Old 02-13-2017, 04:43 PM   #526
lower50's
lower50's's Avatar
Re: 1956 Chevy Pro-Street Build
That will be a beast when you fire it. Looks great!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-13-2017, 05:35 PM   #527
RockinKees
RockinKees's Avatar
Nice, real nice!!!
We'll be waiting for the YouTube video of the first start, you know that, don't you???
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-13-2017, 08:17 PM   #528
Roadkill58
Roadkill58's Avatar
Originally Posted by ptc View Post
The temp starter station..... power, fuel, ignition, blastoff!
Looking good man.
You can start driving a quarter mile at a time soon!
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 02-13-2017, 08:35 PM   #529
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-14-2017, 12:35 AM   #530
Scottish58chev
Looks really Good
Scottish58chev is offline   Reply With Quote
Old 02-14-2017, 01:10 AM   #531
mud.man.rj
mud.man.rj's Avatar
E X C I T I N G , so close I can almost hear it, prob feel it too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 02-14-2017, 04:11 PM   #532
ptc
ptc's Avatar
Thanks guys..... really needing to hear this thing running just for some spiritual uplift... and YES A VIDEO TOO!!!!
Once it runs and there are no leaks anywhere, the body is going on "as-is" for now (the bottoms are all done) and Ill start getting the cab interior ready for paint and get the roll bar finish welded into place and final paint on the inside.
Then some wiring and get the thing ready for a drive.....
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-22-2017, 12:47 PM   #533
ptc
ptc's Avatar
Well its ready for the start up ---- Saturday 2/25 will be the day.
Final Build Spec:
Merlin III 540 Cu. In. WPM Alum head, stainless valve 2.25/1.88", Vortec V4Z supercharged with .688 lift cam and valvetrain by Straub, Eagle forged rotating assembly with H beam rods, Diamond forged flat top pistons 9:1 CR, all ARP throughout.
I will post a video after we get it going
Old 02-22-2017, 02:28 PM   #534
Roadkill58
Roadkill58's Avatar
Beast.
Rust Never Sleeps
Old 02-22-2017, 02:33 PM   #535
Flysocal
Hold on tight. Yeeee Haaaaa!!!!
Flysocal is offline   Reply With Quote
Old 02-22-2017, 05:26 PM   #536
Scottish58chev
That's awesome
Old 02-22-2017, 07:35 PM   #537
mud.man.rj
mud.man.rj's Avatar
Rumbling nasty video, can't wait as you.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 02-22-2017, 07:37 PM   #538
RockinKees
RockinKees's Avatar
I'm siiting in my lazy chair, u tube already on, popcorn present...
So, Lets see and hear the beast!!
Can't wait!!
Cheers!! Kees.
Kool Guyz CC
Old 02-22-2017, 07:46 PM   #539
Kim57
Kim57's Avatar
Very cool.
Kim
My build thread
Old 02-22-2017, 07:50 PM   #540
mud.man.rj
mud.man.rj's Avatar
The crowd are gathering around our computors, waiting to hear the beast!!
5.0 4spd std.
7" lift w 35's.
Old 02-22-2017, 08:50 PM   #541
ptc
ptc's Avatar
I think "Beast" is a very close analogy! .... I put in all the fluids and just turned it over with no fire yet to get everything pumping into all the lines and such and the echo sound coming out of the headers is like a bass drum going thump-thump, thump-thump, thump-thump!!!! .....
its ready!
Old 02-23-2017, 08:52 AM   #542
lower50's
lower50's's Avatar
OH SO EXCITING!! I want to hear the first few sputts out of the exahust before it fires up. I love that part.
1951 MG TD
Old 02-24-2017, 03:43 AM   #543
Nut Case
Nut Case's Avatar
PTC
I'll be waiting on Saturday for a disturbance in the force, no need for a video, we will all feel it!!!!!!!
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 02-24-2017, 11:59 AM   #544
ptc
ptc's Avatar
Ok so I filled the engine oil and everything has stayed inside the engine so far, thats a good sign... next the trans was filled with fluid and again no leaks! - started to fill the radiator -wow that larger radiator took 4 gallons of straight-up antifreeze before it started to fill, and then I ran the electric water pump and started pumping it through the engine block and put in 2 more gallons of water and then saw water on the floor.... yikes. had a plug in the intake manifold loose for a temp sensor fitting that I dont have in yet. Tighten it down and all good. P/S fluid filled and then turned over and pumped it through to the lines to the hydroboost unit and all is still good.
Fuel system ----- I hate fuel! --- always a problem. put in 5 gallons to start with and clicked the pump on , in seconds the lines are filled gauge is pegged and I hear girgling... shut off pump. girgle girgle... I see fuel coming out the Supercharger inlet! um WRONG!
Long story short - my AEROMOTIVE fuel regulator I bought off ebay, that was listed as AEROMOTIVE #13301 bypass regulator is a knock off, I called the tech line at Aeromotive and took pics and the guy said the spring looks like it was meant for a car suspension system not a regulator!
This is what it is suppose to look like
And the photo below is what I took apart on my NEW knock off.
So back to the speed shop for some more parts! ---- good thing I did this little pre-check.... otherwise I would have had a FUEL FLOWING FIRE on my hands thanks to a CHINESE JUNK KNOCK OFF COMPANY....
I dont think I need to say this is DANGEROUS STUFF these companies are doing to the consumers --- If somebody had just put that reg on their car and fire it up with no gauge or checking it, they would have had a huge fuel fire on their hands to deal with.
DONT BUY EBAY JUNK!!!!! ----
Old 02-24-2017, 09:13 PM   #545
Kim57
Kim57's Avatar
Getting real close.
Glad you found the problem before start up.
Kim
My build thread
Old 02-24-2017, 09:39 PM   #546
ptc
ptc's Avatar
So.... there was a bunch of fuel that went into this thing, I pulled all the plugs out and cranked it and fuel blew out of all the cylinders. I had pulled the intake tube and cap off the carb, so when I turned it over the supercharger blew a shot of about a half a pint across my shop!!!!!!
I think it washed down the cylinders and all went into the oil, so I changed the oil all out again too just to be safe before I light this thing up. Got the new reg onto it, found a couple more leaks in the lines and got them all fixed this thing dont leak anywheres right now.
I mopped down everything in the shop with soapy water and cleaned it all up. I dont want to put any spark to this thing till all the fuel vaporizes.... Ive got fans running through the entire shop to blow it out tonight.
What a mess! -- I hate FUEL! good thing it was only cheapo 91 octane and not the good stuff!
Gonna light this candle tomorrow!!!!
Old 02-24-2017, 11:47 PM   #547
mud.man.rj
mud.man.rj's Avatar
Wow, your on top of it, great save, yeah better deal tomorrow, we will be waiting. Try to sleep tonight.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 02-25-2017, 08:13 PM   #548
ptc
ptc's Avatar
Ok guys heres the video of the engine start - - Went really well for the most part. 1st run we blew a PS hose end that wasnt on right and oil everywhere. 35 lbs of cat litter and cleanup and ..... here we go!
https://youtu.be/CvW_x93fwO4
Old 02-25-2017, 10:14 PM   #549
Kim57
Kim57's Avatar
Sounds awesome.
Kim
My build thread
Old 02-25-2017, 11:35 PM   #550
Advanced Design
Advanced Design's Avatar
Wicked cool! Sounds very good.
Advanced Design is offline   Reply With Quote
