Old 08-09-2016, 12:22 PM   #976
Flysocal
Re: Dutch '59 Fleetside Longbed
Good looking truck. Love the fleetside.
Flysocal is offline   Reply With Quote
Old 08-09-2016, 03:28 PM   #977
lower50's
lower50's's Avatar
The lettering looks great. The ghost Fleetside will be cool.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-11-2016, 05:43 PM   #978
RockinKees
RockinKees's Avatar
Thanks guys!!
Are there transmission guru's here?
I got a problem, but this time I don't trust the torque converter....
As you might know, we repaired the trans itself a few weeks ago, the frictionplates were separated from their steel plates, probably due to coolant in the trans (see the pics a few postings back).
Is there a possibility that this could be the case with the internals of the converter also? If there is such a clutch in there....
What I find is that this trans is very soft when you put it in gear, you won't feel it shift from P to D or R. Also there is no change in rpm from P to D or R. My TH350 was much "stronger" when you put it in gear, plus you saw it drop in rpm and felt it was pulling, you had to put your feet on the brake.
This TH 400 never did that, never felt it shift in gear, also in D the gearchange was very smooth. I could adjust it a little by turning the little screw in the vacuummodulator. The changes were noticable.
Now the truck stood for two days and have almost excactly what I had before. Must give way to much throttle to get a respons.
Oil level is good, smells not burned, looks bright red.
If I have some time I will let some oil out to see how it looks.
So my question, could this be a converter failure??
As the trans itself has maybe 50 miles on it after repair....
Also no strange sounds heard while driving or idling or when charging gears.
Please help??
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-09-2016, 10:54 AM   #979
RockinKees
RockinKees's Avatar
So, I'm back from vacation.
Had a great time with the family!!
I just looked at the trans, tried a few things, nothing seems to help...
After three weeks standing still it shifts like never before.
Seems no one has an answer to this trans problem, I think the converter is broke, but I also found very dirty oil after some 50 miles.
I don't trust it anymore, so I got myself a TH700R4 trans.
Some things have to be changed, have to make a new a new driveshaft also.
The trans is from 1991, out of a Caprise hearse with almost 80000 miles on it.
Hope this one is better....
Here we go again...
It's almost two inches longer than a TH400 and just went in without unbolting extra stuff!
Now have to buy or make a bracket for the TV cable, make the shiftlever at the trans, change oil and filter and find a driveshaft we could modify to fit.
Then I hope the trans troubles are history!!
Cheers!! Kees.
Kool Guyz CC
Old 09-09-2016, 11:27 AM   #980
Katrina/10
Katrina/10's Avatar
That should work out nicely, you'll get some highway speed out of that one. Don't forget to hook up the lockup converter clutch. What ratio is your Jag rear?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-09-2016, 12:13 PM   #981
RockinKees
RockinKees's Avatar
Jag rear has 2.88 with limited slip diff.
I was looking for a diagram to make the lock up work in 2, 3 and 4.
Handy when you tow something. Ofcourse brake release!
Cheers!! Kees.
Kool Guyz CC
Old 09-09-2016, 12:23 PM   #982
Katrina/10
Katrina/10's Avatar
With a 2.88 and overdrive you should get good fuel mileage! There are some kits that use an engine vacuum diaphragm switch with power run through the brake light switch. Not sure which gears you can lock the converter, mine just does it in third or overdrive.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 09-09-2016, 01:13 PM   #983
lower50's
lower50's's Avatar
Hope the new to you trans works good.
1951 MG TD
Old 09-09-2016, 09:55 PM   #984
Advanced Design
Advanced Design's Avatar
Big thumbs up Kees. Swapping a trans out by the street is hard core cool. Hope it works well!
Advanced Design is offline   Reply With Quote
Old 09-09-2016, 10:16 PM   #985
dug224
dug224's Avatar
Now THAT's a vacation...4 weeks?? Good luck with the fresh trans. dug
dug224 is offline   Reply With Quote
Old 09-10-2016, 01:48 AM   #986
Nut Case
Nut Case's Avatar
Kees
Just a thought, did you drain the old converter and replace with fresh oil?
Sorry to hear about the tranny problems, Good luck
Keep on keepin on
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-10-2016, 08:47 AM   #987
reaper71
reaper71's Avatar
Good to see you back!!
Mark...
reaper71 is offline   Reply With Quote
Old 09-21-2016, 03:39 PM   #988
RockinKees
RockinKees's Avatar
Thanks guys!!
@ Nut Case, a few posts back you can see what I did with the converter, I think the problem of the TH400 is in the valvebody, as if it at times builds no pressure. Stuck valve or something. Had this problem before with this trans, since the beginning of the build troubles with this trans...Took it apart three times, had enough of it
Small update....
"New" trans is completely in and working
I found a steel driveshaft I could shorten, so I bought that one.
Looks very rusty, but it's only surface rust.
How I shorten the driveshaft in pics:
With this all done, I had to make a new shift lever, because the Overdrive trans has a longer "reach". I made a new lever with the mountinghole for the shift rod at another place, otherwise I couldn't get it to work properly. No pics made of that, yet...
Also, the TH700R4 uses a Throttle Valve cable, where a TH400 uses a vacuum line.
So I had to buy or make a new bracket at the carb to take this TV cable.
I got a used bracket which I modified a bit to take the both of the cables. Throttle and TV cable.
I also had to make a pin to where the TV cable mount on.
The modified bracket:
New turned TV cable pin:
Bolted to the carb, cables hooked on:
Don't mind the return springs, I've got to buy some new ones....
This afternoon I drove the truck and I must say, it drives really good
Must finetune the TV cable, it now shifts a bit early, but I think my transmission troubles are history!!
Only have to wire the Lock Up converter and I'm Ready to Rumble the streets!!
Cheers!! Kees.
Kool Guyz CC
Old 09-21-2016, 05:20 PM   #989
Katrina/10
Katrina/10's Avatar
Oh, no, I can't see the pictures!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 09-21-2016, 10:13 PM   #990
Advanced Design
I can't see the pictures either and I am glad you got your transmission installed.
Old 09-21-2016, 10:19 PM   #991
oldman3
oldman3's Avatar
Me three no pics...Jim
oldman3 is offline   Reply With Quote
Old 09-22-2016, 07:38 AM   #992
Kim57
Kim57's Avatar
No pics.
Just an empty space where they should be.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-22-2016, 03:49 PM   #993
RockinKees
RockinKees's Avatar
No pics?
Strange....
On the computer they are visible, but on the iPad there's none....
I'll try to get it right.
Cheers!! Kees.
Kool Guyz CC
Old 09-22-2016, 06:10 PM   #994
lower50's
lower50's's Avatar
Glad to hear but not see the trans is working. It can be very frustrating.
1951 MG TD
Old 09-22-2016, 09:04 PM   #995
Advanced Design
Originally Posted by RockinKees View Post
No pics?
Strange....
I have an IPad and don't see the pics....
Old 09-23-2016, 08:25 AM   #996
MalibuSSwagon
I'm betting there some sort of privacy settings on the pictures, that needs to be set to public.
MalibuSSwagon is offline   Reply With Quote
Old 09-23-2016, 05:29 PM   #997
RockinKees
RockinKees's Avatar
Settings are right, they're on public?
Can you see this one then?
It shows on my computer....
Cheers!! Kees.
Kool Guyz CC
Old 09-23-2016, 05:31 PM   #998
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I see it!
ChuckDriver is offline   Reply With Quote
Old 09-23-2016, 05:35 PM   #999
RockinKees
RockinKees's Avatar
Originally Posted by ChuckDriver View Post
I see it!
The other pics too ChuckDriver??
Cheers!! Kees.
Kool Guyz CC
Old 09-23-2016, 05:42 PM   #1000
RockinKees
RockinKees's Avatar
Thanks guys!!
Small update....
I did quote the whole text, incl the pics, is it visible now?
Cheers!! Kees.
Kool Guyz CC
