#476 | |
A day late and $1 short...
Re: Project "Just an Old Truck"
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#477 | |
C/10 junkie
![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#478 |
Tonight I did a little post install rear end check. Topped off the fluid, and reinstalled the 3.5° shims Hart_Rod loaned me, I had a little vibe on the round trip to work today. Going to drive it again tomorrow, hopefully it will check good. Waiting to hear back from the guys at Porterbuilt about a trailing arm crossmember to fix the goofy wheel well issue. If I can get that settled the next big project will be the crossmember and forward arms.
#479 |
C/10 junkie
What kind of vibe are you getting? Ever since the 700 install I get a very light vibe under hard acceleration. Just enough to notice.
#480 |
At around 55-60 it is a mild vibration that you feel in the seat (does that make sense?) and between 60-65 it gets worse. It's not felt in the steering wheel, seems to be isolated to the rear. I had the shims in before the rear end swap and it seemed better, but I wanted to start fresh so I would know what eventually fixes it. I am hopeful that a PB adjustable trailing arm crossmember will do the trick! We'll see.
As for your your truck, I think it is tire shake from all those ponies your trying to put to the pavement! ![]()
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 02-28-2013 at 09:40 PM. |
#481 |
Morning drive report... Well, installing the shims seems to have created a new vibration. This is actually a good thing because it gives me something to compare and contrast. The vibration I have been fighting may simply be in the wheel balancing, because it is more of a shudder in the whole truck that eminates from the rear. This new vibration is more of a buzz at 35 and 55. I guess I will remove the shims and see if the new vibration goes away. No matter what, vibration or no vibration, it was a great drive to the job today.
#482 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Have you put an angle finder on the trans and rearend?
Just wondering where you are at.
#483 |
The trans was 5° down before I raised the tail shaft about an inch and the rear end was 0°. I am going to have to put it up on the set up blocks tonight and remeasure everything again to varify, if I were to estimate I would think the trans 4° down and the pinion is 3.5° up with the shims. Where I may get into trouble is if the pinion is higher than the transmission (from the ground) causing the angles at each universal joint to exceed the 4° limit.
#484 |
C/10 junkie
Curious to see where you end up degree wise. I have never even messed with the angles of the trans or rear end and its super smooth until I get on it. Even then it's a very slight wiggle in the seat. Prob just leave it be.
#485 |
If that is all you have I wouldn't sweat it. My problem is that I avoid driving my truck over 60 mph because the vibration worries me...
#486 |
![]() Join Date: Mar 2011
Nice project----love 68's
I can definitely relate to all the parts being stashed all around! Ive got a 3 bay shop and my truck is currently using 2 bays plus some storage out back! Ill keeping watching for sure...
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
#487 |
Checked my angles and here is what I found. The transmission is 3.5° down, the drive shaft angles up 1.5° toward the pinion, and the pinion is 3.5° up. The transmission output shaft is .500" (1/2") lower than the than the pinion. Total angle at the output shaft is 5° and the total angle at the pinion is 5°.
Based on what I have read there should be no more than 4° total angle at any universal, and the output shaft and pinion angle should be the same (or close). My total angles at each Universal are 1° over the limit, but my output and pinion angles are identical. Are the total angles my issue causing my vibration? ![]() Here are the pics I took, as well as a layout of the angles... Pic 1) Output Shaft 2) Drive Shaft 3) Pinion 4) Angles on paper (helps me visualize)
#488 |
If you a re going to swap the trailing arms or trailing arm crossmember,... I would work on it then.
Fixing it now,... may change when you swap parts later.
#489 | |
#490 |
Have you driven it much with the rally wheels on it?
I wonder if that would confirm "wheel balance" vs driveline. I know the shims created a new issue,... just wonder if you should try your rallys before you pull the shims?
#491 |
I understand what you are saying... Pondering it.... Not sure the rally's will fit the rear with the long rear end.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 02-28-2013 at 11:20 PM. |
#492 |
![]() Join Date: Feb 2012
very nice build!
#493 |
#494 |
Swapped out the "modified" proportioning valve for a CPP disc/disc unit, test drive in the morning.
#495 |
Wow! The proportioning valve made a huge difference, $40 bucks well spent.
#496 |
C/10 junkie
Amazing how everything hinges on those little bugers
#497 | |
![]() I snapped a pic on my way out to the truck after my breakfast stop at Whataburger...
#498 |
Whatatruck!! lol
-Rus |
#499 |
#500 |
Awesome lol
-Rus |
