Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-20-2007, 04:04 PM   #51
19723DR
19723DR's Avatar
Re: 1972 3dr Suburban Build Thread
Originally Posted by Frizzle Fry View Post
I'll post a pic of mine if someone else doesn't beat me to it. It's basically right below the radius if the lower body line (as high as possible without being on the bend). Are those stick-on clips?
Thanks, I was asking because I have seen some with a small space. Pics would be great. Maybe what I saw was from people just trying to line them up and the doors and fenders weren't fitting quite right. The kit comes with 24 stick-on clips and all the bolt-on hardware so I could do it either way. I don't have any of the factory holes left though. I'm going to have to drill for the two pieces on the front and back which have two screws each. Not happy about drilling any new holes after paint.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 12-20-2007, 04:18 PM   #52
Hart_Rod
Hart_Rod's Avatar
JB weld the screwheads in the holes and then use a stick-on clip on the end.
Hart_Rod is offline   Reply With Quote
Old 12-21-2007, 08:15 PM   #53
19723DR
19723DR's Avatar
This weekend I will work on the trim. It,s going to snow, again. Not to mention the week end before christmas, but I am going to squeeze it in when I can. Today I ordered a new C-notch from CPP. Man I got to get the back down with the front. I'm thinking the front needs another 1'' to 1'' 1/2 down. That height would be perfect. Thought for the future.
97 Z71 3 Door
Old 12-25-2007, 04:45 PM   #54
19723DR
19723DR's Avatar
Here's some progress pics. Passenger side is finished. The kit only came with 24 clips and that only leaves three on some of the longer pieces. For extra strength I added silicon in between.
Tell me if you think this isn't straight enough:
The suburban is starting to look pretty sweeeeeeet!
97 Z71 3 Door
Old 12-25-2007, 05:14 PM   #55
custom72c20
custom72c20's Avatar
that looks awesome!!!!!!!!
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 12-26-2007, 03:46 AM   #56
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hell ya they look straight you did a great job buildin the ride congrats.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-26-2007, 09:30 AM   #57
Frizzle Fry
Frizzle Fry's Avatar
Man that looks great. You gonna put some screw heads in the rear pieces?
Frizzle Fry is offline   Reply With Quote
Old 12-26-2007, 05:10 PM   #58
NEVERENOUGH
NEVERENOUGH's Avatar
Wow what a nice project. I love your color combo yellow is one of my favorites. You have done a very nice job with color and stance. Great wheel choice also. Can't wait to see what you do with the interior after the great job you have done on the exterior.
NEVERENOUGH is offline   Reply With Quote
Old 12-27-2007, 06:30 PM   #59
19723DR
19723DR's Avatar
Thanks everyone for the support. I finished up the driver's side trim. I cut off the screw ends and glued them into place too. The cold weather made it more difficult because the double sided tape wouldn't stick.
Thank you Mar K Quality Parts. The fit and finish is excellent.
97 Z71 3 Door
Old 12-27-2007, 06:43 PM   #60
19723DR
19723DR's Avatar
I have started my custom kick panel speaker boxes in between putting the trim on. I've looked at some people have done on here, including the one Frizzle Fry made, and have a good idea of what I want. I also have a custom center console and rear woofer boxes in the works.
97 Z71 3 Door
Old 12-28-2007, 08:43 AM   #61
Clyde78
Hubba Hubba! That's not the same suburban my mother took me to Jack in the Box to as a kid. Good job! I showed the old man the pics and he can't believe it.
Clyde78 is offline   Reply With Quote
Old 12-28-2007, 02:25 PM   #62
19723DR
19723DR's Avatar
I'm glad you found the site, can't wait to see your pictures. Tell your dad I'm not sellin' it back! Tell your bro, to find the old pictures and you can post them here.
For all you out there, this is the original owners' son. I can't take credit for all the work, m&ms, you did a good good job of keeping the 'burb well maintained over the years. Here's to you guys!
97 Z71 3 Door
Old 12-28-2007, 02:48 PM   #63
kyull67
kyull67's Avatar
Awesome! I just read the whole thing. Good job
kyull67 is offline   Reply With Quote
Old 12-29-2007, 02:56 PM   #64
19723DR
19723DR's Avatar
Thanks, I checked out your thread and that step-side is going to be awesome.
The C-Notch kit arrived in the mail. Here's a pic:
Great project for a 4 day weekend.
97 Z71 3 Door
Old 12-31-2007, 04:16 PM   #65
19723DR
19723DR's Avatar
Saturday, made some progress. I put in the passenger side C-Notch. Here's some pics of the process:
Drilled out the rivets and removed the old bump stop. Then I made a template.
I then used the template to draw where to cut. I also made templates for the bottom front and back of the C-Notch. So the frame cuts line up with the C-Notch if I want to weld it later.
Jacked up the rear end to make sure the cut would be centered on where the bump stop will be. Note I shifted it backwards from where they said by 1/4".
Maked sure the 2 brake and 2 fuel lines were out of the way.
Made a notch in the spring plate going by the template.
Went to town with saws-all.
97 Z71 3 Door
Old 12-31-2007, 04:17 PM   #66
19723DR
19723DR's Avatar
Cleaned up the frame and put some paint on it. At a later date I will do the whole back frame.
Installed the C-Notch. I put the two bolts in the spring plate first and drilled the back bottom two holes, then the side holes.
Since I am not building a road-grader I bought some taller bump stops from Autozone.
I put the wheel back on for a test fit. Not too shabby.
Now on to the driver's side...
97 Z71 3 Door
Old 12-31-2007, 04:20 PM   #67
Hart_Rod
Hart_Rod's Avatar
They make some much smaller bumpstops (1/2") if you want to be able to go lower in the rear.
R
Old 12-31-2007, 04:59 PM   #68
19723DR
19723DR's Avatar
Rob. The kit came with the 1/2'' bumpstops. I was worried about the rear hitting the wood floor. So I bought taller ones. I can always cut them later. The upper bag bracket need to be modified also. I can't wait to see your body on that clean frame.
97 Z71 3 Door
Old 12-31-2007, 05:10 PM   #69
lolife99
67-72 parts collector,…
lolife99's Avatar
19723DR,... I think you would like the ride better if you install some shock "relocators" from ECE. I didn't realize how much my shocks WEREN'T working without them. They stand the shocks up more vertically,... so they work. I think before, they were just pivoting on the bolts. Oh yeah, love your 'burban!
Keith
Convert to disc brakes.
Old 12-31-2007, 05:33 PM   #70
19723DR
19723DR's Avatar
That is good idea. I will look into those relocators. Thanks man.
97 Z71 3 Door
Old 12-31-2007, 05:36 PM   #71
Hart_Rod
Hart_Rod's Avatar
With the short bumpt stops the rear differential cover just barely touches the wood floor. What bags are you running? I used ART. I can't wait until mine is as done as yours, .
Old 12-31-2007, 05:37 PM   #72
Hart_Rod
Hart_Rod's Avatar
100%
Old 01-01-2008, 04:45 PM   #73
19723DR
19723DR's Avatar
The bags are AIM 2600s and are just like Firestones.
97 Z71 3 Door
Old 01-01-2008, 04:50 PM   #74
19723DR
19723DR's Avatar
Here's the other side:
More snow...
I scooted the C-Notch back another 1/4". Thanks to the suspension forum and CCP.
97 Z71 3 Door
Old 01-01-2008, 06:04 PM   #75
Frizzle Fry
Now we're talkin
