06-16-2016, 01:50 AM | #776 |
Re: My 50 roadster pickup build
looks like a great time, I hope I can celebrate 50 years with my wife, I am envious of you! Thanks for the pictures!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-16-2016, 06:32 AM | #777 |
That looks Like A Great Time! Good to see Your Lovely Wife Again. I'll bet it was Hot in that Valley around the home.
06-16-2016, 07:09 AM | #778 |
Lots of fun stuff for everyone.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
06-16-2016, 10:24 AM | #779 | ||
Yes it was, we have been asked to do it again next year...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-16-2016, 05:24 PM | #780 |
Jim, that was a nice event for everyone to do and we loved the pic of you and Aggie!
06-16-2016, 09:27 PM | #781 |
Thanks Doug, she had a good time even if it was hot...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 06-17-2016 at 11:38 PM. |
06-18-2016, 05:44 AM | #782 |
I see you having some great times all together!!
I love reading your posts and look at your pictures!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
06-18-2016, 10:17 AM | #783 |
Kees, thank you so much. I know there are lots of member on here that do things with their rides, just need to get them to post it...Jim
08-29-2016, 09:04 PM | #784 |
Hey folks, here's another update on a change I've been wanting to do for a LONG time. It's my alternator, it's only an 85 amp, been on the truck for 12 years and always kept the battery hot. It was fine when rpm's are up but at idle, etc it was below 14-1/2 volts, which most new cars show all the time.
The first pic is at 1800 rpm running down the road, 14-1/2 volts and the ac blower on. Second pic is at stop, 600 rpm in gear and ac blower off, 13 volts. Third pic is at stop, 600 rpm in gear and ac blower on, just above 12 volts. This wasn't hurting anything, I just didn't like it that low. Note: I took these pics in March and just now getting around to doing something ...Jim
08-29-2016, 09:16 PM | #785 |
So today I removed the alternator, and will take to the shop tomorrow and have them up grade to 105 amp. While this was apart I thought it would be a good time to change all the belts, since they are 12 yrs old.
First pic is the alternator second pic is my 3 pulley set up for alt, ac and PS. third pic is my old belts, gates 7350, 7500, and 7530, they really weren't that bad, but nows the time to change. Will let you know how everything comes out once I get the alternator back and things installed...Jim
08-29-2016, 09:57 PM | #786 |
That will be a good upgrade Jim. How many miles in those 12 years?
08-29-2016, 11:26 PM | #787 |
Only 24,000 miles, even with me retired I thought I would have more, but life gets in the way...Jim
08-30-2016, 12:05 AM | #788 |
A320 Pilot/USAF Retired
Maintenance is a good thing!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-30-2016, 09:36 AM | #789 |
You are so correct, should have been done long ago...Jim
08-30-2016, 11:56 AM | #790 | |
It's what's keeping me from getting mine on the road. Good luck with the up grade. Kim |
08-30-2016, 05:49 PM | #791 |
24,000 mi is still not to bad for a toy. Will a single v belt run the 105A alternator?
08-30-2016, 07:37 PM | #792 |
Thanks Kim, hope the rehab is coming along, you'll be back at it soon...Jim
08-30-2016, 07:38 PM | #793 |
Thanks lower, I think it will be OK, will have to way and see...Jim
08-31-2016, 01:45 AM | #794 |
maybe someday I will have a truck long enough to
a. do maintenance on parts that wear out or b. get some kind of value out of all the new parts I buy haha looks really great!
08-31-2016, 10:38 AM | #795 |
Thank you...Jim
09-02-2016, 04:22 PM | #796 |
Well, I'm back with an update, but not what I had hoped. When I picked up the alternator yesterday, George showed me on his test machine it was putting out 102 amps and 14-1/2 volts. So I installed the new belts and alternator and fired up the truck. At idle it was only showing 12 volts, anything above 1500 rpm showed 14-1/2. I was not happy, this was really worse that with the 85 amp.
This morning I took the truck to George's shop and he said this wasn't right, it should show at leat 14 volts at idle in gear. He said that the new stator may have to much air gap between it and the rotor. He was going to call his parts people and get back with me, but it could be Monday before he has an answer. My alternator is the old 10Si unit was orginally a 63 amp, which I had George change to an 85 amp in 1996. If this doesn't come up with an answer and no additional cost, I will just buy and new 105 amp unit and paint to match the other engine stuff. (That was the main reason for having it redone, I didn't want to paint the new unit). I know everyone likes pics, so here's a couple showing new belts and gauge with readings. I will let everyone know how it works out...Jim
09-02-2016, 11:21 PM | #797 |
Sure do like your gauges.
Kim |
09-02-2016, 11:29 PM | #798 |
Yes I liked those, they are the same Classic Ins I used in my 55 GMC
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-03-2016, 11:13 PM | #799 |
Thanks guys, I've always liked them...Jim
09-08-2016, 09:50 AM | #800 |
How did it test ok then not work when it was installed?
