03-01-2013, 09:46 PM | #26 | |
Re: LFD's How-To "PorterBuilt Hood Hinges"
Were these changes added to the ones being sold now?
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
03-02-2013, 05:19 PM | #27 |
These changes were made:
The driver side hinge pocket has a notch in the back side of the bottom to distinguish it from the passenger side. The hood plates mounting holes were modified for an easier install. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-07-2013, 02:13 PM | #28 |
This little spring is the perfect solution to popping the hood up when using the Porterbuilt hinges. They are offered by member Pickemup. http://67-72chevytrucks.com/vboard/s...d.php?t=541980
///Relaxed Atmosphere |
12-27-2015, 10:44 PM | #29 |
I had to modify minds? What a pain in the ahhh! My fire wall had a slant to it, so hinges had to be cut to fit flush, anybody else have that prob? Fits like a glove now:-)
12-27-2015, 10:49 PM | #30 |
....other than that little roadblock I love the product
01-01-2016, 08:06 PM | #31 |
How much are these now , are they still around ?
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
01-01-2016, 09:31 PM | #32 |
67-72 parts collector,…
01-13-2016, 12:23 AM | #33 |
My firewall has a slight slant. I bought my hinges at a swap meet so I assumed they were 'fake' PB hinges since they didn't fit quite right. Looks like you had the same problem I'm seeing with mine so I guess I'll wind up doing the same modification. I moved on to another part of the project so I'll get back on the hinges now that I see I'm not the only one in the boat.
Too many dreams, too little money. |
01-13-2016, 01:55 AM | #34 |
Are you sure the top of the cowl is not dented causing the front of the PB hinge pocket to lean away from the front of the firewall?
I havent heard of anyone having trouble installing these before now. I know mine went in SUPER easy. Also,... before I would cut the PB hinge pocket apart, I would shim under the bottom to make it fit the front of the firewall.
01-13-2016, 09:50 PM | #35 |
Subscribing just so I can find it easier later on
______________________ www.northeastrodrun.com |
01-13-2016, 10:27 PM | #36 | |
Last thing, if you already have a painted truck and you don't want to weld the hinge mounting plate to your hood, I sell bolt on hood brackets that allow you us use the PB hinges without welding: http://67-72chevytrucks.com/vboard/s...d.php?t=679945
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-17-2016, 08:52 PM | #37 |
Nice work now I see why my driver side sit higher
07-15-2016, 07:59 AM | #38 |
Subscribing. Nice write up, visual learner here.
01-30-2017, 07:19 PM | #39 | ||||||||
I just spent last weekend installing this kit, so I'm going to update this article from 2009 to 2016/2017 so everyone is aware on what to expect when they spend $440 on PB Fab hinges.
First of all I want to thank Paul (LFD) for taking the time to put together this awesome original thread/"instruction manual" since this kit comes with no paperwork. I have taken Paul's quotes and added my notes to them. I hope it helps others out when installing. Quote:
So overall a great kit. My hood opens and closes very smooth for the first time since I have owned the truck. However I wish they would fix the few, little, and easy to change issues to make the kit perfect and drop the price to the $300 range.. $440 seems high for what you get. I hope my notes and pictures helps to simplify this installation for others. Chad Last edited by chadzilla500; 01-30-2017 at 07:24 PM. |
02-01-2017, 06:32 AM | #40 |
This overall a good kit, however just like every other "kit" this requires some work to make it fit each application. The manufacturing tolerances back in the day were far from good on these trucks and can account for the challenges listed earlier in the thread. The issues with having to chase the threads may have to do with the heat during welding, its and easy fix but it would be nice if they did it before shipping. Still the best solution I have seen for hinges.
02-05-2017, 11:14 AM | #41 |
Where did you place shims when fitting the hood? |
02-05-2017, 11:27 AM | #42 |
11-04-2022, 11:12 AM | #43 |
Mine also has a slant on the driver side -- I was planning to remove the spot welds and adjust the cowl square but your solution seems way easier
1968 LWB C20 / AC / Wood Bed |
