:29 PM   #439
VA72C10
VA72C10
VA72C10's Avatar
That'll probably work out great....just hope they don't whistle like they sometimes do in the vac...but that's usually from the greater air flow and stuff getting stuck in them..
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-30-2012, 05:33 PM   #440
BBEEP
Junior Member
BBEEP's Avatar
Originally Posted by va72c10 View Post
that'll probably work out great....just hope they don't whistle like they sometimes do in the vac...but that's usually from the greater air flow and stuff getting stuck in them..
lol!!!
Old 01-31-2012, 01:47 AM   #441
OrrieG
OrrieG's Avatar
Might try 60's VW fan shroud to head tin duct, it flexible metal.
OrrieG is offline   Reply With Quote
Old 01-31-2012, 03:01 PM   #442
_Ogre
_Ogre's Avatar
bbeep: just went thru your build, amazing/awesome/insightful/mad fab skills.
shop air compressor timer
Old 01-31-2012, 05:16 PM   #443
BBEEP
Junior Member
BBEEP's Avatar
THANKS! Can't take credit for the skills. The old guy in the pics (everyone 10 years older than me has been referred to as 'old guy') has done the bodywork for me since '78. Guess that makes me an old guy, too!
But so far, my ideas!
Old 02-19-2012, 10:12 PM   #444
BBEEP
Junior Member
BBEEP's Avatar
Cowl filled, defrosters installed, 'Specialty Power' windshield wiper mechanisms installed.
Old 02-19-2012, 10:29 PM   #445
texacokie
texacokie's Avatar
Nice job it is really taking shape!
1971 chevy truck
2011 Chevy Camaro
1970 olds cutlass convertible
1966 ford galaxie "7-litre"
texacokie is offline   Reply With Quote
Old 02-27-2012, 02:45 PM   #446
BBEEP
Junior Member
BBEEP's Avatar
Around the windows, cowl, and interior with the first coat of primer.
The top goes back on, with 2-3 inches sectioned out, this week.
The interior metal, including the window surrounds, will be painted the accent color rather than upholstered. The side glass will be glued in.
Old 02-27-2012, 04:36 PM   #447
Pop's C-10
Pop's C-10's Avatar
sweet
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-27-2012, 04:37 PM   #448
_Ogre
_Ogre's Avatar
what did you think about those wipers? install pretty straight forward? i saw an article on them a while back, they looked pretty nice.
i may be doing a frame off with a friend on his wife's 50 ford truck, thought about using them there.
custom classic trucks has a task force, 3'' top chop in their current issue, looks good too.
Old 02-27-2012, 06:36 PM   #449
BBEEP
Junior Member
BBEEP's Avatar
OGRE, wipers were very straight-forward. I used Raingear in my 48 GMC Panel and they work very well, but you have to modify the cowl-vent handle. With the Envoy firewall, dash, defrost, etc that style or original wouldnt work. Didn't like the escutcheons(?) and had to fabricate some. They are adjustable from about 70 to 120 degrees if I remember right.
A friend of mine has used them on three completely different rigs and loves 'em. I haven't wired them yet.
Did you notice the wipers were moved out about 3"? This kit allowed that. Had to make room for my 'hi-tech' defrosters . . .
Old 02-28-2012, 01:15 PM   #450
_Ogre
_Ogre's Avatar
it takes a craftsman to use craftsman
thanks for the wiper feedback
suburban
