02-19-2008, 03:11 PM | #26 |
Re: Project Big Brother!
Here are some fenders still atached to a bed for sale, probably cheap.
http://chico.craigslist.org/pts/575995872.html |
02-19-2008, 04:15 PM | #27 |
Luv the Crewcabs
I think this will end up being your Best Creation to date, Really looking forward to the Start of the Build. Do u have a Projected Time for the Start?
Thanks for making my & I'm sure several other's Dream Truck............... Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
02-19-2008, 08:29 PM | #28 |
The truck was on the cover (I think the Burb was too.) I've got it in ABQ, I'll post the issue when I get back there tomorrow, if you haven't figured it out by then.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-19-2008, 10:09 PM | #29 | |||
Kevin LFD Inc. |
02-20-2008, 02:47 AM | #30 |
I like the rear fenders in the first pic, not the second. And of coarse yours will have a 4th door and a better roofline.
02-20-2008, 03:19 AM | #31 | |
Thanks for the pic's! Kevin LFD Inc. |
02-20-2008, 04:06 AM | #32 |
how much more does the diesel weight? including turbos of course
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
02-20-2008, 04:26 AM | #33 |
2wd FTW!!!!
What Front Clip Are You Going To Use?
02-20-2008, 08:34 AM | #34 |
02-20-2008, 09:42 AM | #35 |
And not even a tip or any goodies to eat.
02-20-2008, 10:14 AM | #36 |
Life, Be In It.....
I found an old pair of steps for the step fenders. You can have them if you want them. They may be good for another project down the road. They were the ones we had on lemon drop's bed when you were doing the body work. They have been blasted and are in primer.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 02-20-2008 at 10:55 AM. |
02-20-2008, 10:41 AM | #37 |
im real excited to see this build. this sounds like the dream truck ive been building in my head for so long. ive watched every build you've done and im very impressed by your work. im only 20 and ive grown up around rebuilding old cars/trucks with my dad and i really look up to you and your work cause i know what it takes. and someday id like to be on your skill level. good luck on this project, i cant wait to the progress...
02-20-2008, 11:05 AM | #38 | ||
Kevin LFD Inc. |
02-20-2008, 12:26 PM | #39 |
02-20-2008, 12:49 PM | #40 |
A guy with a truck
Another one of my ideas down the tubes. At least I know you'll do it justice.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-20-2008, 08:53 PM | #41 |
So with only 250 lbs more, why the need for beefer rack and pinion?
02-20-2008, 09:07 PM | #42 | |
I belive it is due to the total weight of the finished vehical and the direct weight on the steering axel it self. The standard rack used is over rated for the standard truck set up but comes right to the edge of what I am looking at doing. I also have plans for towing an enclosed 28' trailer that I figured into the use of this vehical when I went to Nate for advice. So if this was just going to be a lowered street vehical with out trailer use it would be fine but very close. I am sure Nate can explain it better but one thing I know is if he is not comfortable with it he will not sell it to you. This is why he wanted to know about the end use as well as the full vehical build before he gave me advice. At first I only asked if a drop member would work for a dually then he came back wanting to know more. Kevin LFD Inc. Last edited by Rokcrln; 02-20-2008 at 09:10 PM. |
02-21-2008, 01:30 AM | #43 |
Man o man, kevin! What happened to thinning the herd?
Looks like a great start to your project. The 4th door sounds awesome. Frizzle has the "tahoe" and you've already made a 4th door crew cab out of a burb (even if you didn't "start" the conversion) so why rehash what's already been done You like to be an innovater... so how's this sound... 68 front clip. Your turn signal mod. 4th door mod. Here's the kicker.... 1967/68 AVALANCHE. It might be cooler in my head than in real life... get a burb gate that goes down (the one like a tailgate) and cut the body off below the window line, close off the back of the "cab" with a truck cab, finish off the top of the "bedsides" with top rails from a 67-72 bed, or better yet graft a whole 67-72 bed end onto the burb, tailgate and all... Sigh, I wish I had skills to do this and not live through others *Just thinkin' out lout 'cause I know you have the skills to do it. You're plans for it are really awesome
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-21-2008 at 02:18 AM. |
02-21-2008, 07:50 AM | #44 |
1972 Chevrolet SWB
Your new project sounds killer. Nice to see you not take any time off between projects and have more to work on that can keep you busy.
I am liking the idea of a Suburban turned into a 4 door like an Avalanche which is what I kind of translated this build into at first. I may be reading into this wrong but are you doing a 4 door truck,with a separate bed with dually fenders OR a 4 door Suburban (avalanche style) with dually fenders?? I will be watching for new build threads. Oh and thanks to all of you for the motivation to get working on my project again finally.........dont know where my head has been lately but I will really appreciate the sound of a thumping small block counting off at an intersection again here before too long..
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-21-2008, 08:50 AM | #45 | ||
Kevin LFD Inc. |
02-21-2008, 09:04 AM | #46 |
1972 Chevrolet SWB
Gotcha,I think redneck and I were thinking along the same lines.
I remember a deep maroon late 90's Tahoe that was done up like an Avalanche in a mag once.
02-21-2008, 10:41 AM | #47 | |
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-21-2008 at 10:41 AM. |
02-21-2008, 09:53 PM | #48 | |
Sounds like you're going to do a "small" fender addition like the older sierra denalis? I always thought that was a cool touch GM added to those trucks. WOW! It was THAT long ago? That's one of the best looking trucks I've ever seen. I wanted a "crew cab" after seeing that truck!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-21-2008 at 09:56 PM. |
02-22-2008, 01:54 AM | #49 |
I'm diggin that. I like the look of super short beds as long as they are seperate and on this thing with the long cab and mini-dually fenders it would look awesome. We need a rendering!
Edit: Always liked this super-shorty; just add a crewcab and your mini-fenders... Last edited by Frizzle Fry; 02-22-2008 at 02:13 AM. |
02-22-2008, 07:37 AM | #50 | |
I havw been checking around and I might just find a rolling 73-88 crew cab dually frame for this build as it would be much beefier than the 1/2T burb frame. I really want the diesel power so I want to make sure everything else is up for the task. Kevin LFD Inc. |
