Old 11-27-2005, 11:09 PM   #1
Green Machine
Green Machine's Avatar
Sport Mirror Problem - Help !
Bought a pair of repro sport mirrors for our 70 C10. Did a trial fit/measure up before drilling any holes, driver side will be fine. Passenger side measures about 8 inches back from front of door to front hole of mirror, approx factory location, mocked up mirror as high as possible as backing plate will allow before hitting bodyline ridge above it, best location is about 1/2 inch farther back than factory location, as none of the top of the mirror is blocked by the vent window channel.
Even mounted as high as possible a little of the bottom inside corner is still blocked by the door, and a bigger problem is the the mirror cannot be tilted inward far enough to even catch a slight view of the bedside, the mirror nearly hits the base and runs out of swivel at that point. I like to see just the slightest hint of bedside in the mirror for an idea of where things are in relation to the truck.
I bought these mirrors from Chevy Duty and they seem to be good quality. Does anyone have any adjustment suggestions or should I try a different brand ? Or is that about as good a view as you (or anyone else) can get with the sport mirrors ???
Any good looking mirror options ??? Thanks in advance.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
