Old 05-09-2017, 05:15 PM   #1126
RockinKees
RockinKees's Avatar
Re: Dutch '59 Fleetside Longbed
Thanks Mark!!
Hopefully I thought it out well and works like I intended to...
We'll see tomorrow.
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-09-2017, 05:28 PM   #1127
lower50's
lower50's's Avatar
Did you design the parts yourself?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-09-2017, 07:14 PM   #1128
oldman3
oldman3's Avatar
Kees, like Mark said, super nice pieces...Jim
oldman3 is offline   Reply With Quote
Old 05-13-2017, 02:34 PM   #1129
RockinKees
RockinKees's Avatar
Yes sir, I did.
There aren't many who did a Jag IRS on airride. With all the pics I found on the internet, I decided to invent the wheel myself...let's see how it works...
oldman3
Thank you Jim
Cheers!! Kees.
Kool Guyz CC
Old 05-13-2017, 02:57 PM   #1130
RockinKees
RockinKees's Avatar
I started with some templates and went on from there.
We had the steel plates set at the angles we needed, drilled the holes for mounting first.
I have to bolt the pieces together because the the lower threaded bars are out of one piece, so I can't bent the plates over it.
The lower bag plate bolts to the vertical plates. I also made an extra angle from the bagplate to the sides. All plates are 1/4" thick.
Only thing to do for the rear is a mounting place for the shocks, that won't be such a problem I think.
(don't know why my all my pics are on there side...)
Pic #1 - the templates
Pic #2 - test fitting with airbag
Pic #3 - Extra angle piece from bagplate
Pic #4 - tack welded the upper plate on
Pic #5 - better view from the side
Cheers!! Kees.
Kool Guyz CC
Old 05-13-2017, 03:16 PM   #1131
RockinKees
RockinKees's Avatar
Also been busy on the front.
They all said front is easy!!! Take the springcup out and bolt in the bag...
Yeah right.....
I took a special drill for the spotwelds, drilled out the spotwelds....but, I came across a little hole, that was rusted through.
So, I came up with a different idea to cut away a nice piece of subframe, and weld in a 1/4"plate at which I can bolt another 1/4"plate which at his turn holds the airspring. Problem solved
At first, again, made a template.
I made the upper plates with a grinder, drilled in the large holes and tackwelded it to the subframe.
I have to make the plates for the bags yet.
Pic #1, 2 - what I removed from the subframe
Pic #3 - Drilling the upper plates, Action shot
Pic #4 - Tackwelded the plate in. You can see that the holes are big enough
to bolt in the airbag later on its own plate.
Pic #5 - How I cut the plates...
Now I'm busy with the pics, I know why the pics are on its side, try to take better pics next time!
Cheers!! Kees.
Kool Guyz CC
Old 05-13-2017, 11:25 PM   #1132
oldman3
oldman3's Avatar
Kees, you don't let things stop you, you just take care of the problem. Nice job...Jim
Old 06-23-2017, 04:41 PM   #1133
RockinKees
RockinKees's Avatar
Haha, That's right Jim!
I haven't sat still the last few weeks. I will show you in the next couple of posts...
I have got the airride in working order, but that's just on the ramp.
Didn't test it yet on the ground.
All the tests went well, it goes up and down, all four corners individually switched, two double needle gauges, compressor goes automatically on and off.
I'll show you some pics of the front first (excuse me, they are on their side again )
Pic #1 and #2, I welded in a 1/4" plate onto the subframe that was partly removed. I made the same plate for bolting the airbags to, so that I can unbolt them in the future when needed.
Pic #3 are the lower control arm plates. I removed the spring cups and welded in a flat 1/4" plate for mounting the bag.
Pic #4 is the complete assembly.
Cheers!! Kees.
Kool Guyz CC
Old 06-23-2017, 05:04 PM   #1134
RockinKees
RockinKees's Avatar
Let's talk swaybars....
I wanted the switch front swaybar to the back and make a new one from a Chevy Van up front.
This because of the difference in thickness. The front is 7/8" and the Chevy Van bar is 1 1/16".
First, I switch the front to the back, all went really well. Then I modified the Chevy Van front swaybar up front, but when bolt that to the chassis and the lower control arms, I didn't have enough wheelspace to steer...my bad....
So, I switched the swaybars again from back to front and vice versa, now it must work...I hope....
Pic #1: how the front swaybar mounted at the back. Looks great!
Pic #2: Here's the difference in width that I didn't thought off. Also the 3/8" plate that I used to make the swaybar arms of. You also can figure out why the steering didn't work with this Chevy bar up front...
Pic #3: How I make the rear swaybar arm fits to the Chevy Van part. The arms are about 5" longer as the stock Chevy parts.
Pic #4: Test fitting the rear swaybar.
Pic #5: The end result...
Cheers!! Kees.
Kool Guyz CC
Old 06-23-2017, 05:18 PM   #1135
lower50's
lower50's's Avatar
Nice job it should ride nice and flat like a race car.
1951 MG TD
Old 06-23-2017, 05:32 PM   #1136
RockinKees
RockinKees's Avatar
Now the IRS.
It went smooth I think. Made some templates, had them laser cut and bolted them in.
Had to remove some material of the aluminium hubcarriers to make enough room for the airbags.
Also made some extra gussets for strenght and for bolting the shocks on and for the swaybar.
I think it is plenty strong now.
The pics, well, they're on their side again
Pic #1: The airbag at rideheight, you can also see how much material I removed from the hub carrier, it's normally one straight line to the top at the back. I my previous post you see that I added an extra gusset to the front plates for extra strenght. They are at both the front pieces, left and right.
Pic #2: I used the original Jaguar shockplates to weld the brackets on for shocks and swaybar.
Pic #3: Top shockmount, I's a 3/8" plate, bolted on the chassis with three 3/8" -8 grade bolts. The shock itself uses 1/2" bolts up and down.
Pic #4: View from behind.
Cheers!! Kees.
Kool Guyz CC
Old 06-23-2017, 06:25 PM   #1137
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-23-2017, 07:07 PM   #1138
oldman3
oldman3's Avatar
Kees, some nice work, but I have one question. Isn't the front sway bar suppose to be larger that the rear?...Jim
Old 06-23-2017, 07:52 PM   #1139
Advanced Design
Advanced Design's Avatar
Nice work Kees. Very resourceful development...love it!
Advanced Design is offline   Reply With Quote
Old 06-23-2017, 08:46 PM   #1140
Clarance J
Clarance J's Avatar
Hey Kees. A bunch of posts back when I saw the words air ride I knew that there were some interesting pictures coming up. I was not disappointed.
(even if some were sideways). Enjoying what I'm seeing. Good work there. Its always fun designing and fabricating something (like air ride with Jag suspension in a 1959 Chevy) and making it work.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 06-24-2017, 05:54 AM   #1141
RockinKees
RockinKees's Avatar
Thanks guys for the kind words!!!
I have more pics to post
Yes it is. A stiffer swaybar in the back gives more oversteer. That's why I wanted to switch bars, that didn't work out due to the width of the Chevy Van bar.
I kept the arms of this bar longer hoping it will soften enough.
But then, I don't know the rates of these swaybars, it's a matter of trial and error I think. But that's Hot Rodding I think, I'm not afraid to try new things out
We will see when we're driving again...
Cheers!! Kees.
Kool Guyz CC
Old 06-25-2017, 04:13 PM   #1142
RockinKees
RockinKees's Avatar
I have more to show..
The airtank, valves and compressor are all hidden under the bed.
I made a frame from stainless steel that fits right between the IRS and the gas tank, just behind the rear axle.
I made some aluminium plates to protect all this from too much water and dirt.
The plates are mounted on the front and sides of the frame and at the complete underside.
It's all removable for excess if needed. I'm gonna make a sort of a shutter in the bedfloor to be able to excess from above if there's something wrong.
I do all this because I just want nothing in the bed or in the cab.
All stainless steel welding is done by my buddy who has his own welding company, so all credits to him!!
Pic #1: testing the homemade Stainless Steel airtank, it's 3.1 gallons (12 liters)
Pic #2: Tank and compressor on the frame, valves fit in between
Pic #3: Valves mounted and airlines done. I also use two reducing valvalves for controlled deflating the airbags. Front and rear seperated.
Pic #4: Complete frame assembled and mounted under chassis.
Pic #5: the aluminium plates to protect from dirt
Cheers!! Kees.
Kool Guyz CC
Old 06-25-2017, 04:34 PM   #1143
RockinKees
RockinKees's Avatar
One more to show...
Remember my steering column around my header? As Kim said then, it looks like a snake
Well, it worked, but I have a small heavy point when I steer to the right.
The rubber blocks at the steering rack presses the rack to the left when I steer to the right, it then pushes too hard at the extra bearings in the column, that's why the heavy point in the steering.
So, to get rid of this, I have to re-route the column...or the header.
The only way to solve this little problem is to find another left header.
But after five different headers I know this is not going to be easy.
Thus we, buddy René, the welder, and me decided to make my own header.
I route the header and René welds it together, easy does it!!
After three hours of grinding and puzzling tubes, I tacked together a header.
The column goes through it, problem solved!!
René did all the TIG welding on the header.
I could use most parts of the old header and with some new tubes, the collecter is almost at its original place, job well done
Pic #1: the old original header wit the old steering snake
Pic #2: What I did grind of to make the new one.
Pic #3: The re-route of the new header
Pic #4 and 5: the end result
Cheers!! Kees.
Kool Guyz CC
Old 06-25-2017, 04:46 PM   #1144
RockinKees
RockinKees's Avatar
With the new airbags in place I have to make a new exhaust too.
There is simply no more room to put it back together as it was.
I now have to dump in front the rear axle, I hope that the drone will keep in limits...
The header is bolted to the block, steering shaft has now two joints, one upper at the column and one at the rack, that's the minimum
Hope you can see how it is now:
Pic #1: seen from underside up
Pic #2 and 3: from above.
I have plenty of room for the shaft and header. It has to be good now...
Cheers!! Kees.
Kool Guyz CC
Old 06-25-2017, 11:10 PM   #1145
oldman3
oldman3's Avatar
Kees, all I'm going to say is WOW...Jim
Old 06-26-2017, 03:23 AM   #1146
Nut Case
Nut Case's Avatar
Strong work
Nut case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-26-2017, 09:36 AM   #1147
reaper71
reaper71's Avatar
Looks good Kees!!
Mark
reaper71 is offline   Reply With Quote
Old 06-26-2017, 12:35 PM   #1148
lower50's
lower50's's Avatar
Very nice work!! good thinking on how to solve the problems. As for your sway bar (thicker on rear) On my old lifted Jeep I put a Jeep front sway bar on the rear and I don't have one on the front. It's been that way for 20 years with no problems.
1951 MG TD
Old 06-26-2017, 03:59 PM   #1149
RockinKees
RockinKees's Avatar
Thanks Jim, Nut Case and Mark!!
Thanks Lower! Good to know it worked out for you, gives me confidence it will work for me too.
Cheers!! Kees.
Kool Guyz CC
Old 06-26-2017, 07:22 PM   #1150
rusty76
rusty76's Avatar
I'm really late for this one but I'm in for a cool build.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
