Old 01-02-2013, 10:55 PM   #76
Crash_OK
Crash_OK's Avatar
Re: LS factory cruise control hook up
Originally Posted by Hart_Rod View Post
I have a HND-3 from Dakota Digitial.
http://www.dakotadigital.com/index.c...prod/prd50.htm
How will it work with a 2006 DBW? I installed the handle on a Flaming River tilt column and it was a PITA to get the wires pulled through....
It requires a few relays to make that switch work with the DBW.. See below
There may be more info in my build..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 01-05-2013, 12:04 PM   #77
Daaaanz67
Hey nova you have a pm
Daaaanz67 is offline   Reply With Quote
Old 01-05-2013, 12:06 PM   #78
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Crash_OK View Post
It requires a few relays to make that switch work with the DBW.. There may be more info in my build..
Good info. Does anyone make those for sale? If so, how much?
Hart_Rod is offline   Reply With Quote
Old 01-05-2013, 01:19 PM   #79
Crash_OK
Crash_OK's Avatar
Not that I know of.. It would only take the first two relays, the 3rd is one I added for the DD gauges..
Any type of relay would work.. you would not have to use the micro ones I used. You could use regular Bosch type relays...
Mark
Crash's 69 4x4 SWB
Old 01-05-2013, 01:24 PM   #80
Hart_Rod
Hart_Rod's Avatar
PM sent.
Old 01-05-2013, 01:49 PM   #81
Hart_Rod
Hart_Rod's Avatar
Crash, clean out your PM box......
Old 01-05-2013, 01:50 PM   #82
Crash_OK
Crash_OK's Avatar
done
Mark
Crash's 69 4x4 SWB
Old 02-02-2013, 12:51 AM   #83
Oilbrnr
Oilbrnr's Avatar
What does it take to get cruise working on a GenIV?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 04-24-2013, 02:01 PM   #84
RatRod68
RatRod68's Avatar
Scribed to this one too
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 06-23-2013, 02:14 PM   #85
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Hooked mine up on my 72 GMC with 01 6.0 dbc but its not working. I have led taillights. What do I need to check ?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 06-23-2013, 05:00 PM   #86
ls1nova71
ls1nova71's Avatar
You need to put some sort of load on the circuit. On the brake switch there is an orange wire and a white wire. The orange is constant hot, the white gets power when the brakes are applied. Try hooking a light bulb on the white wire with the other side grounded and see if it works. The light will come on when the brakes are applied if you hook it up right. The bulb needs to be something like an 1157 or close, a peanut bulb like in the dash won't cut it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-23-2013, 06:53 PM   #87
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I have power at pink and purple. Am I supposed to have any power at vss out or K on module?
Old 06-23-2013, 07:29 PM   #88
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Hooked a 2k resistor in there and now it works. Thx.
Old 07-22-2013, 09:12 PM   #89
dkauffman05
dkauffman05's Avatar
I just swapped in a 6.0 in a 86 k10 with a 700r4 Mabee I missed something but can this work with a 700 r4 with a psi harness? I have the cruse box that would mount on the firewall of a 99-02 truck. My swap is also drive by cable.
dkauffman05 is offline   Reply With Quote
Old 07-22-2013, 10:10 PM   #90
ls1nova71
ls1nova71's Avatar
Maybe. What are you doing for a speed sensor (VSS)?
Old 07-23-2013, 07:20 AM   #91
dkauffman05
Well it's an 86 so it has a cable speedo. So I'm assuming unless I get some aftermarket converter to get a vss output it's a no go?
Old 07-23-2013, 10:09 AM   #92
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Speartech labeled a yellow wire for my speedo output. I spliced into that on mine.
Old 07-23-2013, 10:14 AM   #93
ls1nova71
ls1nova71's Avatar
Yes, I'm afraid so. You need some kind of speed sensor to get a signal for it to work.
Old 07-23-2013, 11:02 AM   #94
Hart_Rod
Hart_Rod's Avatar
This would probably work:
http://www.dakotadigital.com/index.c...rod/prd109.htm
Old 08-19-2013, 12:55 PM   #95
1965Impala
I almost forgot about the pics, and I don't have alot of time right now, so I couldn't find the good pics, but here's one of them on my truck. I have the ribbed kind and the smooth kind, both these pics are the ribbed. The smooth are $45 shipped and the ribbed are $50 shipped.
LS1nova71, I would like to have one of the Cruise Control switches you offered in post #54. I will PM you. Thanks.
1965Impala is offline   Reply With Quote
Old 11-12-2013, 05:48 PM   #96
tsetsaf
Back over on page 2 of this thread "farmtruck" asked about dbw, cruise, and the ebrake. I believe I am running into this same issue. I have a 2005 DBW out of a Tahoe and have wired, checked, re-checked, and checked again all of the cruise, brake switch, and TCC switch connections... all are good but still no cruise.
How do I get the cruise to work? I have a total of three harness connections. 1. The main harness to the computer
2. Two harnesses on the TAC black box.
I have spent hours looking for possible solutions with no results. Any help is appreciated. Thanks.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 11-12-2013, 09:18 PM   #97
ls1nova71
ls1nova71's Avatar
Couple of questions. What kind of switch are you using? Di you have three wires coming from the TAC module hooked up? What kind of brake lights do you have? Do the brake lights come on with very little pressure on the pedal?
Old 11-12-2013, 09:41 PM   #98
tsetsaf
It is Rostra/ Dakota Digital style switch. I have "corrected" the signals using two relays, and confirmed proper signal with a test light. Farmtruck responded to my PM and stated that his problem was "My stalk was not getting good connection ". I am not sure what that means so I have asked him for clarification. Should I test the signal at the TAC to see if a certain voltage is present?
4 wires from the tac for the cruise: gry/blck, blue, gry, light blue. Light blue to brakes "on" switch (again used a relay here for the blue brake and TCC purple).
Brake lights are standard and I have adjusted the brake switch so they come on when the pedal is pressed. Should I check to see if there is a voltage leak out of the switch? It is the original.
Thanks for the questions your name comes up in a ton of forums regarding cruise and LS swaps, nice to know I am in good hands.
Mark
California Truck
Old 11-13-2013, 12:07 AM   #99
tsetsaf
PROBLEM SOLVED! After replying in the message above I went out to dinner. This has been driving me nuts and I am sitting there eating when it hits me... I had wired the light blue brake "on" wire into the relay opposite the TCC. Technically correct, it will get 12 volts when the pedal is pressed, it also creates the same problem found when folks install leds with no resistors = no resistance on the line.
Got home, grabbed the flashlight and attached the light blue wire direct to the brake lights "on" side of the brake switch. Woohoo we have cruise. See you are a miracle worker.
California Truck
Old 11-13-2013, 05:34 AM   #100
ls1nova71
ls1nova71's Avatar
Cool, glad you got it figured out. Saves me a lot of typing on my phone. Lol
