01-04-2016, 01:42 AM | #526 |
Re: My 52 GMC Build
Thanks AD Well first I'm not using the key to start the truck. I'll take a pick of what I'm using. So top 5 relays are: IGN any thing I want powered with key: Amp, 12v power plug ect. Glow plugs, Left and Right door poppers, spare. Bottom 5: Starter, Lights, Fuel: anything related to motor running: fuel pump, Efan ect, ACC: all the secondary parts of truck running like transmission controller, gauges, ect. Then my heater. I am using a 30A electric heater 6000btu instead of coolant. Hope that makes sense.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually Last edited by lower50's; 01-04-2016 at 02:30 AM. |
01-04-2016, 02:55 AM | #527 | ||||
Re: My 52 GMC Build
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually Last edited by lower50's; 01-04-2016 at 04:07 AM. |
01-04-2016, 08:57 AM | #528 |
Re: My 52 GMC Build
Thanks lowers, I've been on a research mission and studied up, a lot! I will need help and will be asking, thanks man.
Chance
SHAKE N BAKE BABY, SHAKE N BAKE.... http://67-72chevytrucks.com/vboard/s...d.php?t=686729 |
01-04-2016, 11:57 AM | #529 |
Re: My 52 GMC Build
Here you go... posted by stanceiseverythingcom
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
01-05-2016, 03:34 AM | #530 |
Re: My 52 GMC Build
Thanks John
This is my starter sw. I built it out of the original cable leaver that actuated the 2 speed rear end that my truck had originally. Now you just push and it actuates the sw under the dash. These switches will be to turn the truck on. Upper hole will be for headlights.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
01-05-2016, 04:32 AM | #531 | |
Re: My 52 GMC Build
The starter button is way cool....reminds me of some of our heavy equipment starting. |
01-05-2016, 07:06 AM | #532 |
Re: My 52 GMC Build
I'd like to see some more info on your heater when you get to that part.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
01-05-2016, 08:37 AM | #533 |
Re: My 52 GMC Build
Nice, I like that starter button. And...I'm interested in your heater option also.
01-07-2016, 12:24 AM | #534 | ||
Re: My 52 GMC Build
http://www.my12voltstore.com/12_Volt.../sa12-3000.htm
01-07-2016, 12:26 AM | #535 |
Re: My 52 GMC Build
Tonight I got the electrical panel mounted to the fire wall
01-07-2016, 01:24 AM | #536 |
Re: My 52 GMC Build
clean wiring is a joy to troubleshoot!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
01-07-2016, 11:35 AM | #537 |
Re: My 52 GMC Build
that heater looks awesome, def something to think about. Let us know how it works and sounds. I spent hours routing my heater hose and getting coolant all over me. 1st heater/ac unit I had was garbage, so I had to replace it. Ever since I hooked up my heater I now can't seem to get an air pocket out of the system, either that or ironically my temp gauge is malfunctioning. anyway, I like the fact that this is a USA brand and they have some confidence in their product.
Nice panels
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
01-07-2016, 11:54 AM | #538 |
Re: My 52 GMC Build
Lookin killer. What's on the far left of your electrical panel? Are you planning to put a cover over it?
01-07-2016, 04:48 PM | #539 |
Re: My 52 GMC Build
Excited to see this truck out and about this summer! I had a shop in Breslau (beside the airport) up until April when I moved to London.
Commonwealth Shop truck build, bagged, 4-link, LS 58 Apache Commonwealth http://www.commonwealthmotoring.com/ Air ride and custom parts IG - Commonwealth_mf FB - https://facebook.com/commonwealthmotoring |
01-07-2016, 05:37 PM | #540 |
Re: My 52 GMC Build
That looks really clean!
Now I know for sure I have to make a new fusepanel.... Nice little heater too!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
01-07-2016, 07:10 PM | #541 |
Re: My 52 GMC Build
High quality looking job on the wiring Lower. Make that 3X or 4X on the heater deal. The one in my '46 is a POS and I'm looking for an original to rebuild or a quailty alternative.
Rob
My '47 C.O.E build |
01-07-2016, 10:50 PM | #542 |
Re: My 52 GMC Build
Great heater idea. I'll save that site for later
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
01-08-2016, 01:06 AM | #543 | |||||
Re: My 52 GMC Build
Thanks I figure for the small amount of time it will be used, it's a much better option. Also I have a rebuilt 110A altinator.
01-08-2016, 08:55 AM | #544 |
Re: My 52 GMC Build
Ah sweet, that heater should heat that cab fine if it's sealed up good. Wiring looks legit. I'm still being a puss just thinking about my wiring, haha.
01-09-2016, 09:41 AM | #545 |
Re: My 52 GMC Build
Thanks for the link on the heater, I think it may work for me. A few years ago, I bought one of those heaters that plugs into the cigarette lighter, and it put out very little heat.
01-11-2016, 06:30 PM | #546 |
Re: My 52 GMC Build
N.P. They have different sizes so what ever will work.
01-11-2016, 06:46 PM | #547 |
Re: My 52 GMC Build
Wow wiring takes forever and you don't get much to show for it. On Friday I made a new glow plug wire harness. Took 2.5 hrs for basically a piece of 8ga wire with 8 bullet connectors. Today I made the wire harness for the front of the motor: fuel on, tps, temp, alt.
01-11-2016, 07:35 PM | #548 | |
Simple? What's simple?
Re: My 52 GMC Build
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
01-11-2016, 11:38 PM | #549 |
Re: My 52 GMC Build
I can firmly back you up on that wiring takes forever. Looming all the wires, heat shrink and making it neat. 60 hrs into a full custom wire job with bags isn't far off.
01-11-2016, 11:40 PM | #550 |
Re: My 52 GMC Build
Lookin good man!
Tags |
bagged, build, diesel, gmc, hot rod |
