Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-18-2009, 10:40 AM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
What comes with the efi tanks?
R/
Hart_Rod is offline   Reply With Quote
Old 09-18-2009, 10:45 AM   #27
Daveboyd
Daveboyd's Avatar
R/
everything except the fuel level sending unit, and whatever mounting hardware needed
Pumps used are the walbro 255lph
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 10-01-2009, 01:56 PM   #28
VA72C10
VA72C10
VA72C10's Avatar
How many would we need for a group buy and what type of prices are you thinking?
Also, do you have a supplier for the 90 ohm sending unit where you could add that to the cost or do we just purchase that on our own?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-02-2009, 04:37 PM   #29
msgross
msgross's Avatar
FYI the first tanks is mine that we did from an earlier group buy. I made a powerpoint slide with all the dimensions. (I attached the file, simply download and open)
The sizes could be tweeked a little to fit your frame...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-05-2009, 09:06 AM   #30
Daveboyd
Daveboyd's Avatar
well lets see how many are interested and ill see what i can do.... BUMP THIS THREAD IF YOUR INTERESTED!!! if we can get a decent number ill work an even better price than what i already offer which has not been beat yet.
the sending units will be up to you to purchase on your own.
Dave Boyd
Old 10-05-2009, 09:30 AM   #31
71cadc10
71cadc10's Avatar
I will commit on a EFI tank, for the group buy (if it happens).
I need to measure a few things and decide on the fill neck.
which walbro pump specifically you adding? Can you put a GSS342 (this is a higher pressure version) ?
Andy
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 10-05-2009, 11:52 AM   #32
Daveboyd
Daveboyd's Avatar
Andy
Great!!! Yes our standard pump is the WALBRO 255LPH PART# GSS-342.
THAT'S 1... I CAN HEAR THE PRICE COMING DOWN ALREADY.
Dave Boyd
Old 10-05-2009, 11:56 AM   #33
VA72C10
VA72C10
VA72C10's Avatar
I am in pending final pricing and if I can get the inlet turned 90 degrees to allow me to set up my fill in the stake pocket. Won't need a cap.
Old 10-05-2009, 01:42 PM   #34
Daveboyd
Daveboyd's Avatar
I can put a 90 deg filler on it instead no problem.
THATS 2.... KEEP IN MIND IM THE MANUFACTURER SO WE HAVE THE FLEXIBILITY TO MAKE MINOR CHANGES AS NEEDED. YOU WILL NOT GET A BETTER DEAL ANYWHERE.
Try to let me know which tank you are in for. the EFI or the STANDARD we will sort out the small details like fillers and fitting sizes later.
Dave Boyd
Old 10-05-2009, 07:41 PM   #35
msgross
msgross's Avatar
Dave..
I know your deal doesn't include a sending unit but I think it would be better if you had an exact unit to recommend to the buyer, or included one for the additional cost. The 67-72 take a 90 ohm but I think 66 and older take a different style. (30 ohm?)
This would make sure that they purchased one that fits your flange perfectly, the one I purchased from JC Whitney was slightly off from your flange, the holes were.
The Garage:
Old 10-05-2009, 08:18 PM   #36
gcsupraman
gcsupraman's Avatar
Originally Posted by msgross View Post
Dave..
Thank you! I was actually thinking it would be nice if you offered the sending unit, fuel lines, a few different fill hose options etc as an add on to your tanks. It would be alot easier for those of us who don't know exactly what pieces to buy to pull the trigger.
-Greg
gcsupraman is offline   Reply With Quote
Old 10-05-2009, 10:09 PM   #37
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I'd be interested in a standard tank.
Zoomin is offline   Reply With Quote
Old 10-05-2009, 11:15 PM   #38
msgross
msgross's Avatar
-Greg
Dave will customize you tank but you need to let him know what you want and he'll get back with you... Overall i'm happy with my tank that he built, very clean welds and sturdy... his QC is a little better now I think since mine had a lot of metal shavings that needed cleaned out, but that's an easy fix with a screwdriver and some Vaseline..
The Garage:
Old 10-05-2009, 11:29 PM   #39
dan42
dan42's Avatar
How are you attaching the tank to the frame - are you drilling the frame?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-06-2009, 04:26 AM   #40
Daveboyd
Daveboyd's Avatar
Dave..
i would like to supply the senders or at-least give information on the correct ones for your applications. truth is i have no idea what you require either. The only senders i am familiar with are 0-90 ohm and 30-240 ohm
heres a jc whitney SunPro 33-240 ohm adjustable universal sender
http://www.jcwhitney.com/jcwhitney/p...questid=200348
heres a 0-90 ohm sender from e-guages
http://www.egauges.com/vdo_indS.asp?...90ohms&PN=SN38
both of those senders will fit my flange. also you can always have the sender drop shipped to me and ill install for free.
as for the sunpro sender. every one that i have ever installed or bought has fit perfect. My sending unit flange's bolt pattern only goes one way. all aftermarket senders with a 5 bolt pattern will fit it this flange as it is a US Standard pattern.
I will attempt to do a video here in the next couple days on installing a sender.
Dave Boyd
Old 10-06-2009, 04:27 AM   #41
Daveboyd
Daveboyd's Avatar
Originally Posted by zoomin View Post
i'd be interested in a standard tank.
thats 3.....
Dave Boyd
Old 10-06-2009, 04:53 AM   #42
Daveboyd
Daveboyd's Avatar
Thanks for bringing that up mike... Yes as mike said every tank can be customized to fit your specific needs, however i would prefer not to change the dimensions too much on the overall tank size. If that is a must please call me to discuss your options.
Our Quality Control processes have evolved a ton since then. I have added another inspection into our fabrication process which addresses metal shavings in the tank and metal shavings around the openings. We have also began to practice and adopt ISO Quality Standards.
Dave Boyd
Old 10-06-2009, 04:57 AM   #43
Daveboyd
Daveboyd's Avatar
Our Mounting angle come un-drilled to give you flexibility. I would assume that drilling the frame rails is an option but i think that question would be answered better by MSGROSS as i am unsure of the exact procedure required.
Dave Boyd
Old 10-06-2009, 08:29 AM   #44
msgross
msgross's Avatar
I am using existing holes in the frame to mount mine, since dave sends the flagnes "undrilled" as he stated you can make any adjustments and mount it exatly where you want. You might have to drill a new set of holes if you want extra support, really depends on your frame though since they are all a little different (LWB, SWB, 2WD, 4WD etc..)
I also plan on adding rubber spacers to isolate any vibrations that could cause stress cracks over time.
The Garage:
Old 10-06-2009, 11:24 AM   #45
silver7
silver7's Avatar
Hey fellas, count me in on the group buy. My frame will be powder coated soon and will be screaming for one of these upon return!
silver7 is offline   Reply With Quote
Old 10-06-2009, 11:27 AM   #46
silver7
silver7's Avatar
Standard, non EFI tank for me please. Thanks.
Old 10-06-2009, 12:19 PM   #47
Daveboyd
Daveboyd's Avatar
Originally Posted by silver7 View Post
standard, non efi tank for me please. Thanks.
thats 4 ... Im working the new prices as we speak and will post them soon.
Dave Boyd
Old 10-06-2009, 01:20 PM   #48
Daveboyd
Daveboyd's Avatar
OK normal advertised price for standard non EFI tanks are $388 shipped to your door and EFI tanks are $649.00 shipped to your door.
2009 BOYD GROUP BUY ONLY PRICE
STANDARD TANKS 299.00 + 39 SHIPPING
EFI TANKS $499.00 + 39 SHIPPING
Dave Boyd
Old 10-06-2009, 01:45 PM   #49
silver7
silver7's Avatar
Awesome deal! What's the next step?
Old 10-06-2009, 04:16 PM   #50
VA72C10
VA72C10
VA72C10's Avatar
Quick question...how much gap between the top of the tank and the bed cross sill ( meaning can the side tabs be moved so that the tank sits a little higher and tucks even more up under the truck without coming into clearance issues with a bed crossmember)
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
