Old 07-30-2015, 03:22 AM   #526
josueh95
Re: LS swappers, post up your pics!!
my 5.3/4l80e in my 76 c10
josueh95 is offline   Reply With Quote
Old 07-31-2015, 09:21 AM   #527
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by Mhubbard85 View Post
Question fellas. I just did my harness. Out of the fuse panal connections which do I need to keep
That is a loaded question without more details from you. I suggest checking out lt1swap.com. He has put a ton of info on modifying many different harnesses.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-06-2015, 10:02 AM   #528
ztk123
Finally got my 04 Z06 ls6 installed in my 71 2wd blazer! Completely rebuilt (fairly stock), Kwik performance bracket system. Seems to be running well.....
ztk123 is offline   Reply With Quote
Old 08-06-2015, 01:42 PM   #529
BigMike608
BigMike608's Avatar
My 1977 with a 5.3/4l60e from a 2008 Silverado CrewCab
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 08-13-2015, 08:27 PM   #530
1976K5CHALET
1976K5CHALET's Avatar
My 1990 Jimmy redo. Sent it to a place in Vegas. Paid 16K and received the worst workmanship i have ever seen in my life. Note to self. Even if your to busy in the oil patch working....still...do it yourself.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 08-13-2015, 08:41 PM   #531
69chevytrucker
69chevytrucker's Avatar
if i have a complete 2004 gm truck is it hard to do the swap onto a 83 blazer im pretty handy just not sure i see a lot of you guys do it just thinking the wires look a little scary . and when i say 83 blazer its cause my frame is a 83 but my truck is a 69 so im kinda handy
just not sure what i need to take out of my 04
69chevytrucker is offline   Reply With Quote
Old 08-14-2015, 05:01 AM   #532
dwalt14
ls1 from 04 gto. heads, cam, lt's
dwalt14 is offline   Reply With Quote
Old 09-13-2015, 02:32 PM   #533
DLW
Finally got my LS3 in for good (hopefully) in my 66'. Need to adjust the trans/engine angle a little but all fit nicely.
DLW is offline   Reply With Quote
Old 09-14-2015, 10:09 PM   #534
dwcardfan
dwcardfan's Avatar
Very nice!!!!!
dwcardfan is offline   Reply With Quote
Old 09-15-2015, 09:32 AM   #535
DLW
Originally Posted by dwcardfan View Post
Very nice!!!!!
Thanks...
Old 10-22-2015, 07:43 PM   #536
Shortbed 68
What kind of radiator did u use? I'm doing a 5.3, 4l60e swap in a 68 shortbed looking for all info I can get.
Shortbed 68 is offline   Reply With Quote
Old 10-22-2015, 08:36 PM   #537
DLW
Not sure if your asking anyone in particular, but I went with the Entropy radiator myself.
I also switched, from what you see in these pics ,which are the 2014 Camaro beltline water pump and balancer, to the corvette water pump (2004 vintage I believe) and balancer as it pushed the beltline back 1.5" closer to the engine. FYI, the 2010+ Camaro and truck beltlines are the same and also stick out the furthest compared to the F-body and Corvette beltlines. Just in case anyone is looking for a bit more room like I was.
Old 11-08-2015, 09:39 PM   #538
TwinsSpeedShop
Got my motor painted and dressed out with the valley cover and intake. Will be putting coil pack and accessories on tomorrow
TwinsSpeedShop is offline   Reply With Quote
Old 11-08-2015, 10:26 PM   #539
Shortbed 68
What kind of other parts did u use if I may ask? Engine, drivetrain, anything is helpful. Thank you
Old 11-08-2015, 10:29 PM   #540
TwinsSpeedShop
If your talking about mine, it's a 6.0/T56 combo with a sinister cam installed. The intake is from TSP. everything else is stock
Old 11-08-2015, 11:28 PM   #541
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Looks great. Didn't see a build thread so....what IFS is that you have?
thanks!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-10-2015, 12:08 AM   #542
ajlezama
I'm usually on the 73-87 section but this is my first 67 c10 that I'm building.. here is my swap I'm doing on it..
ajlezama is offline   Reply With Quote
Old 12-10-2015, 12:18 AM   #543
ajlezama
Here is one I did for a customer on his 88...
Old 12-11-2015, 01:33 PM   #544
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
1991 K5/2002 LM7 5.3L Build thread HERE
DirtyLarry is offline   Reply With Quote
Old 12-11-2015, 03:58 PM   #545
Jer64
Jer64's Avatar
looks like a Level 1, mild dropmember from Porterbuilt.....
thanks!
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=587028
Jer64 is offline   Reply With Quote
Old 12-14-2015, 05:08 PM   #546
Leeforbes
Leeforbes's Avatar
My LS swap is dropping in today into my 1966 C10. Out with the old 6 cyl 250 for a new 5.3 v8 with 6L80E transmission!
My 1966 C10 short Bed Fleet Project.
Build Photos
Accessory Drive System I used
Leeforbes is offline   Reply With Quote
Old 12-15-2015, 03:49 PM   #547
Hart_Rod
Hart_Rod's Avatar
nice!
Hart_Rod is offline   Reply With Quote
Old 12-20-2015, 07:44 PM   #548
MotorHead Lon
MotorHead Lon's Avatar
02 5.3/4L60 in my 1988 stepside.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 12-20-2015, 10:34 PM   #549
DLW
That is correct.
Old 12-25-2015, 12:19 AM   #550
josueh95
http://s1050.photobucket.com/user/jo...t9d4d.mp4.html
Little idle clip of my 5.3 with btr stage 4 224 230 cam fbody longtubes and hpipe
