Old 03-29-2008, 04:21 AM   #51
OJOE
Crew Cut
OJOE's Avatar
Re: ojoe's crewcab shortbed build
Originally Posted by BrooKLyn View Post
how come u didnt use the front bed mounts and hack the rest of the frame off?
sorry but i dont understand the question.
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 03-29-2008, 08:02 AM   #52
BrooKLyn
BrooKLyn's Avatar
let me see how to explain basicly move the bed forward use the front bolts. Then cut the frame off that hangs out the back. Move the spring hangers n shackles forward.. just a way i seen some one do a truck.
im picking up a free 82 crew cab tommorrow and im going to short bed just for the f**k of it and i think im going to go ur way since u dont really have to do any hard labor.. sweet job..
BrooKLyn is offline   Reply With Quote
Old 03-29-2008, 09:27 PM   #53
BrooKLyn
BrooKLyn's Avatar
ok heres my next question..
shortbed c10.. are the all (73-87)frames the same?
Old 03-30-2008, 03:41 AM   #54
OJOE
Crew Cut
OJOE's Avatar
this wont work
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 03-30-2008, 03:43 AM   #55
OJOE
Crew Cut
OJOE's Avatar
in 2 wd, yes
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 04-09-2008, 07:40 PM   #56
bcubed
bcubed's Avatar
Wow, looks like I should have been coming over more often, it's come a long ways .. been working on a project of my own though that I've needed for a while
2000 Bagged Silverado
1978 Chevy Malibu
1955 Apache Stepside (someday)
bcubed is offline   Reply With Quote
Old 04-11-2008, 03:58 AM   #57
OJOE
Crew Cut
OJOE's Avatar
nice! i know you are glad to have that. lt looks good.
come on over this weekend.
i just came in, mike and i have been working on mounting the blazer gas tank. we got it done, just have to take it out and paint all of the brackets.
also got the dakota gauges in,front driveshaft in, shifter hooked up and p/s finished.
i got the a/c relocation kit from street and performance, did not know it was going to be polished alum including compressor. i am now bead blasting it all and going to spray clear so it will match the stock brackets.
i am now waiting on wiring harness and ecm from speartech and fuel lines from fueltech.
maybe i can get some more done this weekend
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 04-11-2008, 04:00 AM   #58
bcubed
bcubed's Avatar
Getting mine ready for a show in Millbrook Saturday .. ya'll oughta at least ride out for lunch ...
Maybe I can make it over Sunday to check it out.
1978 Chevy Malibu
Old 04-11-2008, 05:20 AM   #59
bigblock73
yeller
bigblock73's Avatar
There are slight differences (trans crossmember for one), but essentially the same.
bigblock73 is offline   Reply With Quote
Old 04-11-2008, 03:29 PM   #60
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Are the bed and cab mount locations the same? I got a rollin chassis for a steal. Friend I got it off of said he was PRETTY sure it was an '80, but could be a '78 or '79, the truck its goin under is an '81.
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 04-12-2008, 05:33 AM   #61
djracer
djracer's Avatar
it should be fine!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-12-2008, 11:04 PM   #62
C10 the GEM
Smok'em Roast'em Shift'em
C10 the GEM's Avatar
what paint did you use to paint your frame?
C10 the GEM is offline   Reply With Quote
Old 04-14-2008, 02:23 PM   #63
OJOE
Crew Cut
OJOE's Avatar
just plain old black enamel
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 04-17-2008, 06:04 AM   #64
onetonk5
Cereal Killer
onetonk5's Avatar
What pattern did you use to paint your frame?
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 05-01-2008, 09:03 AM   #65
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
ttt
What did u have to change out in the Front end for the conversion to 5 lug?
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 05-01-2008, 05:12 PM   #66
kevinr1970
I don't understand this question?
Originally Posted by toomanytoyz View Post
ttt
Rick
I believe he said spindles/brakes and the "A-arms". The ball joints on the 1-tons are different. This might have been in the headliner thread though?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-01-2008, 05:29 PM   #67
toomanytoyz
Luv the Crewcabs
You are Right, I found it in the Headliner Thread, Changed the a-arms & spindles.......
Thanks for the Help, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 05-02-2008, 02:39 AM   #68
OJOE
Crew Cut
OJOE's Avatar
dats rite lol, thanks joe
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 05-02-2008, 02:43 AM   #69
OJOE
Crew Cut
OJOE's Avatar
hey mark, i used the 36.5 angle cross/22% side stroke pattern. = pint top and a large bucket of paint. sorry guys inside joke
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 05-12-2008, 12:28 AM   #70
mike nutt
69fatmotor
mike nutt's Avatar
here's a few pics of the latest progress. the tank is mounted and fuel lines plumbed up . joe got the wirng harness and computer back and started the wiring. well here's the pics.
mike nutt is offline   Reply With Quote
Old 05-12-2008, 12:39 AM   #71
toomanytoyz
Luv the Crewcabs
Thanks for the Update, That is Going to Make one Sweet Daily Driver, We owe you Guy's a Debt of Gratitude for Documenting the Build for us to Enjoy & for some to Copy...............
Thank You Both, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 05-13-2008, 05:48 PM   #72
bcubed
bcubed's Avatar
Wow, looks good .. if it wasn't for me working on my garage about every weekend, I'd make a trip over ... you guys going to the tractor show this weekend?
1978 Chevy Malibu
Old 05-13-2008, 06:11 PM   #73
Hart_Rod
Hart_Rod's Avatar
The truck is looking great Joe. Have you started installing the Speartech harness yet? Did you have them pull the cruise control wire for you? Can't wait to see it on the road.
R/
Hart_Rod is offline   Reply With Quote
Old 05-14-2008, 03:21 AM   #74
OJOE
Crew Cut
OJOE's Avatar
[QUOTE=Hart_Rod;2720023]The truck is looking great Joe. Have you started installing the Speartech harness yet? Did you have them pull the cruise control wire for you? Can't wait to see it on the road.
yes, i do have the engine harness installed on the last pic, i have been working on my old harness cutting out every thing i don't need (which is a lot) and yes speartech did leave me 4or5 wires for my cruise, they will tie into my old gm stalk controll. also my pcm and drive by wire controll box will be under dash
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 05-14-2008, 05:15 AM   #75
HanSoloWS6
HanSoloWS6's Avatar
Threads like this make me want to tear my truck down right now lol. Too bad I need to be able to drive it for a little while longer lol.
"Locomotion" - 1982 C10 LWB
6.2 to 6.5 HUMVEE non turbo swap complete
Pop's Garage Photography - Dayton, Ohio
My Truck Build Page
HanSoloWS6 is offline   Reply With Quote
