02-14-2016, 10:44 AM | #701 |
Re: Project Roxy
this is a killer build
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
02-15-2016, 12:26 PM | #702 |
Re: Project Roxy
Just curious, where did you get your brake booster and master cylinder on Roxy? Thanks
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-15-2016, 03:11 PM | #703 |
Re: Project Roxy
The one pictured is Hartrods. Mine is a CPP disc/disc booster and a generic 6" booster I bought at a street rod show.
///Relaxed Atmosphere |
02-15-2016, 05:15 PM | #704 |
Re: Project Roxy
Sorry CPP master cylinder
02-15-2016, 05:19 PM | #705 |
Re: Project Roxy
Ok, thanks a lot. I'm wanting to go with a smaller booster to gain some room with the BB valve cover. I hope you don't mind, I posted a question about this and used one of your pics for a reference?
02-15-2016, 07:08 PM | #706 | |
Re: Project Roxy
03-07-2016, 11:45 AM | #707 |
Re: Project Roxy
Cause I'm too cheap and broke to spend $300 on new fancy bed strips. I used the old and hide the fasteners. Primed. Now to bed line body color or paint the same color as the wood tone.
04-11-2016, 04:54 PM | #708 |
Re: Project Roxy
So after throwing another $500 at this pig, I'm a few steps behind now.
Basically, truck was starting really hard. You had to crank it for about 30 seconds to a minute before it even thought about starting. Once it did, it ran rough until it was warm. I figured a new carb with an electric choke would solve the problem (it started decent when I choked the old carb).. Nope.. and now the starter just took a dump on me. I'm too the point where I just want to bring it to someone to finish it and be done!
04-11-2016, 06:43 PM | #709 | |
Re: Project Roxy
04-11-2016, 08:02 PM | #710 |
Re: Project Roxy
Sounds like too much timing. What ignition system are you using?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
06-30-2016, 07:31 PM | #711 | |
Re: Project Roxy
At the last post I had the starter rebuilt only to crack the nose cone. My wife and kids bought me another starter for father's day and I back the timing off a bit. It appears to be starting alot easier. However, I'm going to have the guy that built the motor set the timing again. I've renewed my love for the truck in the last week or so and now that it starts I think things might not be such a fight with it. I'm going to finish the bed. Nothing fancy, just a sheet of stained plywood. I'm hoping to have it drivable by mid-september for an NSRA show.
06-30-2016, 10:57 PM | #712 | |
Re: Project Roxy
07-04-2016, 12:01 AM | #713 |
A guy with a truck
Re: Project Roxy
Keep it coming! Love this truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-05-2016, 05:34 PM | #714 |
Re: Project Roxy
Thanks guys.. Can't believe it's been 5 years since I started this truck..
07-07-2016, 05:02 PM | #715 |
Re: Project Roxy
CPP brakes.. Not a fan and would not probably buy them again. For $1700, I probably could have went with a better company with less hassle.
Latest dilema with them.. The 7/16-20 wheels studs are 3/8" too short to work with my billet specialities vintecs. (they are the screw in style 12 point flange head) Call CPP and they say they have never had that problem. (I know that's not true and has been addressed on this site) They tell me any speed shop with have them and they have nothing in stock to fix my problem. After search for 8+ hours, I found a hex head grade 8 bolt that might work. I ordered a bunch and will see. Just find it funny that CPP made little effort to make it right after I spent so much on the brakes.
07-07-2016, 10:20 PM | #716 |
Re: Project Roxy
AND you've had a bit of trouble with them, now this. Thanks for the heads up. Truck is still killer though and you'll get it where you want it! I love it.
07-07-2016, 10:48 PM | #717 |
Re: Project Roxy
I picked these up for mine but haven't installed them.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-08-2016, 08:42 AM | #718 |
Re: Project Roxy
Those have a knurl section on them. The ones that are installed on mine are 12 point flange tap bolt (fully threaded). I thought finding them would be easy. However, they only place I've found a 2 1/2" bolt was a place in South Carolina. It's a grade 8 hex head. I'm hoping that will be strong enough to use as wheel stud.
I contacted a board member way2low and he said he might also have something that will work.
07-08-2016, 08:47 AM | #719 | |
Re: Project Roxy
07-08-2016, 10:34 AM | #720 |
Re: Project Roxy
You can also check with ARP, I know they make wheels studs too. Not sure if they have a 12 point fully threaded head but maybe they have something that will work.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
07-08-2016, 12:38 PM | #721 |
Re: Project Roxy
I have never seen a 7/16" screw-in wheel stud before. I wouldn't want a 7/16" stud anyway. Personally, I would run a 1/2"-20 stud (what our trucks came with from the factory, for a reason), and either drill and tap for screw-in, or drill for the knurl size on the press-in.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-08-2016, 01:27 PM | #722 |
Re: Project Roxy
I have looked on every website I can think of. ARP, Currie, Moser, Strange, Summit, etc. No one has anything that long.
The only company that has any that long in that thread and pitch is https://www.boltmax.com/proddetail.php?prod=455266-8
07-08-2016, 01:46 PM | #723 | |
Re: Project Roxy
And yeah, it's total BS that CPP says they've never heard of this problem. I still have some emails that I sent to them over 6 years ago.... That's fine, CPP has lost me as a customer (which I'm sure they don't care). I will buy from another source when and if I build another project.
07-08-2016, 02:04 PM | #724 | |
Re: Project Roxy
I'm pretty sure those grade 8 will work.. but, who knows.
07-08-2016, 03:10 PM | #725 |
Re: Project Roxy
I think you will be fine with those. They will definitely be better than what you currently have...
