Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer > projects and builds
Old 01-30-2013, 01:32 PM   #26
robnolimit
robnolimit's Avatar
Re: Pro-Touring S10
Are you wondering, Why are we taking off the bed sides? To put new ones on of coarse. We want to run 335-30-18's, all the way around. This will never work on a normal S10. So, we're going FAT. We go some 4" wider, 2" up bedsides and fenders from Superior Glassworks. Yep, Off-Road stuff. The four parts cost about $800 bucks. We were very carefull pulling the stock bedsides, and got $200 for the sides and stock front fenders, all in good shape.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-30-2013, 01:54 PM   #27
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Pro-Touring S10
That's going to look aggressive !!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-30-2013, 10:38 PM   #28
robnolimit
robnolimit's Avatar
Re: Pro-Touring S10
Bits more progress today. This is a budget build, and we're trying to keep it mostly a bolt-together build. So far I don't think we've done anything that is too tough for the average guy. We definately need to drop this thing, a lot. The amount of spring drop is limited som ewhat, we want to try to keep the lower A-arm level, so slamming the spring is out. We can get about 2 1/2" from the spring. We also need better brakes than the S10 is able to give. So here's the experiment. "92 - '96 Impalla 2 1/2" drop spindles. They use a 12" rotor and a full size GM floating caliper. The good news is, total bolt-on. Ball joint and tie-rod fit and taper are the same. They just bolted right on. But, there is some bad news. The pin inclination is not the same, so it forces some positive camber, no good. Also, the upper ball joint angle is not so good, this is from the spring drop. I'm going to look for a bolt on upper A-arm to fix this. Sprindles, $229, rotors, $118.80, so far, so good.
Old 01-30-2013, 10:46 PM   #29
ryanroo
ryanroo's Avatar
Re: Pro-Touring S10
the fenders will look sweet when its on the ground!
ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-31-2013, 07:57 AM   #30
98layinframe
98layinframe's Avatar
Re: Pro-Touring S10
Thats a semi common spindle swap in the s10 community, i cant remember off the top of my head the name of the companies that sell the 1" narrowed "B body tall spindle swap" upper control arms. My buddy has that setup with tubular uppers, lowers and coilovers on his first gen and loves it.
What brand are those rotors and where'd you get them? Im liking the dual bolt pattern so they can be converted back to the s10 pattern.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 01-31-2013, 09:27 AM   #31
Street Smart
Street Smart's Avatar
Re: Pro-Touring S10
Very interesting build, I`m along for the ride.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 01-31-2013, 12:40 PM   #32
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Re: Pro-Touring S10
Im in
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 01-31-2013, 12:43 PM   #33
theastronaut
theastronaut's Avatar
Re: Pro-Touring S10
I like the direction this is going! Dad has a '97 SS/ZQ8 with a 4.3 and 5 speed that I'd like to have when he decides to sell it.
theastronaut is offline   Reply With Quote
Old 01-31-2013, 03:07 PM   #34
98layinframe
Re: Pro-Touring S10
Also i forgot the mention.. the steering arm on the b body spindle sits lower so it introduces more bumpsteer into the system. You have a few options, can run the proforged taller lower balljoint (lowers the truck 1/2" more too) and if necessary run an adjustible height outer tierod that replaces the factory tierod with the tapered bolt and then regular heim joint.
Also one last thing, for anyone wanting to do this swap and dont want fancy dual pattern rotors, you can buy stock replacement 89-92 camaro 1le rotors. They have to be the 1le setup size!
Old 01-31-2013, 05:00 PM   #35
robnolimit
robnolimit's Avatar
Re: Pro-Touring S10
Thanks for the tips. The rotors are ours, from our Wide-Ride IFS, they use the impalla 12" gear. We have the rotors made with the dual pattern, makes it easier on the customer. - list is 73.50 each. Good to know the info on the other stuff. thanks.
Old 02-01-2013, 06:28 PM   #36
OLDIRON69
Re: Pro-Touring S10
Love the Pro Touring anything! I'm in..
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 02-07-2013, 09:22 AM   #37
sixtyeightchevykid
sixtyeightchevykid's Avatar
Re: Pro-Touring S10
nice build, im watching this for sure
1968 chevy c10 lwb, 250 inline6, 4 speed,
sixtyeightchevykid is offline   Reply With Quote
Old 02-07-2013, 01:08 PM   #38
RS_Customs
Re: Pro-Touring S10
Cool stuff Rob! I have not been on here in years and a buddy told me about the project since I have similar plans for my 98 sonoma. I'll probably have some questions at RTTC if I can get away from the autocross timing table for a little bit lol.
Robert
RS_Customs is offline   Reply With Quote
Old 02-16-2013, 10:34 AM   #39
eldogg
eldogg's Avatar
Re: Pro-Touring S10
I like to use 98+ blazer spindle. It makes big brake swaps eazy!
eldogg is offline   Reply With Quote
Old 02-22-2013, 12:04 PM   #40
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Pro-Touring S10
I came here to suggest the pre runner fenders, good job. I've had this build in my head for a few years. I can't wait to see the finished product!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-23-2013, 11:50 PM   #41
cable666guy
cable666guy's Avatar
Re: Pro-Touring S10
Good stuff, as always, Rob...keep it up!!
cable666guy is offline   Reply With Quote
Old 03-06-2013, 05:38 PM   #42
bobski
bobski's Avatar
Re: Pro-Touring S10
Stumbled across this build checking out your other ones.. bump for updates!
bobski is offline   Reply With Quote
Old 03-31-2013, 09:25 AM   #43
duallyjams
duallyjams's Avatar
Re: Pro-Touring S10
Well 2 months and ............
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-02-2013, 12:12 AM   #44
5speedsilverado
Re: Pro-Touring S10
updates? really want to see prerunner fenders on a street truck
5speedsilverado is offline   Reply With Quote
Old 04-10-2013, 02:47 PM   #45
Wet..Paint
Re: Pro-Touring S10
I was going to suggest this! 11.8" Rotor I believe? As well as dual piston calipers! I'm running that setup on my hot rod frame. Are you going to disc brake conversion on the rear as well?
I really like the way this truck is going! It is going to look mean as hell!
Wet..Paint is offline   Reply With Quote
Old 04-11-2013, 10:38 AM   #46
98layinframe
Re: Pro-Touring S10
If your running a 98+ 2wd blazer spindle... you also have the incredibly easy route for running 13" c5 corvette and even crazier 14" z06 corvette rotors and calipers.
Old 05-30-2013, 12:12 PM   #47
robnolimit
robnolimit's Avatar
Re: Pro-Touring S10
We've made a bunch of progress. here's some updates.
The steering fix took two steps. 1. We moved the lower ball joint out 1.00" and forward .300" this fixed the camber and caster. We got weld in ball joint cups from Speedway, cut the arms with a hole saw, and welded the new sockets in, they use OE ball joints. 2. Next was to fix the bump steer. After much testing, we came up with the correct location for the inner pivit points. New mounts were made from 3/4" thick steel, same as the stock center link, drilled and tapered for the OE tie rod end, then welded to the stock center link. Not to high tech, but very effective. Static alignmentis -1* camber, +7* caster, 1/8" toe out. This has .057" total bump steer in 6" of travel.
Old 05-30-2013, 12:17 PM   #48
robnolimit
robnolimit's Avatar
Re: Pro-Touring S10
The engine fits, but it's tight. We swapped to an 8" dual diaphram booster and that helped. The engine is set back a bit, and the tunnel was modified to fit. E-Bay S10 swap headers were used, they're ok, but tight fit. I think OE camaro manifolds would fit better.
Old 05-30-2013, 12:26 PM   #49
aggie91
aggie91's Avatar
Re: Pro-Touring S10
That is a tight fit. You did not say anything about the sway bar mounted on top of the frame connected to the upper a-arms...Looks cool with those curved blade style arms.
Karl
The LST Challenge:
Old 05-30-2013, 12:27 PM   #50
robnolimit
robnolimit's Avatar
Re: Pro-Touring S10
The Front Sway Bar. Here's some info for ya. If you put a 335-30-18 on an S10, and actually turn the steering wheel, there is NO room for the stock style sway bar. None. So we tried to fit a splined bar in the stock location, - nope. Then we tried going under the lower arm, -nope. So, we tried this. It fits, yes. After the first test drive, the bar doesnt have enough effect on the suspension. I think we need to move the link and arm mount outboard, Right now it is at appx 50% out on the upper arm, not enough motion ratio. The bar is made of 1 3/8" x .188 wall DOM, with end cap plates welded on. the bar was then heat treated to normalize it. I have never done tthis before so it's a learning curve. I read a whole bunch about doing this, so we'll see. The arms are simple 3/8" plate steel cut out to fit, and bent in a press. Delron bushings and rod end links.
