Old 09-03-2015, 05:19 PM   #576
Kim57
Kim57's Avatar
Re: Dutch '59 Fleetside Longbed
Nice mods on the column.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-03-2015, 05:31 PM   #577
RockinKees
RockinKees's Avatar
Thanks Kim!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-03-2015, 06:05 PM   #578
oldman3
oldman3's Avatar
Kees, nice job on the column, looked like a seasoned pro doing the work...Jim
oldman3 is offline   Reply With Quote
Old 09-03-2015, 10:08 PM   #579
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work!
ChuckDriver is offline   Reply With Quote
Old 09-03-2015, 11:16 PM   #580
Advanced Design
Advanced Design's Avatar
Yep, you made that look easy!
Advanced Design is offline   Reply With Quote
Old 09-04-2015, 11:57 AM   #581
RockinKees
RockinKees's Avatar
Finished welding the column.
Shifter pipe:
The 3" pieces going back:
And the last piece (you can see the mark I made to get the parts inline):
And finished it looks like this:
I now have a column build to my personal specs, what else do you need
It was easier than I thought, now comes the connection to the rack and pinion....
Put the column in place to see if I got it right, and yes, excactly what I wanted!
Again, one item off the list
Cheers!! Kees.
Kool Guyz CC
Old 09-04-2015, 12:08 PM   #582
Katrina/10
Katrina/10's Avatar
Nice work, you can grind a couple of flat spots on the end of the shaft to attach a u-joint.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-04-2015, 12:15 PM   #583
RockinKees
RockinKees's Avatar
Yes Gary, that was exactly the plan.
I may have to shorten the end a bit, we'll see when we have the parts...
Cheers!! Kees.
Kool Guyz CC
Old 09-04-2015, 12:37 PM   #584
Kim57
Kim57's Avatar
Came out real nice.
Kim
My build thread
Old 09-04-2015, 12:50 PM   #585
59chev
59chev's Avatar
Thanks for the pics on shortening the column. I will need to do the same thing with the van column I plan to put in my truck.Your pics where the ah.. ha.. moment I needed.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 09-04-2015, 03:20 PM   #586
RockinKees
RockinKees's Avatar
You're welcome!!
Thanks again Kim!
Cheers!! Kees.
Kool Guyz CC
Old 09-04-2015, 04:09 PM   #587
ChuckDriver
Nice work!
Mine is also a shortened van column and I machined it for the Double-D joint. I also modified the shift arm so the shift rod would clear the brake pedal!
Old 09-04-2015, 05:07 PM   #588
RockinKees
RockinKees's Avatar
That's good looking Chuckdriver!
I've made a swingpedal so I don't have to modify the shiftarm
Cheers!! Kees.
Kool Guyz CC
Old 09-05-2015, 04:16 PM   #589
OrrieG
OrrieG's Avatar
Just a heads up. On GM for the shift indicator to match the transmission the distance from the center line of the column shaft to the linkage hole needs to be the same as the center line of the trans shift shaft to shift rod linkage hole. I spent some time on trial and error before I found a link with that nugget of information. So if you lengthened the one on the column you will need to do the same to the trans shaft lever.
OrrieG is offline   Reply With Quote
Old 09-05-2015, 04:21 PM   #590
RockinKees
RockinKees's Avatar
THAT is some good info!!
Thanks OrrieG!!
This probably saves me a lot of headaches
Cheers!! Kees.
Kool Guyz CC
Old 09-06-2015, 08:08 PM   #591
rusty76
rusty76's Avatar
Cool truck. Late to the build but I likes it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 09-07-2015, 03:02 PM   #592
RockinKees
RockinKees's Avatar
Thanks Rusty76!
I've ordered the parts for the steering so that have to wait a few weeks.
Been thinking what to do with the towbar. Did a small mock up to see if it would fit:
Well it fits, but it's very thight. I also want the fueltank in that spot.
The towbar is from a '98 Trialblazer, and is just a little too wide.
I modified the towbar so it fits the framerails. I now can bolt it right under.
Ground off the original "ears" and made my own. Also welded in a gusset, that's being used as the rear mount of the fueltank. The front of the tank is bolted to the crossmember.
And in primer, tommorow it's all black
Next is mounting the fueltank and make the fuelline.
Then think about the fuelfiller, I want it at the rightside of the bed...
Lots to do!
Cheers!! Kees.
Kool Guyz CC
Old 09-07-2015, 06:01 PM   #593
Steve-W
Steve-W's Avatar
Kees, your craftmanship is truely inspirational!
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 09-07-2015, 06:38 PM   #594
55 Chevy Dave
55 Chevy Dave's Avatar
Great build you have going here, Kees.
I can see that I am going to need to go through all 24 pages!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 09-08-2015, 08:42 AM   #595
Kim57
Kim57's Avatar
You're doing a great job on all the fab work.
Kim
My build thread
Old 09-08-2015, 03:27 PM   #596
lower50's
lower50's's Avatar
Nice job on the column. The hitch will be nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-08-2015, 05:16 PM   #597
ptc
ptc's Avatar
Nice Hitch work you did there!!! coming right along.....
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 09-09-2015, 09:44 AM   #598
reaper71
reaper71's Avatar
Looking real good Kees!!
reaper71 is offline   Reply With Quote
Old 09-11-2015, 03:10 PM   #599
RockinKees
RockinKees's Avatar
Thanks guys!!
Small update...
Due to some physical problems nothing much is done.
But...fueltank is in, fuelline is in
Went ahead with the doorlocks again just before the body breakdown
I was filling the pillar to get it nice and clean before I had to stop. You see what this is going to look like when finished I think.
I have to use modern mathmatics to get the stock doorhandle work with the BMW doorlocks. I think I know what to make for this....
As I was at home, I took the ventwindow apart to put new weatherstriping in there.
As I took it out of the truck:
Apart and ready for primer and paint:
Primered and painted and baking in the sun:
I looked at U-tube to see what was the easiest way to put the weatherstriping in, and saw I was missing a few washers. One that was needed for mounting the spring at the right tension was not there, so I made one:
Put the new weatherstriping in, bolted all together and I have a "new" good looking vent window again
The list gets shorter and shorter
Cheers!! Kees.
Kool Guyz CC
Old 09-11-2015, 11:59 PM   #600
Kim57
Kim57's Avatar
Nice work on the vent.
Hope you feel better.
Kim
My build thread
