11-02-2016, 01:28 PM | #26 |
Re: Window felt weatherstrip (beltline weatherstrip)
11-02-2016, 08:10 PM | #27 |
yes they did but I don't know what brand will have a set In 4 or5 days will let you know when they get hear
11-02-2016, 08:12 PM | #28 |
great thanks
11-05-2016, 01:55 AM | #29 |
I see them on the Brother's site for $29.99, but it doesn't say if this is for one or both doors. Do you know?
11-05-2016, 08:54 AM | #30 |
IDK about Brothers, but my truck was in an accident and I had to replace those fuzzies, I ordered a set from LMC and it came as a pair for both doors
11-05-2016, 08:54 AM | #31 |
11-05-2016, 01:06 PM | #32 |
We own a glass shop that specializes in older cars/trucks. A lot of times we make our own inner/outer wipes if we can't get the right parts. We also don't always use the supplied clips, but instead take them off and use #4 screws, 3/8" long with a countersunk head. We position the felt, clamp it in place, and drill a 5/64" pilot hole. The screw heads bury deep enough into the felt that you don't have to worry about the head of the screw scratching or breaking the glass. This lets you position the felt where you want it instead of relying on the clips to locate it. I just did this with my '66 C10 and it worked great; it actually pulls the felt tighter against the door so that there's more room for the bottom channel to fit between the felt and the glass is easier to roll up all the way. The channel fitting between the felt is normal on these trucks, but the felt has to be tight against the door and can't be to thick or else the channel won't fit. The holes that the clips fit into are usually messed up on these trucks as the bottom edge around the hole is really flimsy, so screws are usually a better way of fastening them.
I might be able to get the owner here to make a small batch of properly fitting inner/outer wipes within the next few weeks. They have a stainless bead that won't fade over time and we have jigs to properly shape them. We can also supply the correct screws if you prefer to use screws instead of clips. Link to the screws we use: http://www.dixied.com/product3979.html
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-05-2016, 01:41 PM | #33 |
[QUOTE=theastronaut;7761011]
I might be able to get the owner here to make a small batch of properly fitting inner/outer wipes within the next few weeks. They have a stainless bead that won't fade over time and we have jigs to properly shape them. We can also supply the correct screws if you prefer to use screws instead of clips. Link to the screws we use: I'd definitely be interested in seeing a set. Thanks, Randy |
11-05-2016, 03:40 PM | #34 |
Moderator
I haven't got my glass yet, but on this issue - could you buy like 1/4" or so taller glass and have it installed?
11-05-2016, 03:43 PM | #35 |
We cut flat glass so we could cut it taller... The problem with that is it wouldn't roll down all the way, the stop at the bottom isn't adjustable so you'll have the glass sticking up above the felt/door edge when it's rolled down all the way. If the proper felt is used the glass should roll up all the way.
11-05-2016, 05:19 PM | #36 |
I would be interested in a couple of sets. |
11-05-2016, 08:52 PM | #37 |
I don't understand the screw fastening you are describing. If the screws go into the same lip as the clips used to go into then how do you get a driver in the gap to set the screw? Do the screws go into both inner & outer flanges the clips used to go into? How do you drill the holes for the screws?
Thanks. |
11-06-2016, 06:45 PM | #38 |
I would like a set if that works out |
11-06-2016, 07:42 PM | #39 |
I tried to install the ones from brothers and they are the same as the ones from Steel Rubber products and LMC. They are all horrible. The clips they use are just the same and are impossible to remove without destroying the clips. I can not figure out why they don't even make the clips like the originals. They are also to long on the end that has the curve. So I had to trim it. This sucks. I am trying to install the ones that are meant for a 60-63. I wonder if the people that have had success with any of these products bought the ones for a 64-66.
11-07-2016, 09:27 AM | #40 | |
11-07-2016, 12:47 PM | #41 | |
What year are you ordering them for. The 64-66 might be awesome and the 60-63 horrible.
11-07-2016, 08:14 PM | #42 |
11-07-2016, 08:35 PM | #43 | |
I would be interested also. How do you drill the holes and screw in the screws inside such a thin channel? I would need them for a 60-63 though.
11-09-2016, 10:34 AM | #44 |
11-09-2016, 09:27 PM | #45 |
Moderator
11-09-2016, 09:51 PM | #46 |
11-09-2016, 11:29 PM | #47 |
You have to drill into the flange at an angle, no room to go straight in.
11-10-2016, 12:49 PM | #48 |
Moderator
Page 499 of the Auveco catalog has some interesting clips that could be used on the felts (or newly made sweepers for the outside) . . . maybe.
11-11-2016, 01:01 PM | #49 | |
11-11-2016, 01:07 PM | #50 |
And got a picture of what your 66 window strip looks like? Thanks!
