Old 05-01-2017, 10:19 PM   #426
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1961 Crew Max
Quick update. Got a 2003 denali rear axle. We were able to take all the brake parts off and with the purchase of new weld on flanges now have 13" rotors with dual piston aluminum calipers and internal E-brake. You can probably use this setup on anything with a 3" axle housing or bigger if you run 17's or larger. The other good thing is we were able to reuse the massive 1 1/8" rear sway bar with no modifying. We are going to make some mounts to weld onto the outside of the frame to reinforce the end link mounts. Only had to buy adjustable end links and bushings and straps. I think this would also be able to be used on factory trailing arms.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-01-2017, 10:41 PM   #427
youngrodder
youngrodder's Avatar
Re: 1961 Crew Max
Looks good Chizzler. It's nice when things work out..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-01-2017, 11:15 PM   #428
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Nice so all the brake parts are from a Denali?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-02-2017, 12:40 AM   #429
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Yes. Seems like all the parts crossover to suburban, escalade, yukon, tahoe.
61-crew cab D-max
Old 05-02-2017, 09:32 AM   #430
66ChevyMax
66ChevyMax's Avatar
Re: 1961 Crew Max
That is sweet!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 05-02-2017, 10:30 AM   #431
65sub
65sub's Avatar
Re: 1961 Crew Max
Looking good Chizzler
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 05-02-2017, 05:29 PM   #432
rusty76
rusty76's Avatar
Re: 1961 Crew Max
Getting there. Very nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-11-2017, 12:54 PM   #433
daddyjeep
daddyjeep's Avatar
Re: 1961 Crew Max
I am sure you are on top of this, but does the "hoop" in the sway bar interfere with the drive shaft when it is fully aired up? It is hard to tell in the pics.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-11-2017, 01:54 PM   #434
62stepside longbox
62stepside longbox's Avatar
Re: 1961 Crew Max
^^ I was wondering about that as well, seems like when the axle moves away from the frame the Swaybar will pivot on the bushings and rotate causing the loop to come upwards towards the driveshaft. But maybe there's something we're missing.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 05-11-2017, 09:29 PM   #435
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
The sway bar is very close at fully aired up. We have it set right now to be parallel at ride height. we still have some adjustment. At fully aired out the ends are about 4" from hitting the ground. Now if I wasn't running the bigger firestone F9100 bags it would probably be fine. We started Getting ready to mock up some exhaust from the down tube on the turbo and quickly realized we had to cut it and rotate it to be able to fit the V-band. The 4" stainless will just clear the top of the frame and travel along the outside of the frame next to the cab supports with some minor cutting. More pics will come soon. CHIZZLER
61-crew cab D-max
Old 05-12-2017, 08:39 PM   #436
lower50's
lower50's's Avatar
Re: 1961 Crew Max
I loved building my exhaust, gets you excited to hear what it will sound like.
1951 MG TD
Old 05-13-2017, 03:50 PM   #437
RKS0069
RKS0069's Avatar
Re: 1961 Crew Max
Looking amazing! I have dreams of putting a first gen DMAX in my '62.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline   Reply With Quote
Old 05-23-2017, 09:58 AM   #438
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
We got started on running the 4" stainless over the weekend. We cut and rotated the end of the down pipe to aim it right over the frame.The factory stainless flange that connects to the down pipe was re-used with a v-band. We only used 2 fittings to get it to the outside of the frame. Had to modify the front cab support just a bit to keep everything above the rockers. Now waiting on A couple more v-bands and A weld in flex pipe at each end. The exhaust pass through is made by Goliath Exhaust and will be just in front of the back tire at the bottom of the bed side. More to come CHIZZLER
61-crew cab D-max
Old 05-23-2017, 04:08 PM   #439
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1961 Crew Max
That looks really nice!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-25-2017, 02:14 AM   #440
lower50's
lower50's's Avatar
Re: 1961 Crew Max
That is similar to how I ran mine Are you going to wrap it?
1951 MG TD
Old 06-30-2017, 10:46 AM   #441
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Well just wrapping up a few things before we blow this thing apart. Cut down oil pan and pickup tube to keep it above the frame rails. Finished the exhaust out the bed side. Lots of final welding once its of the frame. CHIZZLER
61-crew cab D-max
Old 06-30-2017, 01:00 PM   #442
tinydb84
tinydb84's Avatar
Re: 1961 Crew Max
Man, I love the work you are doing. You are very talented.
David
Instagram: myfabguy
Old 07-03-2017, 08:18 PM   #443
Dieselwrencher
Re: 1961 Crew Max
Very nice! I love the V bands too. I got a bunch off ebay for my 40. I hope they don't turn out to be garbage.
Ryan
Old 07-08-2017, 01:39 AM   #444
namloc
namloc's Avatar
Re: 1961 Crew Max
Very nice.Almost ready to run hard and stop fast.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 07-08-2017, 07:41 PM   #445
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1961 Crew Max
Agreed!! Its been a fun build to watch.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-08-2017, 09:07 PM   #446
Advanced Design
Advanced Design's Avatar
Re: 1961 Crew Max
Continued nice fab! Great work Chizzler.
Advanced Design is offline   Reply With Quote
Old 07-10-2017, 08:37 PM   #447
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Oh wow I like it.
1951 MG TD
Old 07-10-2017, 11:57 PM   #448
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Yesterday was a fun day. We finally got the big girl outside to stretch out. The side view makes this think look really long. We couldn't even push it from the gravel back to the shop. Had to pull it back in with the tractor. Decided to do something different and welded the headlight trim rings to the grill and closed up the holes. I guess were getting to the next phase of a quick re- blast and epoxy the whole thing. I brought the motor/trans and bed home to do some cleaning and fit the bed wood. I really don't want to pull this motor apart but want to get it clean. I've read a lot of good results with simple green automotive so I'm going to try that first. Lots of welding to do on the frame still but that will be after body work is mostly done and before paint. Thanks everyone for checkin this WTF did I get myself into build. CHIZZLER
61-crew cab D-max
Old 07-11-2017, 03:01 PM   #449
lower50's
lower50's's Avatar
Re: 1961 Crew Max
If it makes you feel better I can't push mine either. Have you measured how long it is?
1951 MG TD
Old 07-11-2017, 03:24 PM   #450
Dieselwrencher
Re: 1961 Crew Max
It looks so nice setting near the ground! I dig it!
Ryan
