03-31-2013, 04:35 PM | #101 | |
Re: ls turbo build
That will place the turbo in the exact same spot the AC compressor when using the Kwik Performance/Vintage Air bracket. Posted via Mobile Device
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
03-31-2013, 04:40 PM | #102 |
Re: ls turbo build
I'm gonna mount mine in the middle up front. If camaro guys can surely I can. Gonna run. 76mm for a while with truck manifolds. What size is your turbo?
Posted via Mobile Device |
03-31-2013, 05:19 PM | #103 |
Re: ls turbo build
bw s475 t6 flange. Ill look into a ac bracket that will hold the ac compressor mid mount...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
04-01-2013, 10:08 AM | #104 |
Boosted Member
Re: ls turbo build
Easier said than done. Have you actually set the turbo in between the engine and radiator? I have. It didn't fit.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
04-01-2013, 10:25 AM | #105 |
Re: ls turbo build
no i havent yet. just figured if camaro guys can we should be able too. been kinda worrying about my turbo being so heavy i was wondering how to mount it. my turbo ended up being a 88mm. its a little to big but got it cheap so will try it.
sorry 69trk not trying to hijack. i will be following the build. |
04-01-2013, 01:33 PM | #106 |
Re: ls turbo build
http://www.theturboforums.com/thread...-1970-c10-s475
ck this out, i like how he ran his merge and his mounting of the turbo. |
04-01-2013, 03:01 PM | #107 | |
Re: ls turbo build
04-01-2013, 04:07 PM | #108 | |
Boosted Member
Re: ls turbo build
04-01-2013, 05:21 PM | #109 |
Re: ls turbo build
04-01-2013, 10:39 PM | #110 |
Re: ls turbo build
Could you make me one of those ac compressor brackets?
04-02-2013, 09:20 AM | #111 |
Boosted Member
Re: ls turbo build
I didn't have time to make the setup myself. I got the brackets from a guy on LS1tech that goes by fox12303
It's about 3x the cost of the Kwik setup, but worth it for my application...IMO.
04-15-2013, 11:33 PM | #112 |
Re: ls turbo build
I'm currently building a twin turbo set for my 67 chevy truck.
67-C10 under construction 2002 ECSB Chevy 5.3l with t-70 turbo 216/218 114lsa and 4l80E Built trans w/ 2500 stall |
04-22-2013, 08:32 PM | #113 |
Re: ls turbo build
Installed my wilsons 90mm throttlebody. Had to make a wheel bracket for the throttle cable to work. Installed the starter, alternator and most of the hydraboost unit. Finally received all my guages so I can start back to wiring the truck.
05-19-2013, 07:18 PM | #114 |
Re: ls turbo build
Finishing up the wiring harness. Also installed the fuel rails and 120lb injectors. Finished the dash and guages. Making some progress very slowly....
05-19-2013, 07:31 PM | #115 |
Re: ls turbo build
Looking good been wondering how your project was coming sinc I'm just collecting parts
06-17-2013, 04:07 PM | #116 |
Still Learning
Re: ls turbo build
Very cool project! Love the plans for this one. Subscribed....
07-24-2013, 01:26 PM | #117 |
Re: ls turbo build
Subscribed...Great Job and Info so far
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles Work in progress....Got the truck for free all original |
07-24-2013, 10:32 PM | #118 |
Re: ls turbo build
Thanks. My dad passed away last month and I have alot to do. Just sold his 41 to help put my mom in a home.. sucks when I have any free time I work on my old truck. About to finish the fuel lines. Then finish mounting the computer and wiring harnesses..
07-25-2013, 04:06 PM | #119 | |
Re: ls turbo build
07-25-2013, 04:10 PM | #120 |
Re: ls turbo build
Condolences to you and your family.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-28-2013, 11:18 AM | #121 |
Re: ls turbo build
Got the ronfrancis wiring all installed and everything works except for the dome light when i open the doors I also got the fuel lines finished, just need to buy a couple gallons of gas and cycle the fuel thru the filter to make sure everything is clean.... Then i'll plug the oil feed and return so i can put some oil in it and crank it to lubricate the engine.... next thing is ordering my ac system and installing radiator and mounting ecu and running the holley hp wiring.... slowly getting there... I would upload pics but for some reason all my file types are to large even after i shrink them...
08-20-2013, 08:43 PM | #122 |
Re: ls turbo build
Trying to post pics. Mounting ecu in center console.
08-20-2013, 08:51 PM | #123 |
Re: ls turbo build
Trying to figure out how to mount intercooler. Looks like I will have to modify inner grill in order for ac condensor to fit..
08-20-2013, 08:59 PM | #124 |
Re: ls turbo build
Engine bay is starting to look pretty good. Need a few more sensors and plug wires and im buying the holley coil covers..
08-20-2013, 10:50 PM | #125 |
Still Learning
Re: ls turbo build
Hey, sorry to hear about your dad and Mom. The engine bay looks great. Keep the updates coming.
