Old 04-26-2016, 04:21 PM   #151
lower50's
lower50's's Avatar
Re: Project Orange Crush (57 3100)
Wow that sounds like some crappy customer service. Nice score on the ps bracket.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-26-2016, 05:21 PM   #152
Valarius_Starchaser
Valarius_Starchaser's Avatar
Sure is 3 more calls and nothing one time it rang for two minutes the next two it only rang for 20 seconds and went to voicemail.....
total nightmare with a set of 5 clutchs and steel at stock .080 and .090 thickness the assembly will come in .075in TO SHORT its like the machinest just guessed at how much he had removed and called it "good"
I am going to start calling around my town and seeing if anyone can remove the required mills to make this assembly fit a set of 6 like was claimed originally
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 04-26-2016, 06:45 PM   #153
jed971959
Hi
why not use the forward steels .77 to get right clearances with 6 clutches
Jim
jed971959 is offline   Reply With Quote
Old 04-27-2016, 08:04 AM   #154
Valarius_Starchaser
Because even with the six .077 steels it is still to tall after we calculated it I would need six .060 steels and six .075 frictions (or thereabouts) and it would end up costing me more then what the piston did in the first place at this point it's more about the fact that this company has blatantly lied
I opened a ticket with the EBay seller last night maybe that will get somebody in high gear
"Orange Crush"
Old 04-28-2016, 02:01 PM   #155
Valarius_Starchaser
Got a call a few hours after I started the conversation with the Ebay seller from the manufacturer I confirmed I had the correct 4L80e direct drum and clutches and measured the piston they sent me at .765 and they said "uhmmm" it should be .665-.670 and will send me one ASAP I don't have a tracking number but am hoping to see it before the weekend because DRUMROLLLLLLLLL
Out with the old
In with the new!
New torque converter came in today! (sorry for the picture atop my mini fridge at work )
"Orange Crush"
Old 04-28-2016, 02:05 PM   #156
Valarius_Starchaser
Also big shoutout to lockdoc even though I managed to confuse him for a minute on what exactly my issue was he helped me sort out my ignition cylinder issue so now I have a key that operates both the door and the ignition and doesn't pull out of the ignition when in the on position! It's the simple things that count
"Orange Crush"
Old 04-28-2016, 02:18 PM   #157
Valarius_Starchaser
And lastly but not least I threw out a WTB add on my local craigslist for a set of doors and found a fair set for a decent price and if all works out I will get them Saturday
"Orange Crush"
Old 04-28-2016, 03:26 PM   #158
lower50's
lower50's's Avatar
Triple score!! Maybe quad score if the Ebay thing works out.
1951 MG TD
Old 04-28-2016, 08:46 PM   #159
Advanced Design
Advanced Design's Avatar
Yeah Valarious, you are due for somethings to come together for you. Hopefully the streak will continue.
Advanced Design is offline   Reply With Quote
Old 04-29-2016, 12:12 AM   #160
Valarius_Starchaser
I hope so too AD I told a co-worker with my timeframe in mind (4 months from now) the truck needs to be "done" enough to drive and do one nasty burnout out of our wedding (per my fiances wishes)
So in true nature of achieving that goal a friend of min and I hashed out what size tires I should run with my end goals in mind and for the rears we have decided on a 31*10.5R15 which are the only ones we managed to figure out because they were damn hard to find in a decent tread for what I needed a lot of sizes that tall were getting into truck treads and needless to say that did not fit my needs
Here's a post with a truck I found that has a similar ride height/stance to what I am looking for in mine thoughts?
http://67-72chevytrucks.com/vboard/s...00&postcount=9
"Orange Crush"
Old 05-01-2016, 12:08 PM   #161
Valarius_Starchaser
I spent yesterday working on the transmission after I got the doors dropped off I found the 3rd accumulator spring broken in half so I got a new GM one coming.
Since I was then at a standstill with that project I started to tear into the doors a bit I got the glass out and they are now ready to be chopped (still deciding if I want to do suicide doors or not)
The doors look great I have two small rust holes and some dents much better then what I had before I would be willing to bet I will only have 10 hours into getting these doors chopped and ready to paint so that just saved a TON of time now if only it would stop raining!
Then today there was a small swap meet at the fair grounds in my town I wasn't able to find any parts I could live without but I did get some IRWIN Vise Grip Panel clamps and Sheet metal clamps to help with the doors for a good price.
"Orange Crush"
Old 05-01-2016, 07:30 PM   #162
Advanced Design
This is an aggressive look...I like it.
Old 05-01-2016, 11:17 PM   #163
Valarius_Starchaser
Thanks AD going for a little bit of pro street rod truck I think it will work out
I did a ton of body work on the passenger side door today I pulled and hammered out ever dent and payed my first coat of glaze over those areas
Some of the dents were deep enough that I had to drill a hole for a bolt to pull them but no big deal there but I did leave the rust holes and the drill holes for another day but as of now that doors is at the half way point in just 2 hours!
I will have some pictures tomorrow
"Orange Crush"
Old 05-02-2016, 08:14 AM   #164
Valarius_Starchaser
Alright time for some pictures
All taken down with 80 grit
Pulling dents the "old fashioned" way as I don't have a stud gun
This is the worst of the rot
"Orange Crush"
Old 05-02-2016, 08:17 AM   #165
Valarius_Starchaser
This was a fun dent to pull
With a bit of hammer and dolly work it looks pretty straight not to shabby
Laid some mud on the dents that I didn't need to drill and pull out
"Orange Crush"
Old 05-02-2016, 08:19 AM   #166
Valarius_Starchaser
Between the Panel clamps and the flat sheet metal clamps I got yesterday at the swap meet I was able to make quick work of all the dented and dinged up edges which was nice for a change because normally that turns into a job for a 3lb mini sledge
"Orange Crush"
Old 05-02-2016, 08:20 AM   #167
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-02-2016, 09:37 AM   #168
lower50's
lower50's's Avatar
Great job on the doors. It takes time but can be very satisfying.
1951 MG TD
Old 05-02-2016, 05:33 PM   #169
Valarius_Starchaser
Originally Posted by Kim57 View Post
Looking good.
Kim
Thanks a lot Kim
Very satisfying I'm not going "show finish" I want to drive it and have fun (that's what they all say)
I got the new direct clutch piston in the mail and it is .100 thinner then the last one so it should work fine
"Orange Crush"
Old 05-02-2016, 05:55 PM   #170
RockinKees
RockinKees's Avatar
Nice repairs on the doors!
Sometimes I wish we had salvage yards full of really old cars overhere where we could pull the parts of
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-03-2016, 04:21 PM   #171
Valarius_Starchaser
Thanks Kees I try to atleast act like I know what I'm doing every once and awhile
I spent some more time on the doors last night welded all my pulling dent holes (is that what you call them?) and ground them then laid some mud on the low spots from the original coat from last night as well as some new found areas
Here's two pictures of the welds ground down I got things a little hot with the grinder. It feels like I haven't done this in forever and feel a little rusty I'm having a heck of a good time though doing it
"Orange Crush"
Old 05-03-2016, 04:31 PM   #172
Valarius_Starchaser
Back to my tire choice it has been finalized and I will be buying General HTS60 Grabbers
My tire dealer stocks them in my 31*10.5R15 and are rather cheap and don't look like a truck tire and are also available in 235/65R15 which should give a decent rake
So for those who care (anyone?)
Here is a side by side
https://www.tacomaworld.com/tirecalc...r15-31-10.5r15
This will give me a 65 mph RPM of 2173.5
wow that all sort of made sense and works together... right?
Thoughts?
"Orange Crush"
Old 05-03-2016, 04:34 PM   #173
Kim57
Kim57's Avatar
Doors look good.
So do the tires.
Kim
My build thread
Old 05-03-2016, 04:55 PM   #174
Valarius_Starchaser
Thanks Kim man that picture sure is bigger then I thought it was going to be
I figured I will need #14 on both sides
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=15
I am starting to get a little shaky on weather I will be able to finish this on time with the hours I need to work just to keep getting the cash together to do it I either don't have the time to work on the truck or I don't have the money to work on it
Oh well just keep moving forward day after day
If anyone has a door hinge patch they have available off a used cab pm me details....
"Orange Crush"
Old 05-04-2016, 08:23 AM   #175
lower50's
lower50's's Avatar
Nice tire selection. I think the size's will look really good together.
1951 MG TD
1957, 3100, 454, 4l80e, drag truck
