Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 01-19-2008, 04:41 AM   #26
Jamie @ Doug Thorley
Re: '67 project nightmare ls1 swap
Originally Posted by Hart_Rod View Post
I used the ECE motor mount setup in my 2 builds. Any idea if your headers will work with them? If you want to send me a set, I'll test fit them for you, . Supposedly Sanderson was working on a set, but it's been almost 2 years.......
That is a possiblity on the test fit.
The builder of this truck used Classic performance products p/n 6372mp-t perch kit, cpls1-k plate adapter kit and the cp9427 crosmember kit. The motor mounts to be used are 59-70 passenger car mounts (chevy). He went with the 4L60 trans with the gear vendor unit. When we are close to completing the first product run, I will be in touch with you Rob.
Here is a couple of pics of the perches...
Jamie @ Doug Thorley is offline   Reply With Quote
Old 01-19-2008, 05:02 AM   #27
Hart_Rod
Hart_Rod's Avatar
Do you have a picture of the oil pan and front crossmember clearance? Just trying to get an idea of the relative engine placement as compared to mine.
Hart_Rod is offline   Reply With Quote
Old 01-19-2008, 05:09 AM   #28
Give me a few minutes and I will go snap a couple pics for you.
Jamie
okay, here are the pics of the oil pan-x-member clearance. You're looking at around 1 1/4" from the bottom of the pan to the top of the x-member. The main sump of the pan has about 1" around the rear of the x-member. The pan is a milodon. Hope this helps.
Old 01-19-2008, 08:14 AM   #29
Bump, new pics added.
Old 01-19-2008, 09:22 AM   #30
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome from Missouri. Always great to have new vendors here. This is a little off topic,... But I need a set of "shorty" headers for a big block chevy in a '73-'87 truck. Do you offer a product for this application? (ceramic coated?) Thanks for joining the forum.
Keith
Convert to disc brakes.
Old 01-19-2008, 09:34 AM   #31
We have a block hugger style header that may work. Shoot me a PM w/ your email addy and I'll see if I can dig up some pics/measurements for ya.
Jamie
Old 01-19-2008, 10:50 AM   #32
Hart_Rod
Hart_Rod's Avatar
Jamie
Did they have to change the pan because a stock one wouldn't work?
Old 01-19-2008, 11:04 AM   #33
Hart_Rod
Hart_Rod's Avatar
Here's some pictures of the a/c and power steering pump placement.
Old 01-19-2008, 11:39 AM   #34
cstanley
cstanley's Avatar
welcome from Dallas!
those are some sweet-lookin' headers. I'm glad someone is finally on this. I plan to get a set when the time comes.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 01-19-2008, 12:02 PM   #35
I don't think so. I've read through cpp's instructions and I didn't see any mention of an aftermarket pan. I will double check when I get back in the office though.
Old 01-19-2008, 12:04 PM   #36
Thanks!
Old 01-19-2008, 12:46 PM   #37
68 short step
so what kinda cost are these gonna run, coated version is what im instrested in...also any plans on makeing them 4 tubes in addition to the tri-y design?
also i have done these swaps, and am currently doing one as well..please put me inline for a trial fit too, like hart_rob
68 short step is offline   Reply With Quote
Old 01-20-2008, 12:45 AM   #38
I don't have pricing yet, it's coming though.
I will just stick to the tri-y design right now. I don't know what you plan to do with your truck but the tri-y method is great for trucks and puts the power right where you will need it, in the low to mid range.
Jamie
Old 01-20-2008, 01:23 AM   #39
Custom 68
Custom 68's Avatar
Wow and welcome I too am interested in the headers I have already done the swap and am using a set of ls6 manifolds in my swap, but I understand the long tubes are a worth while addition. I built custom mounts and sat mine as far back and down as possible. your pictures are great but I am still not sure what might fit on mine.
again thanks and welcome
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-20-2008, 02:01 AM   #40
Dave
Thanks for the welcome Dave. If there are other shots I can take let me know. I can tell you that there seems to be an awful lot of room between the back of the engine and the firewall. The engine seems to be about as low as it can go and the pan is sitting real close to the top of x-member. There is about 1 1/4" between to two components. When I designed the headers, I decided to leave alot of room between the back tubes of the header and the firewall because I figured that guys would want to engine as far back as possible so there might be a good chance these will fit. We'll keep working on it.
Jamie
Old 01-20-2008, 02:03 PM   #41
Liz
Catchy title goes here..
Liz's Avatar
Welcome Jamie, its good to have you here.
Liz is offline   Reply With Quote
Old 01-20-2008, 04:04 PM   #42
Cyclone44
Step Brother
Cyclone44's Avatar
from Knoxville Tn....
Cyclone44 is offline   Reply With Quote
Old 01-23-2008, 06:18 AM   #43
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
from South Texas!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 01-23-2008, 12:34 PM   #44
pcmcobra
pcmcobra's Avatar
I'm gonna get those pics to you, soon!
Bump for this thread, it's on the doug thorley website also!
http://www.dougthorleyheaders.com/news/8/
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 01-23-2008, 12:58 PM   #45
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
great info....subscribing!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-27-2008, 06:38 AM   #46
A little teaser in ceramic....
Old 01-27-2008, 07:25 AM   #47
BACKYARD88
BACKYARD88's Avatar
OOOhhhhh, AAAAhhhhhh
-Mike Owen-
Old 01-27-2008, 07:57 AM   #48
cstanley
cstanley's Avatar
oh heck, yeah!
Old 01-27-2008, 11:31 AM   #49
70cst
70cst's Avatar
Ok...1st and on becoming the newest member to this family. You will find this site more than a bunch of truck enthusiast...but an extended family where all trucks and their owners are treated with respect. Well at least 99.99% are
Those headers...will they fit a 402BB?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-27-2008, 11:59 AM   #50
Custom 68
Custom 68's Avatar
those would look good under my hood!
good looking parts for sure
Dave
